Our Sharp TV often displays the message "No Operation off: Remaining 5 minutes". It then counts down to zero, and the set goes off. How can we eliminate this?
  • richardgaski Mar 05, 2009
    Our set is a LCD Sharp Aquos
    This response is not worth the money. Please refund the charge.
    JRG
    Master:
  • 416 Answers
The function NO OPERATION OFF is enabled. Then TV operates 3 hours is shuts off. You need to disable it by going to menu POWER CONTROL NO OPERATION OFF ENABLE/DISABLE
Press Disable and you are done
Good Luck
Posted on Mar 05, 2009
  • 173 Answers
Hi
In this case you have abnormal system operation or abnormal 5V Dc supply in system IC, if you have knowledge in electronics repairing i can teach you how to fix this problem
Thanks!
  • 4,472 Answers
First off what is the make and the model of the tv? Once I have this information I can assist you properly. Please don't request more assistance until I get a chance to assist you further.
Thank you,
Lee
  • Lee A.
    Lee A. Mar 05, 2009
    http://www.cleverhome.com.au/user/Sharp-...
    refer to p.28 of this manual. All this is, is a setting that when there is no action taken it shuts off. This saves the life of your tv. You can change the settings by viewing p.28 of the manual by clicking on the link above. I believe the default is 3 hours. If you still need further assistance let me know. Also please take a moment to rate my solution accordingly.
    Thank you,
    Lee
  • Lee A.
    Lee A. Mar 05, 2009
    I'm sorry it is possible you are not able to see my added comments but I definitely have the solution to your problem. If you still need assistance or are having any trouble rating my solution please let me know.
    Thank you,
    Lee
HOW DO I SET THE CLOCK
Hi, 1. Switch the source OFF. 2. Enter the Time setting mode.Hold ^ button for 2 seconds 3. Select "Hour" or "Minute" with the 2/3 buttons. 4. Set as desired time with the 5/° buttons. As soon as you switch to "Minute", the seconds start counting from 00. 5. Cancel the Time setting mode. Note: ? Holding down the AUDIO button for 2 seconds also cancels the Time setting mode. ? To turn the time display ON. The time display disappears temporarily when you perform another operation, but the time indication returns to the display after 25 seconds. Note: ? When the sources are OFF, the Time appears on the display. Pressing the CLOCK button switches the Time display ON/OFF.
Jun 15, 2011 | Pioneer DEH-1100 CD Player
Descaling process counts down on the displat but no solution is running through the unit and thr counter stops on 1 min remaining
This is normal behavior, your machine is fine.
For example, the machine says "5 minutes remaining" and then it goes 5:00, 4:59, 4:58....etc all the way down to 4:01.Then it changes to "4 minutes remaining". Which is 4:00, 3:59, 3:58, etc.
So at "1 minute remaining" the machine is really at 1:00, then 0:59, then 0:58 and all the way down to 0:01.So, after the "1 minute remaining" goes away, the machine is actually done cleaning itself.
May 08, 2011 | Miele CVA 4066 Stainless Steel
Pioneer DEH-11 how do I set the clock
5/° buttons.
Note:
• Holding down the AUDIO button for 2 seconds also cancels the Time setting mode.
• To turn the time display ON.
Note:
• When the sources are OFF, the Time appears on the display. Pressing the CLOCK button switches
Thank You.
Mar 21, 2011 | Pioneer DEH-1100 CD Player
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
How do i reset the maintenance count?
1. Select Reset Maintenance Count Configuration menu.
Mar 30, 2010 | IBM Infoprint 1532 Laser Printer
Reset maint counter
Page 3-17 of IBM's service guide
Mar 25, 2010 | IBM Infoprint 1352 Laser Printer
HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
Count-down, Racing Timer and Alarm features
ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
Superb performance
Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
Specifications
Calibre: ISA 8270 Yachting Movement
Size 11 1/2’’’
Swiss Made quartz movement, 9 jewels
6 hands, 2 counters, 3 pushers
Hour, minute, small second at 2H counter
Date window at 6H
Count-down (max. 10 minutes)
Racing timer (max. 96 hours)
Alarm (12 hours)
Technical information
Diameter: 25.60mm
Movement height: 4.60mm
Height of stem and pushers: 2.25mm
Jan 15, 2010 | Watches
How to reset maintenance counter on a Dell 5310
1. Turn off the printer.
2. Press and hold (check) and .(right arrow).
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
5. Select Reset Maintenance Count from the Configuration menu.
6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset.
When the reset operation is complete, the menu returns to the Printer Setup Reset
Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press
Select to Return to Ready status.
Jul 21, 2009 | Dell 5110cn Laser Printer
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Errors list : 46, 50, A1
CP315C/310CN/120C/115C/117C/110C
(1) Press the (1) Press the
Menu and Mono Start keys. Menu and Mono Start keys. Next press the key four times to make the machine Next press the key four times to make the machine
enter the maintenance mode. enter the maintenance mode.
(2) Enter 8 and 0 by using the and (2) Enter 8 and 0 by using the and
Set keys.* Set keys .*
(*To enter a numerical code on models having no numerical keypad, press the key several times to (* To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the display the numerical code to be entered and then press the
Set key. Set key. Repeat this operation for each Repeat this operation for each
numerical code.) numerical code.)
(3) Press the (3) Press the
Mono Start key several times until the purge count appears on the LCD. Mono Start key several times until the purge count appears on the LCD.
(4) Enter 2, 7, 8, and 3 by using the and (4) Enter 2, 7, 8, and 3 by using the and
Set keys to reset the purge count to zero.* Set keys to reset the purge count to zero .*
(5) Press the (5) Press the
Stop/Exit key to return to the initial stage of the maintenance mode. Stop / Exit key to return to the initial stage of the maintenance mode.
(6) Enter 9 twice by using the and (6) Enter 9 twice by using the and
Set keys to exit from the maintenance mode.* Set keys to exit from the maintenance mode .*
Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
Televison & Video Logo
541 people viewed this question
Top Televison & Video Experts
