Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
Intel d845,one long 2 short beeps video problems
Suddenly screen goes black during working on pc.then restarting one long and 2 short beeps it gives and no video comes.but after some time i restart pc work fine but any time screen goes black.i changed RAMS,AGP CARD,BUT problem is still
  • Chinmay patil
    Chinmay patil May 11, 2010
    Have you tried reinstalling latest video drivers?
  • SeymourCompR May 11, 2010
    Usually thats a video error. Could be the port is shot and the cards are fine =/. Hard to say though without more extensive testing. Do you have another machine you can pop the cards into?
  • 530 Answers
Hi im josh in cebu phils.may i help you? friend try to use this solutions of mine surely it will help you.
Your PC uses beeps to communicate with you when something is wrong with the video setup. Check the settings on your video card to make sure that they're correct for your system. Also check any switches on the motherboard to make sure that they're set up correctly for your type of video card. (You should consult your system's instruction manual for details on this procedure.) Check to make sure that your video card is seated properly in its slot; you may even want to try inserting the card in another slot. If none of these suggestions works, try a new video card, or have your system examined by a professional.
In a pre-Windows 98, system, if you have two video cards installed at the same time, they can sometimes interfere with each other and cause neither to work properly. Try removing one of the cards; if this results in the remaining card working, you need to reconfigure one or both of the cards to better work together. (With Windows 98 and later you can install two video cards to run multiple monitors simultaneously
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician. Just try friend it will help you Good luck.
Posted on Mar 05, 2009
No display problem for intel D865GSA board
What are you formatting ? Have you changed the RAM. Does tour system work in its original configuration ? You do not say what the pattern of the beeps is. Before the display disappears, is there a message sent to the screen ?
From the manual
http://download.intel.com/support/motherboards/desktop/d865gsa/sb/d5600601us.pdf
Whenever a recoverable error occurs during POST, the BIOS displays an error message
describing the problem (see Table 53). The BIOS also issues a beep code (one long
tone followed by two short tones) during POST if the video configuration fails (a faulty
video card or no card installed) or if an external ROM module does not properly
checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors,
usually consisting of one long tone followed by a series of short tones. For more
information on the beep codes issued, check the documentation for that external
device.
There are several POST routines that issue a POST terminal error and shut down the
system if they fail. Before shutting down the system, the terminal-error handler issues
a beep code signifying the test point error, writes the error to I/O port 80h, attempts
to initialize the video and writes the error in the upper left corner of the screen (using
both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to
the operating system.
18.April.2014
18.April.2014
Apr 18, 2014 | Intel 865G Motherboard
Black screen green dots
What was the last thing you did on your computer before this happened?
Did you change any system settings in the BIOS?
Did you add new software? or update any software or drivers?
Did you add any new hardware?
Is your system BIOS infected with a virus?
Because it appears that your PC is hanging up during the Power-On-Self-Test [POST]
Here's what happens; when the power is turned on, the computer BIOS [Basic Input/Output System] runs a POST (Power-On Self-Test). It is a diagnostic testing sequence that the computer runs to determine if the hardware [like the mouse, keyboard, hard drive, etc.] is working properly.
If the necessary hardware is detected and found to be operating properly, the computer begins to boot; If the hardware is not detected or is not operating properly, the BIOS issues an error message.
The error message may be a text on the display screen and/or a series of coded beeps, depending on the nature of the problem.
The series or pattern of beeps may vary...they may be in a number of long or short beeps or a mixture of long and short beeps, or even one long continuous beep, depending on what type of BIOS is installed.
Since POST runs before the computer's video card is activated or the integrated graphic chip on the main board, it may not be possible to progress to the display screen.
So if an error is detected during the POST it will halt the boot process because the hardware is essential for the computer's functions.
How many beeps do you hear during the initial POST?
You may have a burned out video chip/card; or corrupt drivers; or even an IRQ [Interrupt Request] conflict.
Nov 26, 2013 | Acer Computers & Internet
Computer won't come on-it gives one short beep. it flashes some computer language - briefly - three different times and then screen goes black but does not shut off. how do I fix this?
One "beep" is good -- multiple beeps mean something is wrong.
Restart your computer, and be ready to press the PAUSE button on your keyboard, to "freeze" that text on the screen, so that you can read it.
Nov 17, 2009 | Compaq Computers & Internet
My computer does'nt boot
Check your Cooling Fan. Sounds a LOT like the fan is getting Sluggish and not cooling the Board Properly.
Jan 20, 2009 | ASUS P5LD2 Motherboard
Black screen with error codes
I think the msg you are seeing is just the default monitor message when there is no video to display. Here is a list of common beep codes: Are you getting the one long beep at each restart?
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 16, 2008 | Computers & Internet
COMPAQ M700 ERROR 101 I/O ERROR
Computer Post / Beep codes Beep Code. Description. Document. 1 long, 2 short, Indicates a video error has occurred ... One Long and Three Short Beeps.
Good Luck, please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Compaq Armada M700 Notebook
Bios Beeps and no boot
Remove and reinsert the dimms
reseat the video card also
put everything back and try agailn
If this dont work reseat the cpu and repeat steps above
If the above fails to fix
If it will boot into safe mode
and use the standard vga as
you did before and restart
and try to reinstall the drivers
You are sure you installed the rilght
drivers for your OS
It may be that the card is not compatible
wilth your mobo.Try checking compatability list
for your OD
Nov 16, 2007 | ASUS A8N-SLI Deluxe Motherboard
Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
219 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
