Question about FixYa Service
Hello I can not down load the Expert Utility Software. It reads ERROR c:program filesFix YaFixYaUtility.exe I have tryed to shut off my firewall then download but it still does not work. Somehow I was able to download it at work through a really good network firewall. Can you please help.
  • 3 Answers
Is there a way to delete the 400 bad requests?
Posted on Mar 05, 2009
Need to fix error code for wii #32004. It won't let me do an up date. The new games the kids got for x-mas will not play with out the up date PLEASE HELP kids are vary upset.
Ensure you are using a broadband or high speed internet connection such as cable, DSL, or fiber optics. Slower connections, such as dial up, may cause issues with the Wii or may not work properly.
Ensure there is no interfering devices by shutting off microwaves, cordless phones, wireless keyboards, and wireless mice.
Disable your firewall settings, as it may be causing a connection problem.
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds. Be sure to test both channels to see which works better or faster.
If you are using a Netgear wireless router, disable the SPI firewall setting which is usually found under the WAN Settings of your wireless router.
If you are attempting to connect your Wii console online using the Nintendo Wireless (Wi-Fi) USB Connector and you receive this error.
To solve this error :
If your PC is using security features or programs such as a firewall, antivirus, or antispyware, check all settings of these security features or programs to allow a successful connection.
You may try adding the following programs to your firewall list of "Trusted" applications : Nintendo Wi-Fi Connector USB (NintendoWFCReg.exe), Setup.exe (when installing the USB Connector), SoftAPInstDrv.bin, mdriver.exe.
Temporarily disable your router's firewall which may allow the Wii console to connect online to recieve a system update. After, you may turn your firewall back on.
Hope it will help you.
Dec 27, 2010 | Computers & Internet
I am getting error message for win32 generic host data executor prevention
Here is my resolution to the error
SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR
IT DOES NOT INCLUDE
DISABLING WIA
OR
DISABLING DEP (which is a good security feature)
I have tried it on upto 3-4 computers with success and complete software functionality
Turn the All in One Off
Uninstall the whole of the HP software on the computer
Run a level 4 uninstall
Start --> Run -->X:\Util\CCC\Uninstall L1.bat
Start --> Run -->X:\Util\CCC\Uninstall L2.bat
Start --> Run -->X:\Util\CCC\Uninstall L3.bat
Start --> Run -->X:\Util\CCC\Uninstall L4.bat
Restart the computer
Check the computer on the restart
Check if you still get an SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR on restart
Start --> Run
Type in Msconfig
Click OK
Click Launch System Restore
Run System Restore
Create a Restore Point named Hp
Click Start --> Run
Type in Regedit
Click OK
Open Registry Editor
Scroll to the following Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentV
ersion\Explorer\
RemoteComputer\NameSpace\2227A280-3AEA-1069-A2DE-08002B30309D
Right click on this Key Click Export
On the Export Registry Window which comes up
Type Hpprinter as the filename and save it on the desktop
Get back to the same Registry Key
Right Click the Key and Click Delete to remove the key
THERE SHOULD BE NO DEP ERRORS THIS TIME
(IF you have any issues after deleting the above key <possibility is remote> restore the computer back to the Hp restore point)
Reinstall the Hp printer Wirelessly or on a wired network now the usual way
Once the software installation finishes
Verify functionality
NOW
Right-Click My Computer, then click Properties.
On the Advanced tab, under Performance, click Settings.
On the Data Execution Prevention tab
Click Turn on DEP for all programs and services except those I select to select the OptOut policy, and then click Add to add the following programs
Create an exception in the DEP for the following programs by browsing to the correct location. The following list outlines the locations:
Hpcmpmgr.exe (x:\Program Files\HP\Hpcoretech\hpcmpmgr.exe)
HPwuSchd2.exe (x:\Program Files\HP\HP Software Update\hpwuSchd2.exe)
HP Digital Imaging Monitor (hpqtra08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe)
HP Image Zone Fast Start (hpqthb08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe)
Generic Host Process for Win32(svchost.exe)
(c:\windows\system32\svchost.exe)
Add all these files one by one by browsing to the locations
Click Apply and OK
Let the computer restart if prompted
Its also at times needed to disable
from the Startup of the computer in Msconfig
Hpcmpmgr.exe
HPwuSchd2.exe
The reason is the above mentioned exceptions to the Data Execution Prevention are loaded after the Startup loads and the DEP may try to shut them down at the startup itself and generate the errors
Unchecking the above files does not mean losing any functionality on the All in One all the features should work properly
Jan 21, 2010 | Dell Inspiron 6000 Notebook
I am trying to uninstall webroot spysweeper with antivirus but cant find it to remove it, what should i do?
Under normal circumstances, like any other Anti-Malware software, Webroot will protect itself. You cannot randomly shut down its service. You cannot use most external uninstallers.
Always try to uninstall it using Add & Remove Programs first (on XP) or Programs and Features (In Vista and 7), or the uninstall link in All Programs on your start menu.
If you are not able to find it in any of these places, get the official cleanup utility from Webroot directly at:
http://download.webroot.com/SSCCleanup.exe
This utility is made to cleanly shut down and clean up Webroot SpySweeper, Antivirus, and Internet Security Essentials and will even remove itself when it's done.
Dec 21, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Hello fello fixya experts my expert utility was working just fine untill today i tried to log into it it and this is what it said an unhandled exception has occured in your application if you click...
Yes this problem has been resolved
i had the windows enterprise suit pop up on the computer just before this had happned and it was conflicting several of my programs I couldnt even run any type of scan so i forwarded the problems to my hewitt packard live team and they ran a scan using malwarebytes and got rid of a rouge virus and several other viruses that had attached to several programs they originated from google search engines is what hp told me and my fireforx never even caught it but any way i am now virus free and good to go and my expert utility is now working great
Oct 29, 2009 | Computers & Internet
Error 1316 occurred while down loading adobe 9.1 what is wrong. Wiil not let me down load any registry fix.
Hi upperroom50,
This message usually means a previous installation of a software is getting in the way of the new installation. It's kinda nutty that this would cause a problem, but we live in a nutty world. The fix is to download a free program from Microsoft that will totally and completely remove the old software. Then the new version can load unimpeded.
1. Download: Microsoft Windows Installer Cleanup Utility
2. Choose Save file option in the popup dialogue box
3. A File by name Msicuu.exe will be downloaded on your system
4. Run the Msicuu.exe application. This will install the program.
5. Run the Windows Installer CleanUp Utility file you just loaded (Start > All Programs > Windows Install Clean Up or C:\Program Files\Windows Installer Clean Up double click msicuu.exe
6. You will see window listing various applications.
7. Select the offending program, then click Remove. You'll see the warning box, select OK. The utility will remove all the parts of the program from your computer.
8. Restart your computer, then try loading the new version of the software.
Good Luck, and don't forget to leave a rating,
Thanks
Mark
Sep 17, 2009 | Microsoft Windows Vista Ultimate Edition
Get fatal error message after installationof
Make sure that your firewall program is shut down before installing the programs. I have hp program on mine and after I shut down my firewall it went through. Try downloading the latest software from www.hp.com
Aug 18, 2009 | HP Office Equipment & Supplies
My Fixya expert utility doesn't work. Error
Download and install the .NET Framework from this link : http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en
A quick Google search tells me this error means you are running .NET programs without having it installed. Surf to Windows update and patch .NET layer to your system. Horizons requires at least version 1.1 I think.
Jun 19, 2009 | FixYa Service
Fatal Error Application comes on when turning on the GPS
The problem i,m having is All the routes i have taken have Now a Permanent Orange Heavy Line and i can not identify any Roads on my Navigation 4000
Feb 03, 2009 | GPS
Geetting an Error : Rundll32.exe
RUNDLL32 is the Microsoft Windows program that loads DLLs into memory so
that they can be used by specific programs or by Windows. This behavior
could be associated with a programs not responding properly or is associated
with spyware programs and viruses. Anti-virus software and firewalls do not
fully protect your system against the majority of spyware and privacy
threats. Spyware is commonly bundled with software downloads, attached to
e-mails, or transmitted through networks so it can appear to be legitimate
software, but once installed it can be nearly impossible to detect and
remove without the help of a dedicated spyware removal tool such as:
Ad-Aware 6.0 (build 6.181)
http://www.lavasoftusa.com
SpyBot 1.3
http://www.safer-networking.org/
SpyWare Blaster
http://www.javacoolsoftware.com/spywareblaster.html/
HiJackThis
http://www.spychecker.com/program/hijackthis.html
Please make sure that you download the updates for each of these programs to
ensure complete detection of known spyware programs. Although nothing is
absolute in removing spyware and keeping it off, downloading and executing
the programs above can dramically decrease future infections.
Also please utilize free virus scans from the following sites:
Trend Micro
http://www.trend.com
Bit Defender
http://www.bitdefender.com
Panda
http://www.pandasoftware.com/
McAfee
http://www.vil.nai.com/vil/stinger
After Spyware / Adware is remove, you may get an error finding files on
reboot
After you use anyone of these programs (with the exception of HiJackThis)
you may receive an error of some sort after rebooting your system. This is
pretty common. Many spyware programs add themselves in the Startup location
and execute when Windows boots. If you recieve an error when rebooting after
removing spyware, do not panic. This is more than likely a startup remnant
trying to access the spyware program that is no longer on your computer.
HiJackThis is a great utility to find and remove these startup remnants.
However, there is a less technical way of removing these items:
(1) Click START to RUN and type: msconfig
(2) Select the STARTUP tab
(3) Uncheck the file that pertained to the startup error message you
received
(4) Click APPLY and OK
(5) Reboot your system
If this fails to fix the startup error message after reboot, there are still
options:
(1) Navigate to C:\Documents and Settings\All Users\Start
Menu\Programs\Startup
(2) Delete the icon that pertained to the startup error message you received
(3) Navigate to C:\Documents and Settings\username\Start
(4) Delete the icon that pertained to the startup error message you received
Jan 23, 2009 | Microsoft Windows XP Professional With...
FixYa Service Logo
Top FixYa Computers & Internet Experts
Mark Magill
Mark Magill
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
