Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Hayward H300 Spa Heater will not fire up
I have a Hayward H300 spa heater that will not fire. I get an error code of SF and HS. I just had this serviced 2-3 months ago and it worked fine twice. Any ideas on how to fix this? Thanks!
  • Anonymous Mar 19, 2014
    got spark and the gas is on,it fired up once then thur a ILC code
Try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Posted on Jun 13, 2009
What does this mean Hayward pool heater h150FDN gives us an hs or h5 error?
HS = High Limit Sensor
Heaters Maximum Water Temperature has been Exceeded.
A few reasons this occurs...
  • Low water flow thru heater, check :
    • Dirty Filter
    • Opened By Pass Valves
    • Plugged pump impeller
    • Dirty/Full baskets at skimmer or pump
    • Anything that may reduce water flow
  • Sensor could actually be doing its job, in a different aspect, Thermostat failure, and water is overheating in spa or pool?
But anyway, your heaters fault code you asked about is: hs, not h5
May 17, 2014 | Hayward Pool & Spa
Hayward h200 pool heater (LO) Error code
check gas pressure sounds like gas meter is too small
Jul 12, 2013 | Hayward H-series Electronic Gas Pool...
Where is the temp sensor on a Hayward H300 ED2 pool heater
take off top there is a copper wired unit going into header and wire to the board
Sep 18, 2012 | Hayward H-series Electronic Gas Pool...
Error code HS on hayward heater H400FDN
check the fusible link if blown check gas pressure
Jan 28, 2012 | Hayward H400FDN Low NOx Natural Gas Pool...
CODE SF CURRENTLY DISPLAYED ON LED / CLEANED 2 SENSORS ON EXTERNAL PLUMBING,SAME CODE. LOOKING FOR LOCATION OF TEMP.SENSOR?
The code SF indicates there is either a bad temperature sensor or the input to heater is faulty. I would buy a temperature sensor from a pool supply suppilier and install it. That solution has a very high likelihood of being successful. If you have a few tools and a little mechanical ability installation should be easy. I hope this helps
Aug 13, 2011 | Hayward H-series Electronic Gas Pool...
Haywood heater has code sf what does that mean
SF is a thermistor error. Once the heater cools down it should reset itself. If not, call a service tech.
Jul 03, 2010 | Hayward H Series Pool & Spa Heater 400k...
When I turn on my pool ,the heater wont turn on.
clean the filter turn breakers off for twenty secons
Sep 06, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H300 heater runs but will not heat water
Your internal by-pass could be stuck open or the disc could be worn to the point of letting water pass too fast. Or your thermal control valve could be stuck open. These are both found in your water header going into the heater. Hope this helps, good luck.
Jul 02, 2009 | Hayward 100,000 Btu Heater For Ag Pool And...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
865 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
