Question about JVC HD-56G786 56" Rear Projection HDTV
Closed caption how do I get the closed caption off of my jvc 56g786 tv
  • 8,197 Answers
Here is the manual for your tv. On page 51 it will tell you how to turn on and off the CC.
http://server4.nodevice.com/downloads/4e1fdaec439e1d8864e7377154b583f4/hd-52g786.pdf
Good Luck and Please Rate FixYa!
Posted on Mar 05, 2009
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
May 05, 2011 | JVC HD-56G786 56" Rear Projection HDTV
We accidentally hit some button on the control that made a big black square come over all our channels. We have tried everything and cannot get this off. We realize it is locked and have tried changing...
Hello
Closed Caption function is set to On in your JVC. look if there any button marked as "CC" on its remote control. If it is there, hit it till the closed caption function go off from your tv screen. If there is no such button found, get into its menu option, surf through, and get in to the closed caption option, set the close caption function OFF in that window. OK.
Apr 11, 2011 | JVC AV-32D502 32" TV
I have a JCC AV-32D305 television. I use Direct TV and the TV remote has disappeared. And since the closed captioning is on, I get the "box" in the middle of the screen and it cannot be turned off with...
Unfortunately JVC had closed caption buttons on the remote and that is the only way to change the CC settings. Go to www.remotes.com and check to see if they have a remote for your set. Thanks
Nov 01, 2009 | JVC AV-32D305 32" TV
My 36 inch jvc 4:3 tv has a black box covering most of the screen
Well this happened for my tv aswell its usually a closed captioning setting if u press ur closed captioning button a few times it will go back to normal
Oct 05, 2009 | JVC Televison & Video
HDMI broken on JVC HD-56G786 TV
have you ever went thru your hdmi setup procedure that jvc recommends?
Sep 07, 2009 | JVC HD-56G786 56" Rear Projection HDTV
How to remove closed caption from JVC TV without original remote
how can i get rid of the closed caption on my magnavox tv without the original remote
Mar 19, 2009 | JVC C-20810 TV
Turning on closed captioning
Some older telivisions don't have the option hoever caption with always be under the menu. Or if your playing a DVd then under the language set up.
Feb 12, 2009 | JVC AV-20220 TV
Line on my 56g786
can you see lines over your menus? if so, replace light engine.
May 17, 2007 | JVC HD-56G786 56" Rear Projection HDTV
Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Apr 10, 2007 | JVC AV-32F704 32" TV
JVC HD-56G786 56" Rear Projection HDTV Logo
151 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
