I was traveling and apparently had a power surge in the Motel. After checking and talking to HP, concluded that the motherboard was blown. I replaced the motherboard but did not have any video. I found, however, that I had video when I hooked up to an external monitor. I replaced the inverter, cable, and then the screen and still no video (actually the ebay supplier sent another screen when the first one didn't work). Any other ideas of what I might try?? Thanks for your help. Darrell
  • Jay Selway
    Jay Selway May 11, 2010
    Was the replacement motherboard new, or a second hand spare?
    Make sure the connections from the board to the screen and inverter are all secure, and also that the cable from the board up through the hinge is not worn , as this would also lead to a failure of the screen.
  • 3,051 Answers
Hi there
hey when you replaced the mother board are u sure that it is compatable with the screen that the person sent you
Posted on Mar 05, 2009
  • 52 Answers
If i were you i would go get a new laptop. Sounds like something is shorting out on the motherboard. like metal touching the case.
Pioneer av no hdmi output after power surge
internal fuse was blown check motherboard if you know how to open panel if niot take to technician
Feb 26, 2014 | Pioneer VSX-821-K - 5.1 Channel A/V Home...
Hitachi hd 1080 tv
its seem to be a surge apparently at one time tv had gotten a voltage spike may have blown the fuse in the power supply or main board.
Aug 12, 2013 | Televison & Video
My monitor doesn't go on anymore. Las night I had a pop-up appearing on the screen. I closed my computer and started over again. I'm sure I didn't turn off my monitor. Everything went well until this...
First, check to make sure the power cable is plugged properly in the back of the monitor and into the surge protector. You can try a different power outlet, but if you're still having the same problem and the light isn't turning on, it's likely you've either blown the fuse inside the monitor, or you had a power surge and blown something inside the monitor. This happens when you don't use a surge protector and just plug the monitor into the wall.
That said, if the above doesn't work then you have a hardware problem with your monitor and it needs to be serviced.
Jan 11, 2011 | Computers & Internet
HP Compaq laptop won't charge/power from AC due to blown fuse
First of all there are no fuses in a pc's motherboard, whatever the type.
In your picture the apparently faulty part is a filtration coil (L1 - the L refers to an impedance/coil) situated on the power like coming from the Jack1  - where the charger plugs in.
If your laptop :
1 - works just fine with a battery
2 - doesn't power on when plugged in the mains and without without the battery
3 - doesn't charges the battery
then , since the charger is good, the power circuit is cut after the the plug-in power jack, on the motherboard.
Use an ohmmeter to test the power circuit for continuity, starting from the jack.
So yes your busted impedance is most likely the failed part. Jumping it would fix it, but will leave the laptop without any protection against parasites coming thru the power line - use it from now on only plugged thru a surge protector at least an off line UPS at best.
Jun 03, 2010 | Intel Motherboard
I have just a new computer and when I turned on for the first time, it power up but no image on the monitor, I have checked the connection and tested the monitor on laptop and it works, it conclude that...
first check u ram seated correctly or not and verify u hear the boot sound or not.disconnect all ur connection to the motherboard and reconnect finally then check it
Nov 04, 2009 | Intel D945GCCR Motherboard
I have an HP all in one C6180. I had a power
Check the power pack of the printer the surge must have damaged the power pack,check for blown fuse on the power pack that connects to the wall or replace the power pack with another one.hope this will help you
Oct 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Power failer
You need to check the voltage on the power adapter. If it checks out, you will need to call HP because this is an issue that is typically caused by power surge and motherboard replacement is usually the solution.
Jul 15, 2009 | HP 413670-001 - HP Compaq nc6320, nx6310,...
We had lightening strike, power surge.
if the problem is not turned worse then the motherboard can be repaired easily.also the modem if faulty can be repaired or replaced as it wont cost much.but yes it is necessary for a technician to manually diagnose this to see the current state of mother board.
thanks.
Jul 08, 2009 | Dell (8N816) Motherboard
My computer does not boot
Actually, what happened here is a power surge. It happens to Intel mobos more than most, apparently. You're going to have to replace it. If you're lucky the mobo is still under warranty.
Nov 26, 2008 | Intel DG33BU G33 Express Socket 775 mATX...
Power problem
The Printer unable to turn on could be of two reasons.
(1) Connect the Printer directly to the wall outlet instead of connecting through the power surge protector (If connected through surge protector).
(2) Check whether the Power adapter is getting warmed up after connecting to a particular wall outlet.
(3) Try connecting the printer to any other wall outlet and check for the results.
Hope this information would help you in this regard.
With regards,
Ashesburn.
Feb 14, 2008 | HP DeskJet F380 All-In-One Printer
Computers & Internet Logo
David Payne
David Payne
