Question about Sony Playstation 3 (PS3) Console
PLAYSTATIO3 60GB WHEN I TURN ON THE PLAYSTATION IT WONT READY ANYTHING IT WONT EVEN LOAD UP BUT WHEN I TRY TO TAKE THE HARD DRIVE OFF IT READS IT BUT THEN IT TELL ME THAT THERE IS AN ERROR ON THE HARD DRIVE. BUT THEN WHEN I RESET IT WITH THE HARD DRIVE ON IT WONT READ IT AGAIN. DO I JUST NEED A NEW HARD DIVE?
  • bryanr12 Mar 05, 2009
    It will NOT display any video or audio but everything else seems to be working fine. You can hear the disc loading and the system going through its progressions. It sounds familiar to the problems other people have with video and audio problems. I took the hard drive out and tried with out hard drive and a message appeared on the screen saying basically no hard drive. So thus proving the system is capabile of sending a signal to the TV. I don't know what the problem could be but I don't want to just throw money at the problem without some education. Any help is appreciated.
  • Anonymous Mar 06, 2009
    i got a 40 gig that will not load any of the main menu, read the controler or read any disks, what should i do to correct this problem.
    President:
  • 2,653 Answers
Sounds like it.
Any Sata drive 500gb and below will work fine.
You can get them on the cheap at newegg.com
Let me know if you have any other questions or problems.
Posted on Mar 05, 2009
Got wd elements 1.5 tb plug n play hard drive n errh it wont plug n play ??? used on playstation 3 always worked used on my lap top and other peoples neva had any problems lent to a m8 he removed with out...
PlayStation 3 has a Unix like operating system. It is proprietary. http://www.tomshardware.com/forum/279261-32-retrieving-files-stuck-help
The below is how the WD was reformatted to accept P3 content. Even if the PC reads the Fat format, the file types are native to the Unix like system, not Windows. But the above link may be of some help.
http://www.wikihow.com/Add-an-External-Hard-Drive-to-a-PlayStation-3
Jun 14, 2017 | Western Digital MY BOOK HOME 1TB EXT...
Games wont load
it is a blue ray driver failure basically just try this before anything, do a hard reset and then choose the hard drive repair option to hard reset just go and turn off the system then on from the back and hold the reset button until it double beeps and release quickly to go into the system reset menu and go from there might repair any sectors your system is missing for your drive to not work, fixed my issue i had the same problem<!-- from fixya rte -->
Aug 10, 2010 | Sony Playstation 3 (PS3) Console
The playstation 3 wont read discs. Regardless of what disc I put in, DVD, Bluray, game or CD it just wont read. I'm pretty sure that it's not spinning the disc because it doesn't make the humming sound it...
You could buy a new Bluray drive and swap the dead one out. They cost around $80 and aren't hard at all to swap out. You could also try to lubricate the shaft of the drive motor, as it may just have ground to a halt from friction. Other than that, there's not much other than getting a repair/replacement from Sony.
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
It wont read the disks i put in
your cd drive reads disk, it probably is bad
u should look up hard drives on wikiapedia
May 27, 2010 | HP (PV944A) 160 GB Hard Drive
I put any game in and it wont load up even at the main menu and doesnt say anything like disc unread
More likely then not you got a BD failure.
1. try a audio disk if that reads then you need to replace the BD drive inside.
2. If the audio does not read ether you going to need to get the unit repaired as this could even lead to more issues like the controller.
You can also try resetting the unit by turning it off then back on hold down the power button to you hear it beep then you will see a screen, you select reset to factory defualts.
all else fails www.videogamerepair.com can help get this thing going again for you.
This was a FREE answer please do rate it and leave feedback
Apr 29, 2010 | Sony Playstation 3 (PS3) Console
Just brought a new playstation 3 and games for my kids for xmas and everything was good.. just got back from holidays and now they wont load... HELP
try different games and also try different music cd's just to see if it will ready anything.
If not, turn off the machine. turn the machine with the opening of the dvd drive toward the bottom and shake the machine. Do this just to make sure there is not any loose debris like coins or anything else getting in the way of the laser.
If nothing comes out try again to get the machine to read the games. If you still don't have any luck then the dvd drive is bad and would need to be replaced.
Dec 31, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will load some games and not others includind demos
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-4 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO markusmaritz@yahoo.com I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 BUT PLZZZ RATE ME thank
Jul 09, 2009 | Sony Playstation 3 (PS3) Console
Wont read disc
yes is fixable look like you have change the hard drive or something like that ok if this messages appear during powering the unit on then you need to do the follow make sure is a hard drive on it
then get a usb drive connect the usb to your computer then create a folder and name it PS3 open the folder and created another folder and name it UPDATE make sure to use capital letters then go to sony and open the web page for playstation 3 download the update 2.60 install the update in the folder you name it UPDATE and once you have the update ready plug your usb to the playstation but make sure there is a hard drive on the ps3 turn the unit on and then after the message cannot start connect your controller using your usb cable and push the logo PS then again in your control at the same time push SELECT and START at the same and then the ps3 is going to start looking for an update just wait about a minute and on the next screen push SELECT and START again at the same time but this time hold them for 5 seconds and then the ps3 will start looking again for the update and it will start the update automatically
Mar 17, 2009 | Sony Video Game Consoles & Games
When I turn the PS3 on it reads "Cannot start. The correct hard disk was not found." and the hard drive is completely screwed in the back. I cannot do anything even when I restart
I look all over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me.
Mar 28, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
66 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
