Question about Impression Products Impression M1 Wireless Internet Keyboard/Mouse
My mouse is a wireless mouse and i dropped it accidently once. Right after the fall,it is not working anymore. Can i actually fix it?
  • Rylee Smith
    Rylee Smith May 11, 2010
    Hi!
    Please tell me the model no. and make of your mouse.
    its light working?
    Does it have a USB port on it for attaching the usb/flash drives?
    Check for the battery.
  • 10,865 Answers
It is possible that the battery popped out when it was dropped. It is possible that the battery got put back in wrong. Open the battery case and remove the battery. Then be sure to replace the battery with the positive end going in the right direction.
That should fix it for u.
Please rate my answer as a fixya thanks
Posted on Mar 05, 2009
I dropped my wireless mouse
it is Depending on how deeply its damaged.. maybe you should post a photo? the only way you can solve it is if There is a part inside that isn't in its right place , but otherwise if any of the electrical components inside were damaged I think it would be too hard for you to fix. Good luck
Dec 18, 2013 | Impression Products Impression M1 Wireless...
I just dropped my mouse by accident and it doesn't work now. How do I fix this?
open up the door to make sure the batteries are okay, reseat the batteries into the slots to make sure the batteries are making proper contact.
If that doesn't work, then try new batteries just to be sure the batteries aren't the issue.
If it still doesn't work then leave the new batteries in and the usb adapter that comes with that mouse, hook it back up to the usb slot on the laptop and see if windows recognizes the mouse. If no messages come up then go into the device manager and see if the mouse shows up in there.
It will show up as either the type of mouse you have or a yellow question mark which would mean you need to reinstall the software for the mouse.
if nothing shows up in the device manager for the mouse then that means the mouse is bad and would need to be replaced.
Dec 01, 2009 | Microsoft Wireless Notebook Optical Mouse...
My new GE 98812 ergonomic wireless mini mouse isn't working anymore. It was very simple to set up for the first time last night (right after I bought it), but today it won't connect at all, even though the...
on the bottom of the GE wireless mouse there is a connect button make sure to push it one time then on the usb there is a connect circle hold it as if you were going to pinch it sounds dumb but I was just having the same problem and I read one of the solution fixes and it said to push connect button on back of mouse and also push it on the usb where it says connect even though the one that you push on the usb stick isn't a button but it is sensed once held with pointer finger and thumb hope this better describes it to fix it
Sep 30, 2009 | GE Wireless Optical Mouse
Ge mouse turns off after holding left and right
sounds like the baterie is cooked 2 me
power drops too low and it turns off
Aug 03, 2009 | Computers & Internet
Wireless Optic Logitech mouse performace
I had the exact same problem with my original Logitech wireless mouse that came with a wireless keyboard. I eventually figured that the button component inside the mouse wasn't making consistent contact causing unintended double clicking or dropping while dragging. I fixed it by doing some soldering to switch the left mouse button with the right mouse button, since I didn't have to use double clicking or dragging with the right mouse button. It worked pretty well for several months until the switched left button started showing the same problem again. Now my newer Logitech mouse (it's more expensive Nano wireless mouse) is having the same problem after about 1 year using it. I think there's a serious durability problem with the button component that Logitech is putting on their mice. I may do the same trick again on this mouse, but now I don't consider Logitech as a good mouse manufacturer anymore. They used to make good quality hardwares but I guess they aren't that good anymore with all those cheap Chinese suppliers for their parts. :(
Apr 28, 2009 | Computers & Internet
My Logitech LX5 wireless optical mouse has never worked properly
hi im josh in cebu phils.may i help you? Friend try my gathered solutions. This problem has a simple solution—replace your batteries! Low batteries in a wireless device will cause all sorts of problems. In a mouse, this typically means that the cursor slows down, jerks around, or seems to hit an invisible wall. Fresh batteries should fix things right up.
If new batteries don't fix the problem, you have some sort of wireless interference. Try moving the wireless receiver to a new position—preferably away from other wireless devices (wireless network adapters/base stations, cordless phones, baby monitors, and the like). If interference continues, see if you can change transmitting/receiving channels on one of the devices, or consider turning off the interfering device while you're computing. Good luck friend hope i helped you.
Mar 04, 2009 | Logitech LX5 Cordless Optical Mouse
Microsoft Wireless Optical Mouse 2000 - Laser Stays the Same
check the battery is secure in position you might have knock it loose when you dropped it
Jun 02, 2017 | Microsoft Wireless Optical Mouse...
I have a Microsoft Wireless notebook optical mouse 3000 that my son dropped in the dog's water dish. We have dried it out and put in new batteries, but it won't light up. I tried my other mouse and put new...
the one dropped in the water is probably no good anymore could have corrosion from the water how long did you let it dry.
if you want to use your other mouse first uninstall driver for dog water mouse then restart if the usb has reset on it then press
was the other mouse combo keyboard
Jan 18, 2009 | Microsoft Wireless Notebook Optical Mouse...
Wireless Keyboard isn't connecting at all with computer
It turned out that the little metal spring that holds the batteries in was bent. It was so slight, you couldn't even tell, but the batteries weren't actually touching. So I just bent the spring back into shape, and now it works perfectly fine.
May 19, 2008 | Fellowes Cordless Optical Keyboard/Mouse...
Impression Products Impression M1 Wireless Internet Keyboard/Mouse Logo
227 people viewed this question
Top Impression Products Computers & Internet Experts
Rocketmanusa
Level 1 Expert
Perry Ralston
Level 1 Expert
Julie Simmons
Julie Simmons
Level 1 Expert
Are you an Impression Products Computer and Internet Expert? Answer questions, earn points and help others
