Ep 771 unit shutting down.
The lamp has not reached its end of life it's about halfway through. The unit powers on and the bulb is extremely bright. The unit will say warming up and then 30 second to 1 minute the lamp goes out and the unit stays on. There is no sound or flashing led lights. I'm wondering if this is a known problem or any way to fix the unit. I have tried using a replacement bulb and re seating the old bulb. For the love of god please help me!!!!
    Scholar:
  • 93 Answers
Check all the filters for dust and fur. This sounds like an overheat problem, and the easiest way of preventing damage is to remove the heat source, so the projector turns the Lamp Off. Also clarify that the fans are turning when the unit is powered up.
Posted on Mar 05, 2009
What does it means of 6 seconds red light interval of my NEC MT1050 projector,and how will I fix it to come back to life?
Holding down the "OFF" key on the remote control for 30 seconds
to reset the lamp timer
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jun 13, 2014 | NEC MT850, MT1050, MT1055, MT1056...
TV is warming up slowly
Based on model number indicated and fact it is not shutting down it most likely is the lamp reaching the end of its 2000 hour life.
Original lamps from Mitsubishi last longer than "generic" ones that often have half the life and are not as bright.
Jun 11, 2012 | Mitsubishi WD-60735 Projection Television
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Replaced lamp in 55vg825 approx 1500hrs ago & lately the picture has lost brightness compared to when the new bulb was installed. Is there another adjustment or is the bulb defective already? Past...
bjac,
You are correct about lamps working or not, but that is the extremes. Over the course of operation all lamps lose brightness as the hours add up. All lamps will lose their brightness over time.
Typically lamps only last at best 6000 to 8000 hours. That is not long if the unit is used most of the day everyday. In addition the cheaper the quality of the lamp, cost and manufacture, the quicker they go down hill.
Assuming that you have a low quality lamp what you are experiencing is normal. You may be able to improve the brightness and clarity of the picture by cleaning the lenses, mirrors and screen. I have a tip at
http://www.fixya.com/support/r4690955-clean_lense_screen_in_projection_tv
This tip is labeled projection tv but is also appropriate for cleaning an LCD or DLP unit.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 14, 2011 | Hitachi UltraVision CineForm 55VG825 55"...
The image is very dim, even on maximum brightness. We are considering replacing the bulb, but bulbs for this projector are very expensive and we suspect that since there is some image, the bulb is not the...
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Mar 07, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
Tv turns off for a minute and comes back on
if tv turns On itself after shuts down then its symptom of weak lamp as current lamp is reaching to end of its working life, tv requires lamp replacement.
Lamp replacement procedure would be written in user manual and its easy. Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
Infocus LP 280 runs for 1 min then shuts down, runs again then
are the leds on the top lit or blinking? it could be the lamp, the ballast, or the fans. check the lamp. if there are black spots or bulges in the lamp, replace it. if not, make sure the fans are running. if they are, replace the ballast.
Jun 09, 2009 | InFocus LP 130 Multimedia Projector
Projector stays on for a while then shuts down
Two things that usually gives this symptom. One, internal heat sensor will shut down projector if extreme heat is present, usually caused by dirty filters, fan failure, etc. Two, your bulb has reached its life end.
Feb 02, 2009 | Eiki LC-XG210 Projector Multimedia...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
