Question about Lanzar SDBT75N Car DVD Player
How to hook up my rem amp wire to this player it does not have
It does not have a amp out put for my subs how do i hook it up then
If by saying amp outputs you are refering to the RCA jacks on back of the head unit (Left and Right RCA jacks usually labeled FRONT, REAR, SUB, etc...) then you do have options even if your head unit doesn't provide a SUB channel.  These RCA jacks/amp outputs carry the signal (music or whatever) at a lower voltage (and is typically more like DC voltage as there is a ground reference which is 0 volts and signal rides on the positive voltage), providing a cleaner signal to the amp which does all the work.  The wires behind the amp that you connect directly to the speakers is typically amplified by the head unit itself and is a much higher voltage level and varies from negative to positive ( AC voltage.).
You could use the other channels (FRONT or REAR) if available, (a specific SUB amp output cuts all the higher frequencies out, passing just the lower subwofer frequencies inside the head unit).
if you want to strive for a more efficient use of your sub, use a low-pass/SUBwoffer filter (a crossover) in between the Head unit and amp, thus providing the amp with subwoffer signal, (or if for some odd reason you have SPEAKER level sub connections you can use a line output converter which will let you run RCA to the amp.)
Hope this helps u understand why I couldn't just say get a new stereo nor could I just say use splitters on available amp outs.
Posted on Mar 05, 2009
Kenwood kdc mp228 now working with amp/subs
Hi, ensure amp has 12v on the "+" and "rem" terminals and has a good ground to the amp, This is all the amps needs to start up
May 05, 2010 | Kenwood KDC-MP228 CD Player
Stereo wont stay on and only couple speakers work
on the back of the stereo you should have an rca inputs in the back, it should say either rear, subwoofer, or non-fade. all of these are acceptable, run rca's to the amp from the deck.
also on the deck in the wire harness is a blue wire with a white stripe.
hook a wire up to this and run it to the REM. terminal of your amp. this wire tells the amp to turn on when you turn on your key.
these are the only two wires you hook up the back of the stereo.
hope this helps
Jan 07, 2010 | Sony Car Audio & Video
Kenwood KDC-135 remote wire
should be a solid blue wire
Jul 24, 2009 | Kenwood KDC-135 CD Player
Install kicker ix254 into a Land Rover Discovery
that wire probs is your rem wire hook it up and try er out john
Apr 19, 2009 | Kicker IX254 Car Audio Amplifier
No power to amp
you need to hook up the rem wire, that runs from head unit to amp its usaully a blue wire on the head unit and there should be a rem input near where the power leads are on the amp
Mar 21, 2009 | Kicker ZX400.1 Car Audio Amplifier
Sony output problem
All i did was mess with the REM wire, and found out i had to hook the REM wire to the blue/white wire on the deck. Instead of the blue/white wire, i had it hooked up to the solid blue wire on the deck which was preventing my amp from playing on CD.
Nov 22, 2008 | Sony TA-E9000ES Amplifier
Thunder 5604
okay u will have to troubleshoo the amp.....dose the amp light up?...when u have the radio on? also check your sub wires.going to the amp....make sure the rca'sare hooked up to the radio rear out puts are the radio sub out puts...and then test your amp gain adjustment...let me know if that work's
Jun 23, 2008 | MTX Thunder5601 300W x 1 Car Amp Mono...
How do i hook up the r.c.a to the back of VM9312
try hooking up your rem wire I.E. blue/white wire to blue wire (not to power antenna) then check ground and power wire. never hook up power wire while car is on...you will blow amp
Mar 18, 2008 | Jensen VM9510 Car DVD Player
Blowing fuses
you may have the rem wire hooked up to the yellow 12v battery wire located on your harness. try yellow to yellow and if your rem is not working correctly when is hooked blue to blue put in on the red ignition wire located on your harness. should solve the problem. or return it
Mar 02, 2008 | AudioControl KVT-911DVD Car Video Player
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
Lanzar SDBT75N Car DVD Player Logo
712 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
