Question about LG E500 Express Dual Series Notebook PC
The motherboard is hard to find a power jack for or any info on
Need a power jack pin for a MS-16371ver 1.0 motherboard.it is a laptop. Intel Core 2 Duo T7500 processor. I have been told the LG Electronics E500-GP02B6 notebook has this motherboard also.
the motherboard has a HannStar J MV-4 94V-0 0725 stamp. also
the board has a 116371-1.0 part number stamp on it also.
the board is fairly square with a semi circle portion missing
the power jack has 5 contact legs of which four are located near the corner and one contact in the back center of the jack
  • RescueTechLA
    RescueTechLA May 11, 2010
    A picture would really help.
    I'm good at tracking them down.
Ms 6541 front panel conection
in the lower right corner to find F-P1 18-pin, 3 rows of 2 cables combined as follows: hard drive LED pin 8-blue, red pin 9; button-black power pin6. white and yellow button pin 7 pin9 ready, green Pin8, not only takes away the reset button cable ready source of power and resets
Jun 17, 2014 | Intel Motherboard
Ms 7399
The problem could be with the mother board.It is difficult to pin point the problem without checking Power supply, RAM and motherboard. Before going to any conclusion first disconnect everything from the Motherboard. i.e front usb connectors, front audio connectors, hard disk, cd/dvd drive and floppy drive (if there is one), cmos battery, keyboard and mouse. Now start the system. If there is no difference check with another power supply. Also clean the cpu fan if it is choked with dust.
When looking for a motherboard it may be difficult to get the same type. U may buy a board which supports core 2 duo processor and DDR II RAM. Your machine may be having DDR II RAM. Also boards are available which supports core 2 duo and DDR III Ram. That's all.
Mar 30, 2014 | Computers & Internet
I have an MS-7502VER:1.2 motherboard and i cannot find wher to plug the power switch into
Hi scouts692
The Front Panel Header Pin arrangement for this motherboard is unusual, in that the header only appears to have 8 pins in a single column rather 2 parallel columns of 6 Pins with 1 blank, as most conventional motherboards do.
Pin 1 is POWER SWITCH orange or red (PWR SW 1)
Pin 2 is POWER SWITCH white or black (PWR SW 2)
Pin 3 is POWER LAD + (PWR LED -)
Pin 4 is POWER LED - (PWR LED +)
Pin 5 is HARD DRIVE LED - (HD LED -)
Pin 6 is HARD DRIVE LED + (HD LED +)
Pin 7 is RESET SWITCH blue or green (RST SW/RST 1)
Pin 8 is RESET SWITCH white or black (RST SW/RST 2)
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 17, 2011 | Intel Motherboard
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
Pc will not start , power is good - checked ok - replaced processor, fans now turn slightly when power is connected? but nothing else. replace motherboard? philips hepc 7501/05 g33m ms-7357 ver 1 - no...
Make sure the processor is seated firmly. Also make sure that the MB connectors are securely plugged in. Looks like there is a main connector AND a 4 pin connector on this board with the 4 pin being just to the right of the ports that are on the back edge of the board.
Oct 05, 2009 | MSI G33M-FI Core 2 Quad/ Intel G33/...
Mother board
Description: The Asus P5GC-MX is an Intel 945GC Express-based, compact motherboard.Compared to other compact motherboards on the market, it is inexpensive at around $55.This motherboard supports Celeron, Pentium 4, Pentium D, Pentium Dual Core, and Core 2 processors that use the LGA775 interface.This product can support up to 2GB of memory.
Pros: None noted, given available product data.
Cons: None noted, given available product data.
Suitability: A compact motherboard, suited for small computers.
Value: In view of its inexpensive price, this motherboard has great features for the money.
Suggestions: (1) Be sure that you are using a LGA775-compatible processor with this motherboard.(2) If you want to take full advantage of the on-board SATA controller, you will want to consider a hard drive upgrade.Existing IDE hard drives will run on the ATA-133 bus.(3)
XFXg31
General
  • Product type (AE) Motherboard
  • Form factor Micro ATX
  • Width 9.6 in
  • Depth 7.6 in
  • Compatible Processors Pentium Dual Core , Pentium Extreme Edition , Pentium 4 , Celeron , Pentium D , Core 2 Quad , Core 2 Duo , Core 2 Extreme
  • 64-bit Processor Compatibility Yes
  • Mainboard processor socket LGA775 Socket
  • Mainboard / Multi-Core Support Dual-Core / Quad-core
  • Chipset Type Intel G31 Express
  • Data bus speed 1333.0 MHz
  • Storage key information Serial ATA-300 , eSATA port
  • Power connectors 24-pin main power connector , 4-pin ATX12V connector
  • Processor
  • Installed Qty (Max Supported) 0.0 ( 1.0 )
  • Memory
  • Cache Memory Type None
  • Supported RAM Technology DDR2 SDRAM
  • RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
  • Supported RAM Speed PC2-6400
  • Video
  • Graphics Controller Intel GMA 3100
  • Video Memory Dynamic Video Memory Technology 4.0
  • Audio
  • Audio Output Sound card
  • Sound Output Mode 5.1 channel surround
  • Audio output compliant standards High Definition Audio
  • Telecom / Networking
  • Modem None
  • Networking Network adapter - Ethernet , - Fast Ethernet
  • Features
  • Hardware Features Intel Fast Memory Access Technology
  • Expansion / Connectivity
  • Expansion Slots Total (Free) 2.0 PCI Express x16 - DIMM 240-pin , 1.0 PCI - LGA775 Socket , 2.0 Processor , 1.0 Memory
  • Storage Interfaces Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1.0 device(s) , Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s)
  • Interfaces 4.0 x Audio - Input - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - VGA - 4 pin USB Type A , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX - Mini-phone 3.5 mm , 1.0 x Display / video - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Hi-Speed USB - Line-out - Mini-phone stereo 3.5 mm , Microphone - Generic - Mini-phone stereo 3.5 mm , Audio - Generic - RJ-45 , Keyboard - 6 pin mini-DIN (PS/2 style)
  • Additional connectors (optional) 4 x Hi-Speed USB
  • Miscellaneous
  • Included Accessories I/O back plate
  • Cables Included 2.0 x Serial ATA cable , 4.0 x Serial ATA power adapter
  • Software Included Drivers & utilities
  • Windows Vista Readiness Certified for Windows Vista
  • The Intel board is a discontinued product but is a better board than asus
    Sep 01, 2009 | Computers & Internet
    Need proper wiring for the J9C2 connector pinout
    The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
    you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
    Apr 01, 2009 | Dell Dimension 4600 PC Desktop
    I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to : it_mid@yahoo.com
    First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
    For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
    A quick search of their products results in:
    http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2889&ProductName=GA-G31M-ES2L
    which states that up to 800mhz DDR2 (PC6400) is supported
    ( 667mhz (PC5300) is also supported. )
    Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
    PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
    Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
    Connecting front panel wiring to INTEL 845GRG Motherboard
    Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
    See page 9 for motherboard layout.
    The front panel connectors are shown on page 68, see item C.
    On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
    Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
    Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
    The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
    If this manual is not what you see on the MB, please advise.
    Good luck davideiker1!
    Need more information/questions post here.
    Thank you for using FixYa.
    Input, comments are welcomed.
    Mike
    Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
    LG E500 Express Dual Series Notebook PC Logo
    2,896 people viewed this question
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
