Question about GE GSS20IEP Side by Side Refrigerator
I have the same problem as most. I have a GE
I have the same problem as most. I have a GE GSS201EPA. My problem started with a power outage. Everything worked fine for about 24 hours. There are no indication of shorting out, but frig is warm and freezer won't freeze ice. I have ice in bottom of frig and frost built up in back of freezer. HELP!!! This was the third outage in two months. I'm tired of buying food I can't eat. I can't afford major repairs.
  • 93 Answers
Its sound like your defrost timer is not working a fridge should defrost every 8 hours replace your defrost timer leave your door open to defrost all the ice buld up the timer shoul be located in the back lower where the compressor is located it about 3 sqare inch normally black with a small motor on or some are white in coulours thanks from gilles
Posted on Mar 15, 2009
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 | GE Ovens
AFTER POWER OUTAGE MY GE DEEP FREEZER WONT COME ON
Hi
First check there is power to the unit and the trips and fuses are all OK
If so then unplug the unit for around 24 hours, then switch on and listen, you should hear the compressor start up ( a low buzzing sound), however if then you hear a click and it goes quiet the compressor is probably faulty. This happens often after a power outage which can produce a voltage surge.
Regards
Gordon
Apr 24, 2011 | GE Refrigerators
After a power outage my dishwasher has a "Er" code. I downloaded the manual and it says nothing about that specific code. Please help! "Er" code GE Profile Dishwasher GSD4930X66WW
the er means error. you may have a damaged control from the power outage. try to turn the power off to the unit for 30 min then put it back on. see if it resets it.
Jan 10, 2011 | GE Dishwashers
GE refrigerator pfss6pkwbss flashing 88 82 after a brief power outage...any info on how to resolve?
Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel! I was told by both GE and a local repair service that I had to replace the entire control panel...what a RACKET!! GE needs to start telling people this trick when they call in with this error...it will come up every time there is a power outage.
Nov 23, 2010 | Refrigerators
Clicking noise after power outage
If you had a clicking noise about once a minute for 3 to 5 times, then unit worked fine, you have no problem, it was just letting the pressure equalize in the system before the compressor could restart. (this happens if you had a very short power outage).
If you are getting many clicks and compressor is not starting, you will have to replace the motherboard.
May 27, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
GE refrigerator not cooling after power outage
It sounds like the main control board is bad . After looking up the board , it is on a recall lisr by GE . You should call GE and have them come and check it .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
Nov 02, 2009 | GE Refrigerators
Ge profile arctica
It is unlikely that a power outage by itself will cause your problem. Recheck hour refrigerator thermostat. It should regulate to 38-42 degrees F. You can take an outdoor thermometer and put it into the fridge compartment, leave it for an hour or two and check. Adjust as necessary. If that doesn't fix it, we can proceed further.
Jan 23, 2008 | GE Profile PFS22 33" Artica French Door...
GE GSS20IEP Side by Side Refrigerator Logo
321 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
