Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
The external display on my blackberry pearl flip is empty
It is a back lit screen and it has "Daily Alarm" 8:00 am. I have turned the alarm off but I cannot get the clock to display on the external display
  • 1 more comment
  • mama_wolf2 Mar 13, 2009
    I used the alarm feature on my blackberry pearl flip once and since then I can not get the external display to show the clock face. The external display now says alarm and I can not change it.
  • 7kidsdad Apr 02, 2009
    External display says "Daily Alarm 5:00a" and I cannot make it go away. It won't even change when a call is coming in.
  • Anonymous Apr 21, 2009
    After I snoozed my alarm from the external keys this morning, it did not re-play when the 10 minute snooze time expired. I had a message when I opened it - something about an unexpected error. I turned the phone off and back on, and now I get the "Daily Alarm" message on the external screen. I do get a notification when a call is incoming. I turned the alarm off; I also set the alarm to a new time, and it did not sound when that time came.
I had the same problem. i reset the alarm to go off immediately, then dismissed the alarm. i also reset the default theme. the clock came back to the external display and the daily alarm message went away!
Posted on Apr 21, 2009
Sometimes if u power off ur phone and take out ur battery and restart the handset, it works. else reset ur company settings. hoping this helps u!!
Posted on Dec 19, 2009
Hi
I have blackbery pearl flip once i removed my software and i instill it agan.frant clock is not working and not display any thing .phone is working fine.
ok
Posted on Mar 22, 2009
My blackberry pearl 8220 flip does not last enough even though I charge it daily for the amount of charge needed.
If your not using bluetooth make sure it's turned off, and check your screen settings, brightness and backlight time, perhaps you could find a setting there you can save power with.
Jun 02, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Missing Calls and Texts. Alarm Caput.
Cause:-
Call logging is not enabled for the Message list.
Ensure call logging is enabled from the Phone application Options menu.
1) From the Home screen, open the Phone application.
2) Display the menu and select Options.
3) Select Call Logging.
4) In the Show these call log types in message list field, select the type of call log to be displayed in the messages list.
5) Display the menu and select Save.
I hope I was able to help you.
Nov 23, 2009 | RIM BlackBerry Pearl 8100
How can I get my alarm clock to show on the front screen?
I don't think you can, unfortunately. The blackberry doesn't allow you to move icons that are within other folders, so you can't move the alarm clock app. I know, it's frustrating!
Aug 09, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Screen turned black , internet and external LCD i have no idea who is texting or calling please help. I already restored firmware and wiped and did to factory settings and used desktop software removed all...
It sounds like your LCD screen got damaged. It may have been water damage or if dropped the connector for the lcd screen may have come loose
If you g=follow this guide, you can take the LCD apart and check to see if the able is seated probably. If it is seated, then theblackberry LCD screen is damaged and needs to be replaced.
Blackberry Flip 8220 LCD screen Replacement Guide
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Checkout the guide I wrote for replacing the blackberry flip LCD displayscreen. There are also links to by the new pearl flip LCD screens2.gif
Aug 02, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Broken screen on Blackberry 8220 Pearl Flip
If you're tech savy you can use a blackberry repair guide that will show you how to disassemble it step by step and replace the screen, the screen is available on Ebay or you can go to the repair service.
Jul 15, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Display on pearl flip when closed is always black
John-
It is possible the backlight or the LCD itself got damaged. The good news you is you can replace it.
Jun 03, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
My blackberry pearl flip got wet
Sorry to tell you but the back light on your blackberry pearl probably burnt out. That is one of the most common issues with a wet phone.
May 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
External display on pearl 8220 cracked
Check out the guide I wrote for replacing the blackberry flip LCD display screen. There are also links to by the new pearl flip LCD screens
Mar 17, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I tried resetting the phone setting, now T mobile is back on the external display. I would like T mobile be removed and relevant info. be displayed.
Go into the Application Loader in Desktop Manager and make sure that BlackBerry Attachment Services is loaded. That will restore your external display clock.
Feb 20, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
3,064 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
