Need a schematic diagram on a trane furnace model blu080k0942b0
  • 1 more comment
  • Perry Putnam
    Perry Putnam May 11, 2010
    This must be pretty old. I've checked my sources and can't find a wiring diagram. Waht kind of problem are you having? Maybe we can help.
  • Farley Redfield
    Farley Redfield May 11, 2010
    Can you please describe your problem as to what you'll be looking for on the diagram? Is this a gas or electric furnace? (Id guess 80,000 BTU because of the 080 in the model number). What does it do then not do or are you trying to wire it up? If this is the case please tell me what terminal designations the furnace has and your thermostat and if you have AC on the same thermostat.
  • prem
    prem Nov 21, 2013
    gas electric furnace trane xb80
I would like to change the filter on my folks "Packaged Convertible Gas/Electric 1 1/2-5 Tons" furnace/air conditioner unit. I do not have a manual to find out where the filter is on the unit. MODEL # YCC-IOM-1E18-EB21D1-7.
Thank you in advance for your time.
Posted on Aug 03, 2010
    Problem Solver:
  • 15 Answers
Have you checked on the inside of both front panels?
Posted on Mar 30, 2009
Need schematic for trane unit heater model gpar-0050-sa, serial # j79h-04863
Posted on Feb 25, 2011
Trane furnace problems
where? for what? please explain. furnaces tipically have a restrictor where the inducer blower mounts on the furnace.
Apr 05, 2014 | Heating & Cooling
Electrical diagram for contactor (240 v/1 phase/24 v coil)
How to connect motor 1 phase with mcb , contactor , timer ,switch selector on off on , and lamp indicator
Feb 17, 2012 | Omega Trane Furnace Draft Inducer Blower...
I am looking for electrical schematics for the Trane XE80 furnace. I think the ignitor is getting too much voltage such that it is failing too soon. I measured 100 VAC on the 24 VAC ignitor.
The electrical schematic will be on the inside of the lower door...
Check also that the board has not been changed...
Also some of the newer furnaces do use a 120v ignitor and maybe you are being given the wrong one...check the full model and serial numbers to figure which ignitor you need...
I thnik you have a 120v board in there...there is really no way a 24v board can give you 100v...that means you should be getting a new style nitride ignitor that is 120v...
heatman101
Apr 14, 2011 | Heating & Cooling
What is the efficiency rating on the Trane model BLU055E936B1 upflow furnace and what new furnaces are available to replace this old Trane furnace without having to change the venting system.
Chances are you need to replace both the condenser and furnace, then you you should get a varaible speed blower with the new furnace, get at least a 90% gas system with a 16 SEER condenser, save on energy cost as soon as it's installed. Go Get IT
Jan 28, 2010 | Ruud Central System Air Conditioner
New Trane XV95 furnace runs and stops nine
if it is a mechanical thermostat the heat ant. does that on cheaper digital tstats it is set by span and on better stats like honeywell model 5000,6000,8000 series you set the cycle rate. what kind and model number is tstat
Dec 19, 2009 | Goodman GDS80904BNA Open Flame Heater
Trane XE90 both ac unit and the furnace kick on at the same time
How about the Heating/cooling thermostat. Sounds like you better check it.
Jun 25, 2009 | Omega Trane Furnace Draft Inducer Blower...
Need wire diagram for GE electric furnace
Usually the older GE's are straight forward and any generic wire diagram will help you out. If its newer and a Trane made unit try A Trane dealer.
Mar 27, 2009 | GE Heating & Cooling
Hooking up a used 550 to a new 80% trane UD-R9V,
In this situatioin you'll eed a second transformer 110volt to 24 volt to relay from w to common to operate only when furnace being called for.
Feb 07, 2009 | Aprilaire 550 Humidifier
Heating & Cooling Logo
4,748 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
