Switch broke and we can not find the correct one
SOURCE: chain broke on jin you
Try following link, without guarantee: It has same number but says 4 wires
http://www.allelectronics.com/make-a-store/item/PSW-14/PULL-CHAIN-SWITCH/1.html
You posted under Westinghouse:
http://www.atlantalightbulbs.com/ecart/catalog/westinghouse-6.html
Internet search does not show 5-wire switch, they are either 3 or 4 wire.
Maybe you have older fan, or maybe the switch can be replaced with 4 wire.
Next step would be to test your wires to see if 4-wire conversion can be made:
Determine which wire is hot if possible.
Take photo of wires and then remove switch.
Use multimeter set to read ohms, and test between each wire and the wire you labeled hot wire.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
SOURCE: Old fan switch has 4
You have 2 questions:
1) Pull-chain Switch question:
You need a fan switch with 4 wires.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=202191016&langId=-1&catalogId=10053&PID=500871&cm_mmc=CJ-_-500871-_-10368321&cpncode=00-29062147-2&AID=10368321&cj=true&srccode=cii_9324560&locStoreNum=577
Your pull-chain switch has one wire that connects to Hot from wall switch. And then one wire for each of the 3 speeds.
Best way to start is to test the old switch with continuity tester.
Compare results with following image of 3-wire switch for general reference:
http://waterheatertimer.org/images/Fan-motor-1-500.jpg
2) Ceiling fan pull chain switch is for the fan only.
Pull Chain on Bottom
L 1 2 3
Upper Yellow Jumper Pink Grey
Lower Orange - Jumper Black
Santa E70469
SwitchCo part # 01
or
KensElectronics.com part # ZE-208D-01
