Question about Canon PowerShot A630 Digital Camera
Dropped the Powershot A630 camera - still works (LUCKY). However, need to use rubbers bands to secure the battery cover as front cover latch will not fasten (tab broke). Bought front cover and need guidance on disassembly and tips to replace it.
  • nr95 Apr 19, 2009
    daniellouie1,
    I just dropped my camera and have the same problem... but I don't know where to buy a new cover for the battery compartment. Can you help?
    Novelist:
  • 98 Answers
So get ready with your screw driver.
I am posting a link below... will give you an idea of how to disassemble a A650... The assembly will of course be in the reverse direction.
Keep the screw carefully... You will only need to understand a part of the whole process.
http://heliodorj.blogspot.com/2008/05/disassembling-canon-powershot-a650.html
Please do rate this solution and thanks for using FixYa.
Posted on Mar 05, 2009
I don't know how to open the battery door for the
Slide the latch in the center of the battery cover toward the front of the lens, then flip open the cover. It's hinged toward the center of the body, so it flips open in that direction.
There's an illustration in the "Preparations" section of the Basic manual (page 5 in my copy). If you need manuals, you can download them from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a630#BrochuresAndManuals
Aug 11, 2011 | Canon PowerShot A630 Digital Camera
The latch for the battery cover on my Power Shot A720 IS is broken. Can it be fixed?
Probably not as the cause is most likely broken molded plastic parts that where to small and thin to last very long. Seems to be a common problem on this otherwise great pocket camera. Use tap or a rubber band to keep the battery cover closed so the contacts still work. Bad design by Canon.
Jan 03, 2011 | Canon PowerShot A720 IS Digital Camera
A630 will not power on. Says batteries are dead.
You have to clean your battery compartment contacts. To do this Dampen a Q-Tip swab with rubbing alcohol and clean the contacts well. Also you'll want to clean the battery and charger contacts as well. Thank you, Dana
Oct 05, 2009 | Canon PowerShot A630 Digital Camera
My battery cover is broken and the camera will not power on. Will the camera work without a battery cover?
Very often they won't as there are spring contacts onto the battery inside. The battery needs pressure to keep it in contact.
Aug 16, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Remove battery door of Canon A630
This is an old A70, but the way it's done is very similar as I don't think this has changed much over the years. It's a pin design that you have to push out with a stiff unbent paperclip. You push in on the side with the smaller hole. To access the pin you'll need to remove the front and back case covers. See the following:
http://blog.thustra.com/2007/03/canon-a70-ir-modification.html
Jun 19, 2009 | Canon PowerShot A540 Digital Camera
Canon lens cover won't open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 09, 2009 | Canon PowerShot A630 Digital Camera
Dead LCD after child was taking pictures, probably dropped or twisted LCD.
I have,
But shipping cost to much,
So i look for business partner in other country,now!
Aug 27, 2008 | Canon PowerShot A630 Digital Camera
Canon PowerShot A630 Digital Camera Logo
409 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
