Question about Apple iPod mini M9160LL/A MP3 Player
Ipod mini doesn't turn on
My ipod mini won't turn on despite being on the charger plenty of time. Any ideas? Thanks
If you mean on the charger as in pluged into your computer this will not charge a completly dead ipod because it tries to run i-tunes at the same time. So when it gets enough power to start to turn on then i-tunes draws more that it has , you need to plug it into a wall charger for a while if this does not work the batteries are bad and need to be reolaces.
Posted on Mar 07, 2009
IPOD TOUCH WONT TURN ON
Marclla, Check the attached links,instruction and guides to get IPOD up and running, Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
My iPod Touch 5th generation won turn on
If your iPhone iPad or iPod touch doesn respond or won turn on
Fix iPod won turn on problem Quick Fix
http://ccm.net/forum/affich-786664-5th-generation-ipod-won-t-turn-on
Apr 01, 2016 | Apple iPod touch
My dell Inspiron mini won't turn on. I have
disconnectt the adapter+battery and HOLD the power button by 30 seconds. in order to eliminate any EDS, in the power. And try again.
However if the problem persist, test very well the adapter+battery and p.supply in the c.board of computer for some cold solder contact, etc God bless you
May 21, 2013 | Computers & Internet
My ipod wont charge when i plug it in
Hello, welcome to Fixya!
If your ipod won't charge, the fault should either be from the battery or from the means by which you are charging it.
If the battery is very weak, then it might not come-up when using charger or PC to charge it. Leave the ipod in the charge for about 6 hours and it should come up if the battery is weak.
But if it doesn't come up, then you have to check your charger. Test your charger with a friend's ipod. If the charge works with your friend's ipod then it means your battery is the cause of the problem.
The essence of the above test is to diagnose and get to the root of the problem. So that a precise/concise solution can be proffered.
I hope the above is clear. If not, please let me know.
Regards.
Nov 17, 2011 | Apple iPod touch
My ipod won't turn on i just have a white screen and tha in nts only when it`s pluged
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thanks for using Fixya!
Jun 02, 2011 | Apple iPod MA446LL/A MP3 Player
My ipod 30gb needs to connect to its charger before it power on, and sometimes when i disconnect it from its charger sometimes my ipod will also shutdown, My next problem is that, when my ipod 30gb...
The Batteries in these units like all rechargeable batteries only have a certain number of times they can be charged and discharged before begining to fail. Your only option is to replace the battery with a new one. They are cheap to purchase off eBay and YouTube has Videos detailing how to change them.
May 06, 2011 | Apple iPod MA446LL/A MP3 Player
Yes
To reset iPod mini:
1 Connect iPod mini to a power outlet using the iPod Power Adapter.
2 Toggle the Hold switch on and off (set it to Hold, then turn it off again).
3 Press and hold the Menu and Select buttons for at least 6 seconds, until the
Apple logo appears.
If Your iPod mini Won’t Turn On or Respond
• Make sure the Hold switch is off.
Jun 25, 2008 | Apple iPod nano
Ipod charger is buzzing !
  1. no it is not noral for the buzzing, try the one that go on the computerand see if work that way
Dec 25, 2007 | Apple iPod nano
Mini ipod freezing showing charger sign
restart your pc press del key in your keyboard,
go to setup usb settings disable usb 2.0 setting
Sep 15, 2007 | Apple iPod mini M9160LL/A MP3 Player
My mini ipod freezing, showing charger sign i could not turn it to menu
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 14, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod mini M9160LL/A MP3 Player Logo
194 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
