Question about Sanyo DP42746 42 in. Plasma Television
My plasma tv seams to not be getting enough power
  • 71 Answers
Install a spik guard
Posted on Mar 05, 2009
Why does my Vizio 50" plasma tv not capture the video signal? It keeps poping in and out till it warms up and then it will finally hold the signal.
Be sure that your signal is strong enough coming through the HDMI or coax. If your signal is strong enough, it may actually be your TV's power supply needing to warm up.
Nov 10, 2014 | Vizio P50HDTV20A 50 in. Plasma HDTV
Pt425 no sound
sounds like possiable mainboard
Feb 04, 2014 | Norcent Technologies PT425 42 in....
LG 50 inch plasma wont power on?
U can chk the fuses in the back but it is poss u have shorted it out and it will need to go in to a TV service company. Mine was about us $ 150 to fix. I touched the satelite wire against the back grill of the tv briefly but this was enough. Dont forget to chk that u r getting power off the power switch it is plugged into. Also if it is plugged into something else chk that this is providing power out as it has fuses too. cheers.
Aug 27, 2012 | LG 50PA4500 50" 4500 Series Plasma HDTV
Sanyo tv plasma model DP50741stopped working
Does it front panel light ON when you power up the set? If not, the problem is with its main power regulator board. If not, the fault must be to its circuit board.
Jul 02, 2012 | Sanyo Televison & Video
I hace a samsung flatscreen that the screen flickers with no picture and turns itself on and off.
Hi this is a power supply issue. Your power supply is not strong enough to power your tv anymore.
You can get get parts for this tv at www.interliquidparts.com
Nov 19, 2011 | Samsung HP-T4254 42 in. Plasma Television
Best plasma TV HDMI
None.All Plasma tvs designs are alway have high heat output and consume alot more A/C power energy than any other tvs designs out there.Tvs like CRT-tube tvs,DLP tvs -Projection tubes and projection lamps tvs,LCD-flourescent tubes tvs as Liquid crystal display screen tvs.All these tvs designs are all good tvs designs to buy but the pictures display and screen lighting and the sharpness of the pictures never have and able to compare high enough qualities as a display picture on the screen output to a Plasma screen tvs,until now LED-tvs are LCD and LED screen display combine to make it better and brighter technologies and now are good enough to compare to a Plasma screen panel tv.So buy a LED tv will get less heat output and comsume less A/C power energy too and it is good enough pictures qualities too.To compare too as a plasma screen panel tvs output.
Oct 28, 2011 | Televison & Video
We have a 50inch plasma and when we attempt to turn it on via the remote, the tv power indicator flashes and the tv doen not switch on
The most common cause of Failure in this unit is power supply failure caused by failed capacitors.
A visual inspection is The easiest way to identify and confirm bad capicitors on the power supply.
Such a capacitor will show one or more of these symptoms:
1) Bulging of the vent on the top of the capacitor. (The 'vent' is the impression stamped in the top of the can. The impression forms the seams of the vent. It is designed so that if the capacitor becomes pressurized it will split at the seams relieving the pressure rather than making it explode.)
2) Sitting crooked on the circuit board as the bottom rubber plug is pushed out.
3) Electrolyte (a crusty brown substance) leaked onto the board from the base of the capacitor
4) Venting from the top of the capacitor, visible as rust-like brown deposits, or a visible hole in the vent
Once the power supply is repaired or replaced your tv should work normally
Jun 26, 2010 | Panasonic Viera TH-42PX80U Plasma TV
PLASMA TV PROBLEM
The problem with this set, is defective YSUS board, to avoid future same problem, you must change the following boards: YSUS, ZSUS & Control.
Verify with LG if your serial Number is included within
lots production that were recalled by this design defect
May 28, 2010 | LG 42PJ350 42 in. TV
Hitachi 55FX48B 55 in
well, if you know how to repair tv, I can provide you its service manual, just post here your email and get it.Hope you have necessary tools to rectify and check semiconductor components ;)
regards,
Sep 02, 2008 | Hitachi 55FX48B 55" Rear Projection...
The screen on my plasma tv keeps turning itself off....
it seams that your tv is high heated or it is needed to change some of the tranzistors... as it seams the damage isnt realy bad..but it need an "experts hand" to be fixed
Nov 29, 2007 | Televison & Video
Sanyo DP42746 42 in. Plasma Television Logo
64 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
