Question about Sony SLV-N750 VHS/S-VHS playback VCR
Vcr clock setting
How can i set the time on a sony vcr without original remote? I've tried with a universal remote. I still can't get it to work. It says automatic clock set on the vcr also.
Probably you can't. That's a big pet peeve of mine with A/V equipment these days- so much of the control is by remote only and if it dies your machine is almost useless
Posted on Mar 05, 2009
My Sony VCR Model SLV-662HF will not accept cassettes. I am using a universal remote control. The VCR's display shows APC 71501 and 81508. Do these APC codes refer to the VCR or the All In One universal...
The codes are to program the universal remote control to communicate with the Sony VCR. Try programming the universal remote using one of these: 60000 60032 60033 60035
The acceptance of the cassettes may not be related to the use of a universal remote control. If the URC doesn't have the "equivalent" functionality of the VCR's original remote control, you may not be able to use the URC to perform the functions of the original remote control.
Dec 13, 2013 | Sony Slv-662hf 14" Vcr Plus Rmt-v266...
Remote CTL model RM-V210 doesn't allow programming of the VCR.
Dear sir/madam,
http://www.thompsontv.com/rcarc.html
click the above link and programmed your remote control..
thanks
good luck
Oct 01, 2008 | Sony SLV-679HF VHS VCR
What button on my rca universal remote (rcrn04gr) to set the time recordings after info put in for time recording on my emerson dvd/vcr (ewd2203). The original remote you push t-set button before and...
Most of these universal remotes don't always have the same features as the original remote. I usually just keep the old remote for just that purpose---to set the T-Set. Otherwise, sorry.
Oct 05, 2013 | RCA RCRN04GR 4-device universal remote...
How do I set the clock without the remote?
http://www.ebay.com/itm/HIGH-END-MITSUBISHI-MODEL-HS-U440-VCR-W-REMOTE-NICE-/230751842386?pt=VCRs&hash=item35b9e1b052
Look at link above, you could buy the original remote from e-bay for $25 plus get another vcr. Only two days left so act fast. Universal remotes - try a different one, other than that its going to be difficult. You could also buy another vcr that has its own remote from a thrift shop or craigslist.
Feb 23, 2012 | Mitsubishi HS-U440 VHS VCR
I am trying to get a remote code for my slyvania 6719
I also can't find the remote for my Sylvania
TV/VCR/DVD combo...
Model number 6719DF. I don't normally use this tv
(it's an extra spare that I plug into our generator when
the power goes out... since our regular family TV is
quite big and set into the wall making it difficult to
track cords around, I drag this crappy Sylvania down
from our dining room to our family room) I did
happen to find an old Zenith universal remote that
does work with it in some ways (See directions
below). I can turn the TV on and off, set the channels,
language, clock.. etc through the Input select button
on the universal remote but can't set to "Game Mode"
after using connections with video/audio input cords
plugged into the front panel of the TV. So
Playstations, extra dvd players or vcr's, etc won't
work.
Switching from the VCR to DVD and vice versa does
require manually setting the tv itself (remote doesn't
work with that) but at least I can set sub titles, fast
forward through chapters on Dvd's and control the
volume, etc without having to constantly walk over to
the tv.
Programming the remote: I've noticed a lot of people
have tried using codes supplied by different universal
remote providers and couldn't find a code that
worked using their lists with this particular model...
there is a way that it can be done but it's a bit more
time consuming:
Many types of "universal" remotes give the option of
"scanning" the electronic device for a code if one is
not available or the one provided with lists does not
work... Every universal remote though needs certain
buttons pushed during the "scan" and they are all
different! Ha! So if you lost or misplaced the MANUAL
as well (like me!) you might need to do a search on a
manual for your particular universal remote, but I can
at least give you directions on programming a
"Zenith" Universal remote to "scan" for a Sylvania
TV/DVD/VCR combo model 6719DF:
Using the Zenith Universal Remote or any Universal Remote using it's "scan" method:
1: Shut off the TV
2. Press and hold "Code Search" on the remote until
the red LED
light lights up and stays lit.
3. Press the device button for the device (In my case,
for my crappy Sylvania combo, I pressed "TV".)
The LED light will blink once.
4. Scanning: Slowly press and release the "Power"
button on the remote, waiting a few seconds between
while watching the TV to turn on. It's very important
that you pause in between because if you do it too fast
and the TV turns on before you press the power
button again... you'll have to start all over. I've
learned that lesson.
It took 160 presses each time on that button to get the
correct code scanned! I had to do it over 3 times
before I stopped myself beforehand because I was
pressing it too quickly..
5. Right after the TV power turns on, press the "Mute"
button on the remote to set the code. It should work with few limitations (no "game" mode)
after that.
May 26, 2011 | Sylvania 6719DF 19" TV/VCR/DVD
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
Cant set clock or access menu using universal remote
Haven't found answer to that, but there is a remote contol specifically for your unit now on EBAY at http://cgi.ebay.com/SHARP-VCR-RRMCGO173AJSA-Remote-Control_W0QQitemZ350117240995QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116. The whole thing is under $10 including shipping. If nothing else, copy the model # of the remote and you might be able to find it cheaper someplace else.
Dec 04, 2008 | Sharp VC-H973U VHS VCR
Orion VR213
Call the number on the unit to price an original remote.
Jul 23, 2008 | Orion VR213 VHS VCR
Can I use another remote?
I have the same model TV, also without a remote. I found a Philips universal remote model CL019 at Big Lots and it works just fine. However, for some reason when I tried to program in the channels it would only program in up to channel 23, and then after about 15 seconds add channel 60. Can anyone help?
Jan 19, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Sony SLV-N750 VHS/S-VHS playback VCR Logo
265 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
