Question about Spherex Xbox 5.1 Surround Sound System Computer Speakers
Is the spherex xbox 5.1 surround sound system compatable with the xbox 360, if so how would I set it up because It's not working the way I'm doing it.
  • 34 Answers
Yes my bf has if u have a newer tv u just plug in to the digital audio output or u can plug it right into ur xbox ull need the adapter that comes with it
Posted on May 20, 2009
Speakers have hiss and crackle but no sound coming through optical feed on spherex xbox 5.1 surround system
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 27, 2011 | Spherex Xbox 5.1 Surround Sound System...
Not getting true surround sound
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
  1. Start the Xbox 360 console without a disc in the disc tray.
  2. In the System section of the Xbox Dashboard, select Console Settings.
  3. In the Console Settings area, select Audio.
  4. In the Audio Settings area, configure settings for analog output or digital output:
    • Analog output settings:
      • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
      • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
    • Digital output settings:
      • Digital Stereo: Select this setting to use digital stereo output.
      • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
      • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
  • Xbox 360 Component HD AV Cable
  • VGA HD AV cable
  • S-video AV cable
  • Advanced SCART AV cable
  • Japanese HDAV D-connector AV cable
Additional info:
http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
Sep 28, 2009 | Audio Players & Recorders
Spherex Xbox 5.1 Surround suound..USB does not work
If the xbox is not able to recognise the usb, it is most likely that the product is not compatible with the xbox i would look for an adapter which would take the usb connection to the xbox's analog connection, or if your speakers have a stero 2.5 connection then you can easily find an adapter to connect to the xbox's analog connection in the back, the analog connection is the red and white ports at the back!.
Feb 11, 2009 | Spherex Xbox 5.1 Surround Sound System...
My xbox 5.1 SPHEREX SURROUND SOUND SYSTEM DOES NOT WORK NO POWER
my bfs did this same thing he went to radio shack found the fuses replaced them and boom works great its been workin over a yr in half now no problems
Jan 10, 2009 | Spherex Xbox 5.1 Surround Sound System...
Xbox 5.1 surround sound not working. not coming on at all
so no power at all ?? then u might want to check the fuse in the back and are cheap my bf had this problem bought fuses and works like a charm for over a yr in a half
Dec 28, 2008 | Spherex Xbox 5.1 Surround Sound System...
FIBER OPTIC
You don't need it, but you probably want it if you have an xbox adapter with a digital/optical connection. They are pretty inexpensive particularly if purchased online. Here is an example:
http://www.iunitek.com/iunitek/index.cfm?fuseaction=shop.dspSpecs&part=2885066
Sep 03, 2008 | Spherex Xbox 5.1 Surround Sound System...
Can hear everything except the te voices in movies.
You could try hitting the dynamic compression button on the remote and that makes the highs and lows close im not sure if this will help but it might and another thing you can do is hit the front green button up more so it will be louder hope this helps
Jun 08, 2008 | Spherex Xbox 5.1 Surround Sound System...
Lost Remote
call spherex416 321 6211 when you call they will say its api (audio products international) and say you have lost your remote to your spherex xbox suround sound and they will transfer you to the parts department or ask to be transfered then tell the person there you would like to buy a spherex remote and the guy told me its about $14and plus shiping he said is $25 idk why shipping is so expensive. but i did not order yet because i dont have my debit card yet and the problem with me was i dropped my remote while music was playiong then it wouldnt turn it on or off or do anything for that matter but the led still lit up along with the ir led because i checked with my camera so im buying a new one i just hope that i broke when i droped it not something else and i took it apart theres like nothing in it that could brake lol i hope this helps it was long i know sorry.
May 22, 2008 | Spherex Xbox 5.1 Surround Sound System...
My shperex xbox 5.1 doesn't work for the right speakers
Unless your using the Optical and Coxal input you wont get 5.1 surround sound.
Mar 06, 2008 | Spherex Xbox 5.1 Surround Sound System...
Spherex Xbox 5.1 Surround Sound System Computer Speakers Logo
473 people viewed this question
Top Spherex Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Spherex Audio Player and Recorder Expert? Answer questions, earn points and help others
