Question about Jensen JER-422 Universal Remote Control
Roof Decking for Galveston County Texas
What type of plywood can be used for decking?
  • 10,865 Answers
Http://www.informationdestination.cengage.com/ReferenceContent/Roofing/Plywood%20Roof%20Decking.pdf
If you have a plywood roof deck, make sure that you have at least 15/32" (or ½") plywood thickness if the rafters are set at sixteen inches (16") on center. If your rafters are twenty-four inches (24") on center, it is recommended that your plywood is at least 5/8" inches thick. All plywood should be Exposure 1 Rated plywood and be rated for structural use by the APA-The Engineered Wood Association. This is indicated by a stamp on the plywood that states "32/16" rated. What this means is that particular board is rated for sub-flooring where the floor joists are 16" on center and for roof decking where the rafter or roof joists are 32" on center. The APA recommends a 1/8" gap be left between adjacent panels of plywood/OSB.
please rate this answer as a FIXYA! thanks
Posted on Mar 05, 2009
I have a deck 14x20 I want to replace the decking @.89 a linear ft what would my cost be?
Looks like you're going to be into it for right close to $500 for the decking, give or take. I'd add another $20 - $30 for stainless steel screws, plain old decking screws will eventually rust causing nasty looking stains as well as the possibility of the screw twisting the head off if you ever have to remove it.
Oct 12, 2014 | Pavilion Endure Pressure Treated Lumber...
How do i calculate 600 square feet of 5/4" x 6" decking into linear feet
2 Linear feet of 6" Material would make 1 Sq Ft.
so 1200 linear feet should do it.
Sep 16, 2014 | Pavilion Wood Decking Exotic Cumaru /...
Composite decking is cracking and peeling off
Hire a reputable contractor
Mar 25, 2014 | Garden
What does decking on a dog house look like?
Decking on a dog house basically provides an extra space for dogs to sit. Sometimes it comes with shading but not always.0aaaaasuvork5cyii=
Aug 22, 2012 | Dogs
Codes on layers of shingles on a roof
That would depend on where you live. In Nebraska it is 1 layer now since the code calls for Ice & water barrier to be installed directly to decking now. So I would have to know what county you live in to answer that question accurately.
Nov 11, 2011 | Cars & Trucks
Can an insurance company say they will replace the shingles on a tornado damaged house in NC and not replace the decking when they have slat boards with 3 inch spaces cause their house was built in 1913(...
it depends on your coverage. contact an independent agency to better understand what the rules of NC insurance states. many times, the policy holder doesnt "get" what the policy covers so you very well may not be covered here. but an independent agency will help you out best. Massachusetts Insurance Agency
Apr 12, 2010 | Jensen JER-422 Universal Remote Control
Cut off question
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Aug 27, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Televison & Video Logo
487 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
