Question about Califone International 1030AV Turntable
Califone 1420 k "Wobbling sound"
I have a califone 1420k and I've realized that is not uncommon for them to have a "wobbling" sound. Like the speed is moving up and down. It causes the music to sound out of tune. Does anyone have a solution for this?
Please!
  • 3 Answers
If you take the platter off you may find a rubber "idler wheel" that rides on the inside rim of the platter. It may be worn or glazed over and hardened. Might try cleaning with denatured alcohol. If that doesnt work you may need a new idler wheel. West Tech Services is a place that comes to mind that may carry what you need.
Posted on Aug 09, 2009
  • foxyea Nov 29, 2010
    Great tip! I have a Califone International 1925. Its in great shape, but started to get that wobbly sound. Platter removal was pretty straight forward; Removed the metal C clip on the spindle, and lifted off the platter. The Idler wheel is the only rubber component. Mine was in good shape, I used a q-tip with some isopropyl Alcohol and cleaned a lot of dark build up off the wheel. Replaced the platter, and now its holding speed. Thanks again.
Califone 1435k This record player from the 70s runs great and came highly recommended but the 33 records we're trying to play are sounding much too fast. Any ideas on how to fix this?
This is an idler wheel drive turntable that uses a small rubber wheel, that when engaged pushes on the motor spindle and also on the rim on the underside of the platter. The spindle on the motor is stepped so as you shift speed the idler wheel moves up or down the spindle and that changes the speed of the platter. It could be the the shifting mechanism is dodgy You can try to loosen it by gently shifting the speed from 78 to 16 and back again. But the idler wheel rubber might be in trouble too.
Dec 29, 2016 | Califone International Audio Players &...
Platter not spinning
Some turntables only move when you move the arm to the record. If that doesn't work and you have read the set up instructions correctly, as it's new contact the maker or the place you purchased it from. I'm certain they will help.
Mar 22, 2014 | Califone International Audio Players &...
Califone 1875 turntable
Ask them what the part is they can't get and report it back here. Fixya experts like myself sometimes can track them down.
Feb 26, 2014 | Califone International Audio Players &...
Califone 1420 k speed fluctuation
Take the turntable off by removing the "E" clip on the top center of the turntable. You can then oil the motor, lube and check the main turntable bearing and most important, clean, lube and adjust the idler wheel. The rubber tire on the wheel can be cleaned with alcohol or rubber cleaner and this will fix most speed problems. The height of the wheel can be adjusted by changing the fiber washers and of course the wheel bearing should be greased.
Aug 09, 2013 | Califone International 1030AV Turntable
Have a new Califone "boom box" with radio, CD
there are two power buttons. one on the top left, and front face upper left pwr/standby button red - off green - on.
Jan 08, 2011 | Califone International 2455CAC...
I have a Califone 1620 model economy classroom phonograph in need
Probably a bad relay switch. Open up the turntable. Identify the motor that spins the table. Follow the wires of that motor to, perhaps, some type of little circuit board with a relay. I have a Backley-Cardy 322-487 classroom phonograph which uses a Califone 1620 amp and a BSR turntable. To get the table to spin, you have to move the tone arm. Mine doesn't move and I'm in the process of replacing the faulty relay that is the problem.
Sep 30, 2009 | Califone International 1030AV Turntable
PA 716 PowerPro will not come on, no sound or anything at all
http://www.califone.com/search.php?zoom_query=PA&zoom_page=1&zoom_per_page=10&zoom_cat=-1&zoom_and=0&zoom_sort=0 Try Support at this site. Icouldn't find a 716 but that doesn't mean there isn't one.
Jul 28, 2009 | Califone International Califone PA-716B...
Adjust pitch on a Califone turntable.
This one is actually fastened from underneath (inside). You need to open the player up and you will see the usual C shaped fastener on a cleat near the motor assembly. Most old direct drive record players have a C pin around the spindle that you can unfasten (pry with a twist) with a screwdriver. Irealize you figured this out yourself, but I'll take the guess work out for someone else... yeah..l you gotta take it apart!
Feb 15, 2009 | Califone International 1030AV Turntable
Califone dvd/vcr 200
Hi, you can download the manual from the site given below:
www.retrevo.com/s/Califone-DVDVCR200-DVD-Players-review-manual/id/540dj397/t/1-2/
Hope my info solves your problem, Thanx for using fixya, Good luck.
Sep 29, 2008 | Califone International DVDVCR200 DVD...
Ax-12 computer mic
The Califone AX-12 has a 3.5mm connector on the cord. This should plug into the sound card on your computer... usually found on the back of the computer in the same general area that the speakers plug in.
Jul 14, 2008 | Califone International (AX-12) Consumer...
Califone International 1030AV Turntable Logo
1,368 people viewed this question
Top Califone International Audio Players & Recorders Experts
Michael Galve
Michael Galve
Michial Gueffroy
Ben Armstrong
Are you a Califone International Audio Player and Recorder Expert? Answer questions, earn points and help others
