Question about HP Pavilion dv6000z Notebook
I have had spooler problems and lost the HP Solutions Center.
I uninstalled and reinstalled the printer among other things. I got it to print this afternoon. This evening I tried to open the solutions center to try the scanner and align the print heads. I get a response that indicates ther are no HP products. The Photo Center iand Library are there so I am confused. I have spent many hours trying to get an assignment done and printed. Three clues: 1.I use Adobe Pagemaker 7.0.2and Photoshop V. 2. This is a new laptop loaded with Windows Vista. 3. Is is also loaded with Norton 360.
Thanks for the help I have xp on my computer, and was using my printer just fine. I went to print, and was told that my computer and printer could not communicate. Since this is a wireless set up, I thought I needed to uninstall and reinstall, except my computer will not allow me to reinstall due to a printer spool error. What can I do to fix this?
    Problem Solver:
  • 13 Answers
I had many simular issues with my laptop, then it shut off one day and wouldn't come bacl on, after digging through tons of support forums on HP's support page I found that a know bios issue exists for this model laptop. As long as its still running down load the latest bios and flash the laptop. Let me know if this helps
Posted on Mar 05, 2009
Cannot connect with hp printer. a red x appears and says that there is a problem with print spooler
Click Start, Devices and Printers, right click on the Pro 8500a icon for your printer. CLick Properties. From there, click the Advanced tab and choose "Print directly to the printer". Click Apply and OK. From there try printing again.
Report if this works.
Feb 11, 2013 | HP Office Equipment & Supplies
I want TTFSUB. GPD files for HP 1100 A
That's the print spooler files for your printer. Just uninstall the printer and reinstall the print drivers using the included software.
1) Go into Control Panel~Device Manager (Devices and Printers in Win 7)~right click on the HP printer and left click on Remove Device. 2) Reinstall the printer using the HP software that was included with the printer or go to the HP web site to download the software if you have lost the original disk.
That should do it.
May 19, 2011 | HP LaserJet 1100 Printer
Hp OfficeJet 5610 All-In-One
Try uninstalling printer software and reinstalling it...if it not work..check whether print spooler service is on or off in on start run...type down in the box -services.msc and check the print spooler services..
Jun 17, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer spooler not running/HPPhotosmartEssential.msi problem
printer you have to frequently , if the spooler problem u are getting you have put the printer on service center for once clean entire printer properly
May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
I'm not sure exactly what you have tried yet, but maybe type in Services in the Vista search box and open Services. Scroll down to Print Spooler and right click on it. Restart the Spooler Service.
Also, many people have had scanning problems when using all-in-one software in Vista. I usually recommend this:
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (eg HP C3180) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 13, 2009 | HP C7200-69016 Network Adapter
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
Incompatible ink cartridge(s) ERROR on HP 4230 All-in-on printer
Try uninstalling and reinstalling the drivers. This can be done by going to the Add and Remove programs, this is located under the Control Panel. You may have to reboot and I would recommend that you do. This will clear out the Print Spooler. The Print Spooler is located under the C Drive and may get corrupted. You can find information about this in Google. Look for repairing spooler on the OS that you are using.
Dec 26, 2008 | HP Officejet 5610 All-In-One InkJet...
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
Spooler crashes when printing random PDF's
Installing new drivers dind't help. But what I did is I checked print as an image from within pring options in Adobe Acrobat (you gotta go to "advanced" to find that check box), and then it worked.
Feb 05, 2008 | HP LaserJet 1022 Printer
HP Pavilion dv6000z Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
