Question about Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio
HOLA NO POWER IN THE CB RADIO UNIDEN
  • james morgan May 11, 2010
    tell me more about the radio. besure to tell if the radio ever worked. if it was polarity reversed (hooked uo backwards). Ineed more info as to why it does not come on.
  • Rob
    Rob May 11, 2010
    Hola!
    Would you list the make and model of your CB?
    Gracias,
    Rob
One Wire
  • 126 Answers
SOURCE: power was reversed now radio keeps bowing fuse and will not come on
Most cb radios have protection diodes that are made to burn out to save the radio in this situation. Usually you can replace them with a rectier diode between 1n4004 and 1n4008. They can be purchased at Radio Shack, or if you need more stuff, you can get them from Parts Express. This unit is the same as a cobra 29. If the pc board layout and numbering is the same, then the protection diode number is D23, which is located in front of the pa speaker jack on the main pcb. If you need more help, feel free to email me at rollincbmods@yahoo.com.
Dean
Rollin CBs
Posted on Jan 26, 2008
Mechanic688
  • 204 Answers
SOURCE: trying wire a superstar dm-452
Hello bubba, the wiring code for the radio is
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
If this is the power /echo mic like it looks to be from the Workman catalog, then I can't remember what the wiring code is for the mic. I do know, that the audio wire has the ground/shield wire wrapped around it.Could be just about any color. Put the shield on pin 1 and the audio wire on pin 2 and all you have left should be 2 more. If you get it backwards, then the radio will key up as soon as you turn it on. You'll have to key it to hear the speaker. Just reverse the 2 on pins 3-4. Hope this helps as it's been over a year since I've seen one. Let me know,,, Mechanic
Posted on Nov 05, 2008
SOURCE: UNIDEN UH-011 UHF CB RADIO
i have just printed off a hard copy of this manual it was on Http//.www.uniden.com.au/ RESOUCES main/pdf/uh011.pdf If that isnt helpfull i could post it out to you.
Posted on Aug 09, 2009
Benimur
  • 6966 Answers
SOURCE: CB Radio
Hi and welcome to FixYa,
Have you tried VR5? Not much on the mods other than adjusting L8-10 for AM power.
Good luck and thank you for asking FixYa.
Posted on Aug 15, 2009
tbirdfan1
  • 3051 Answers
SOURCE: old uniden cb radio. i have plugged it in and i
Hello there
There is a internal fuse on the inside of the unit that might need to be replaced and also check the fuse that is in the power cord ok?
best regards michel
Posted on Sep 14, 2009
CB Uniden 4-wire mic to a Uniden 510 radio how to wire color codes please
look up microphone wiring diagram for your cb and mic. more than one way to wire, depending on mic and cb having 4 or 5 on plug end. write down mic numbers and cb plug numbers. if audio on mic is 3 and cb is 4 put 3 on 4 pin check each wire. using power mic make sure red and black wire are on the right pin, can damage radio or mic or both.
Feb 11, 2018 | Uniden Radio Communications
Where can I get a Circuit Diagram for a Uniden UHF 012sx UHF CB Radio?
The only place you would get that is from Uniden themselves.
UHO12SX Manual - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH012.PDF
UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Features. 2. Preventative Maintenance. 2. Troubleshooting. 2. Controls/Connectors. 3. Missing: diagram ‎012sx
[PDF]UH8060NB - Uniden
https://www.uniden.com.au/RESOURCES_MAIN/pdfs/UH_8060NB_OM.pdf Operating the UHF CB Radio in Duplex Mode. 17. Scanning ... The Uniden UH8060NB is designed to provide you with years of trouble ... Built-in AVS Circuitry†.
[PDF]UHO12SX Manual.cdr - Uniden
https://www.uniden.com.au/RESOURCES.../uhO12SX_OM_2yrWarranty-Updated.pd... UNIDEN Model uh012sx UHF CB Radio. Contents. Introduction. 2. Controls/Connectors. 3. Indicators. 4. Included with your uh012sx. 5. Operation. UHF CB ...Missing: circuit ‎diagram ‎012sx
Circuit Diagram for Uniden UHF 012sx Google Search
Mar 19, 2017 | Uniden Radio Communications
Where do I find the power level adjustment for a uniden PC787 cb radio
I haven't look inside but I would say they are probably located in the same spot as the 29 lx
Feb 19, 2015 | Uniden Radio Communications
Customer has lost his power supply cord. where can he purchase another cord. power cord is three prongs.
  • Hi, I can help.
  • For the Radio Shack TRC-447 this is just a standard 3 PIN DC cord. Many CB's use the same cord and they are interchangeable. Some Cobra, Uniden, Radio Shack use the same cord. Texxcomm is a great place to get parts from.
  • If you have any coimmments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 07, 2011 | Radio Shack TRC-447 CB Radio
How to turn the power down uniden pro 520 xl
For this radio you adjust power through coils in the back of the radio. Using a watt meter and a plastic screw driver push coils L201 and L202 together and the power output will decrease. If D203 (modulation limiter) has been removed you can replace that as well. This should get you fixed up. Good luck.
Jan 10, 2011 | Uniden PRO520XL 40-Channels Base CB Radio
I have a uniden pc66xl phillipines cb it has smoke coming from a red transformer in the back right next to the power input at least i think its a transformer
you will need a now one. You can contact Uniden at 1-800-554-3988. that is their parts department. Don't try to run the radio till you replace it, or you could cause more damage.
Feb 27, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
I have a uniden pc68ltw cb radio and it keeps blowing the 2amp in line fuse i tried a 5amp but still blows the fuse.i hooked it into another truck to test it but still blew the fuse. something wrong with...
have you been using the uniden pc68ltw cb radio without the fuse blowing before?
If the uniden pc68ltw cb radio has not been blowing fuse before, then might be a problem from the radio. This problem should be a power related problem.
The fuse blowing means there is excess of current. So while your trying to refuse, thicken the wire.
Best regards.
Feb 23, 2010 | Uniden Radio Communications
TWO TRANSISTOR IN THE RF OUTPUT STAGES ARE MISSING.....TYPE? CIRCUIT DIAGRAM? PRO 501 XL.THANK YOU
Hola santipatag!
I have found two schematic diagrams that are very close to your radio. one is a lessor model and the next is one that is a bit fancier than yours. I would think the output stages would be about the same with maybe a SWR sense function.
Please email me and I will return the diagrams directly to you..... Here is my email
poikaa@yahoo.com
Hasta Luego mi amigo! Rod KB8DNS
Feb 19, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden 520xl makes humming noise when mike is keyed
if you have a power mic , you might have it turned up to high. next make sure you have a good ground on your antenna. if that is ok and you still have the same problem have the swr checked. this should fix the fm radio noise.
Apr 10, 2009 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden washington base station
I need the wireing information for uniden washington CB radio,thank you.
Oct 28, 2008 | Uniden PC78ELITE 40-Channels Base CB Radio
Uniden Bearcat Pro PC68XL 40-Channels Base CB Radio Logo
44 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
