Question about Maytag 24 in. MDBH970AWS Built-in Dishwasher
Maytag MDBH970AWS Heating element won't turn off. Dishwasher heating element won't turn off. Have to shut off the breaker to make it cool down. Heating element gets hot as soon as you flip the breaker back on
  • 1 more comment
  • Anonymous Apr 18, 2009
    I have same problem and it looks like some other maytags were recalled due to faults with the heating elements. my numbers don't match though. go to the maytag website to find out for you.
  • Anonymous Mar 22, 2014
    element heats up when dishwasher begins
  • Anonymous Mar 28, 2014
    heat back on after all cycles have finished have to turn breaker off to shut heat off
  • 360 Answers
The heater relay is located on the control board, a faulty relay or a faulty control board would cause the problem you have described. The fix is to replace the control board. Parts for your unit should be available from most appliance parts retailers, if there is not one local to you, the part is available at www.apliancepartspro.com. along with an exploded view of your unit
Hope this helps.
please take the time to rate this solution
Posted on Mar 05, 2009
E1eh-017ha ele.furnace fan shuts down then the heating elements get4 times hotter turn off.discount breakers in furnace still hot sets off fire detector. You have got to kill main breakers
Dont really understand .Is it a furnace with electric heat ,if it is then Check to see if contactor or relay is stuck closed ,also you heating element should not get so hot there should be a limit switch to shut heater off .Maybe bad limit and bad relay .Your electric heat should shut off when fan shuts off
Feb 15, 2018 | Heating & Cooling
LDS4821ST HE error...new heating element already installed
The manufacturer has assigned this error or fault code to indicate a problem with the water heating circuit. Turn off the circuit breaker to the dishwasher for 30 minutes, allowing time for the appliance to cool; then restart the cycle. If error returns, check the heating element for continuity and check the wiring harness for any obvious signs of damage. If the heating element shows infinite resistance after testing with an Ohm meter, replace it.
Sep 28, 2016 | Dishwashers
Oven will not shut off
Good Morning Friend,
I understand your Frigidaire oven will not turn off. I also see that when you turn it off, the blower and heating element, stay on. The blower will stay on to help cool down the oven, but the heating element should turn off. I see that you have to turn your oven off at the circuit breaker. I suggest contacting your local authorized dealer for further assistance. They will be able to diagnose your appliance and determine why your oven will not turn off. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Ovens
Oven will not turn off
-Best Regards-
WP
Hello niki4god - I recommend resetting the dishwasher by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on the unit. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your unit may possibly be experiencing a communication problem with the control board or a potential wiring failure.
Jun 20, 2013 | Frigidaire 24 in. FDB635RF Built-in...
LG LDS581 dishwasher HE error mid cycle
HEATING (ELEMENT) ERROR // Water heating error
Oct 01, 2017 | LG 24 in. LDS 5811 Built-in Dishwasher
Dose not clean dishes internal water jets dont spin
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 22, 2010 | Maytag 24 in. MDBH970AWS Built-in...
D/washer fills with water rinses when heating shorts out house
If this machine has been installed and worked for a while, are you sure nothing else has been pluged into the same circuit as the dishwasher and overloading it. If the element is actualy heating up I doubt anything is wrong with it to kick out the breaker. Check out what other stuff goes out with the breaker off.
Oct 29, 2009 | Maytag 24 in. MDBH970AWS Built-in...
Dishwasher Heating element not working
rclay How old is your dish washer? It has up to five years limited (parts only) warranty on the electronic control. If it is within this period of time, then you can call Maytag and they will send you a new part. If you are not sure how old is it, you can find it with Maytag by the model and the serial numbers (on the door frame). The warranty for your dish washer you can get here: http://www.maytag.com/cust_serv/pdf_use_care_manual/6_915728.pdf Gendos...post back
Jan 31, 2007 | Maytag MDB9100A Dishwasher
Maytag 24 in. MDBH970AWS Built-in Dishwasher Logo
884 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
