Question about Ricoh Aficio 450 Copier
Wat is da problem of my copier afficio 450
My id output display VSG (4.11) VSP (0.00) VSDP (0.00)....wat is VSDP means?? becuz ol i knw dat it must be (4.0)(0.0)(4.0)
  • thraser
    thraser Mar 05, 2009
    so wat im gona na do...?? is der a posibility my magnet roller is damage or watever plz help men...
Thraser, your still battling this machine? Of course your readings will be off if you only have developer coverage over half the mag roller? That's where I would start.
I also now wonder about your model #, because I don't think that the 450 has a VSDP reading, but the newer ones do. It refers to the "immediate post-pattern output" of the ID sensor -not surprised that these readings would be whacked!
Posted on Mar 05, 2009
  • Anonymous Mar 05, 2009
    Must be something wrong with the dev unit. You could try to find another one. I have one, but you're not in Toronto, I bet....lol.
    This is one old machine - Upgrading would be a better solution - stuff is getting to hard to get for these old boxes...but again.....are you sure it is an Aficio 350 / 450?
What does service code sc350 mean?
SC350:
Problem:
ID sensor pattern test error
Description:
One of the following ID sensor output voltages was detected twice consecutively when checking the ID sensor pattern.
1) Vsp ? 2.5V
2) Vsg ? 2.5V
3) Vsp = 0V
4) Vsg = 0V
Possible Problems:
• ID sensor defective
• ID sensor connector defective
• Poor ID sensor connector connection
• I/O board (IOB) defective
• High voltage supply board defective
• ID sensor dirty
• Defect at ID sensor pattern writing area of the drum
** Generally, I've found this problem to almost always be one of the last two items listed above.
Jun 21, 2011 | Gestetner DSm745 Black and White Copier
What is a 350 code on a savin 8045 copier
This code can be reset be turning off the main power (orange rocker switch) for about 10-seconds and then turning the machine back on. If the error comes back up, then there is a definite problem with the machine and it should be looked at by a train service technician.
SC350:
1) Vsp ? 2.5V
2) Vsg ? 2.5V
3) Vsp = 0V
4) Vsg = 0V
Possible Causes:
• ID sensor dirty
Apr 01, 2011 | Office Equipment & Supplies
Parts and consumable of afficio 450
http://www.ricoh.com.ph/support/contact.html
Sep 07, 2009 | Ricoh Aficio 450 Copier
Afficio 450 developer type 4 or type 5
This machine takes Part Number "887733: Developer Type 5"
Hope this helps.
Jul 05, 2009 | Ricoh Office Equipment & Supplies
Changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
Apr 24, 2009 | Ricoh Aficio 450 Copier
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Changing developer in afficio 450
Preform SP 2-801 then 2-805.That will do it!
Jan 21, 2009 | Office Equipment & Supplies
Copier.... afficio 450 vs konica 7025
You're talking about two really old machines, the 450 from 1998 & the 7025 from 2000.
Both are about the same class, but I'd give the edge to Ricoh since it was also sold under a number of other brands & replacement parts are readily available.
Hope this helps...
Sep 10, 2008 | Office Equipment & Supplies
Afficio 450 camera lense alignment
You need a manual to calibrate the scanner do you have one?
There are some holes in the scanner that need to be calibrated with a tiny screwdriver. The manual teslls you the correct settings.
Did yiou remove the cable?
Aug 19, 2008 | Office Equipment & Supplies
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
119 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
