Question about Grundfos RCP-96 Recirculation Pump for Tankless Water Heaters
3 speed Recirculation pump lost middle speed
I have a Wilo 3 speed recirculation pump for a heating system. The middle speed has quit. Wondering if it's just a simple fix, change a capacitor or something, or replace the pump. It still works on high speed.
  • danlawrence_ Mar 24, 2009
    Thank you. I already went and pulled the control off, tested and found a burnt winding. Ironically the other pump of 2 went the day after that on all speeds and the lady at the house described an incident with a surge. I replaced them both with Grundfos.
    Thanks again.
  • 659 Answers
It sounds like you might have had a power surge and burnt the windings on the medium speed. If it is bothersome, you will need to replace either the motor or the whole pump. (not sure if replacing just the motor is an option.)
Posted on Mar 20, 2009
Does anybody have a diagram for the flow of a back boiler pump
Did you install the pump so it flows in the correct direction? Check the arrows on the unit.
Dec 06, 2014 | Water Water Heaters
I have a Navien NR 240A tankless which has been in use for about a year. My only complaint is that when the internal recirculation pump turns on I can hear a waterflow or pump noise throughout the house...
Hi Bruce
No its not normal it shud b isolated by lagging the noise travels through the timber lagging between pipes will help also how old is the pump shud only b a hum if pump ok any more and u need to replace , also u mite like to check speed of pump mite b on max turn down so long ur flow is ok or ur system mite get to hot
Sep 17, 2013 | Water Heaters
Excess Hit Water Bill from Solar/electric Hot Water System
10-30-12
Cost calculations for recirculation system vary widely.
These systems cost more, and they cause higher operation cost of water heater.
1) When pump is OFF, then hot water is no longer leaving the tank.
Most recirculation systems have choice of timer for setting specific times of operation, or thermostatic operation that activates pump when sensor detects temperature less than 90 degrees
BUT...
2) Condition of plumbing is suspect here because you are not receiving fully 90 degree hot water from the recirculation system.?.
Bad single-handle faucet cartridge, or bad recirculation check valve, are causes of crossover. Clean recirculation check valve with white vinegar. Replace worn faucet cartridge.
Test for crossover.
http://waterheatertimer.org/Crossover.html
3) There are other suspects, such as water leak.
Drips, broken pipe, bad TP valve.
Turn off all taps and put ear against pipe to listen for running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
4) High costs: Lifting single-handle faucet in middle will immediately cause cold water to enter tank. Even if no hot arrives at tap, because the cartridge is drawing both hot and cold in equal amounts when handle is lifted in middle.
Today it is more efficient to install dual-handle faucets so tank is not receiving constant dose of cold water when single-handle faucet is not used correctly or tediously.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Oct 29, 2012 | Water Heaters
I have a laing cirulating pump thats is worhing but now making noise so i took it apart see nothing but it was hot when running so is there any thing i can do to fix before it burns out
Open following link for Re-circulation information and resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
If the unit is getting hot, it may have already slowed and is now spiraling to it end.
Try bleeding air out of water lines, and clean autocirc with CLR calcium lime and rust remover.
Recirculation systems have a built in check valve so cold water side of faucet will work correctly. If this check valve is stuck open or closed, it can affect a lot of things in the plumbing system.
For example, stuck check valve can cause tankless water heater not to operate. It can also cause autocirc pump to overheat.
Lines, or elbows clogged with sediment can also cause same problems with recirculation system. If your system has direct return line to water heater that connects into the water heater drain port, then clog in line can cause overheated pump. Check water flow, check water lines, and clean out autocirc.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on autocirc or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 22, 2010 | Laing Thermotech Autocirc Undersink...
Pump runs 5 minutes and stops
Move the slide switch to ON.
Open following link for recirculation system resources.
The recirculation can work on either the timer or the thermostat using slide switch located next to the timer dial.
First of all, look to see if dial is rotating as time passes.
Next look at position of slide switch. If switch is moved to 'timer,' then the timer controls the on-off function for pump.
Move the pins located on timer dial to control on-off times.
If the switch is moved to ON, then the thermostat controls the pump, and turns on until temperature in pipe reaches 94 or 100 degrees F approximately. I forget exact cutoff temp.
Upvote the help.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Oct 11, 2010 | Laing Thermotech Autocirc Undersink...
We have a robbens underfloor heating system with a heatrae electric boiler on a floating floor system. The underflooe heating manifold has a grundfos Alpha + pump. What setting should this be at? Currently...
Venting of the system is when you re circulate the water or cooling fluid in higher speed to eliminate the air bubbles from the system.
If water circulate on a too higher rate does not have time to dissipate the heat so your floor is cold.
You need to go to 2 or even 1 depending on the length of the heating coil in the floor. Unfortunately the pump only has 2 speeds (setting 1 and setting 2) so whoever install your system had to calculate the length of the pipe for maximum efficiency. Try on 2 and if not satisfactory go to setting 1. If too hot on setting 1 then you can adjust the heat by reducing the amount of water from the shut-off volume control. It is a hit and miss situation, I know but unfortunately that is the only choice remaining now after the system is installed.
Jan 10, 2010 | Grundfos RCP-96 Recirculation Pump for...
Wilo 3speed recirt pump for my wood stove
I wasn't aware that you would put a citculating pump on a tankless water heater, but as long as the arrow goes in the direction of the water flow that is how it needs to be,, putting a circulator on a tankless kind of goes against what it is for, the tankless will never shut off and once it is on how will it ever satisfy itself to shut down?
May 26, 2009 | Grundfos RCP-96 Recirculation Pump for...
Grundfos RCP-96 Recirculation Pump for Tankless Water Heaters Logo
199 people viewed this question
Top Grundfos Water Heaters Experts
Donni Steen
jdthefixer
Are you a Grundfos Water Heater Expert? Answer questions, earn points and help others
