Question about JVC DLA-SX21U Multimedia Projector
Optoma EP739 Projector won't turn on
After replacing the bulb and cleaning with compressed air the projector worked for a little while but now won't turn on and i get no lights on the top. I know there's a safety switch next to the lamp under the plastic cover but it seems to be making good contact. I tried two working bulbs, checked all the connections I could find inside the unit by disassembling the main covers, and cleaned everything out. Are there any other safety switches? Any ideas?
Please help!!
ice man
  • 68 Answers
SOURCE: jvc HR-S9700 -TAPE JAMS, THEN SWITCHES OFF,CASSETE DOOR REMAINS OPEN,DOES NOT ACCEPT OR PLAY
the switch is on the electronic board under the tape compartment. you have to unscrew the screws and unplug all the wires to take it out. be careful though, you have to put it back the way it was otherwise you will mess up the machanisim on that machine. good luck
Posted on Apr 06, 2007
Benimur
  • 6966 Answers
SOURCE: no signal optoma ep739
One good thing is that you are running XP. Will work on the premise (that you have posted) worked before and the driver (ForceWare91.31) was the only thing changed.
Let's try the easy ones first. Activate twin/dual view in your Display Properties. Right click on any clear area of your desktop, click on Properties, click on Settings tab, select monitor 1 or 2 depending which is your primary and which is your projector. Check (or uncheck-whichever works) on box "Extend....". Apply, OK.
or
do the same with nView Properties.
The hard ones are registry and/or inf editing, though I am reluctant to even suggest.
Incidentally, there is an application that is supposed to facilitate twin or dual view configuration, UltraMon. This may be better/safer way to address your concern.
If all else fails, you may have to rollback/downgrade your driver.
Cheers.
Posted on Jan 20, 2008
simplemitch
  • 752 Answers
SOURCE: Remote control
You need to resurface the contacts. Here's how you do it:
First, disassemble the remote. Clean the black foil pads on the circuit board with rubbing alcohol. Now take a #2 pencil and a razor and shave the graphite from the "lead" onto a piece of paper (hold the blade perpendicular to the lead, this results in a finer powder). Now that you have a nice pile of powdered graphite, blot a Q-Tip into it to saturate the cotton with graphite. Rub the graphite onto the little black pads on the rubber button membrane, and be sure to apply more graphite to the Q-Tip every 2 to 3 buttons. Blow off any excess graphite. reassemble remote and test.
Posted on Aug 04, 2008
marsrover
  • 682 Answers
SOURCE: projector has no power
close lamp compartement door firmly because door switch can disconnect power from projector if not closed firmly.
Posted on Sep 22, 2008
SOURCE: optoma ep739 won't power up
The lamp cover has a disconnect that won't allow power while the cover is off. Sometimes the piece of metal gets bent out of place.
Try removing the cover for the lamp, and bending the little piece of metal forward.
It worked for me!!!!
Posted on Nov 27, 2008
The lamp exploted in less than 30 hours of use, replaced an exploted in 4 hours, replaced and exploted in 5 minutes what can I do?
Is it the correct bulb? Or recommended bulb? Try a higher wattage or lumens. I'm not sure what the lamps in the projectors are called, but check on the wattage and lumens.
Dec 07, 2014 | Optoma EP739 Multimedia Projector
How do you feed TV thru an Optoma DLP projector?
You need a tuner to tune in the tv channels. use a vcr that way you can change your channels
Jun 06, 2010 | Optoma EP739 Multimedia Projector
We have a optoma ep739 used at our local football club;but whenit gets warm it cuts out until it cools down;isthere any filters that need cleaning
take the lamp out, there is a fan directly looking to the lamp... clean it with a compressor. and after that at the menu of projector there is a place called 'High Altitude'. turn it on. And it'll be fine...
Mar 01, 2010 | Optoma EP739 Multimedia Projector
Optoma ep739 color was going greenish so i replced the bulb and now it seems to be getting no power at all? i tried several outlets and still no power, no flashing light, no led, nothing. Any suggestions?
These units have many safety interlocks. First make sure that all of the doors that you opened are replaced correctly. If not, the interlocks will prevent any power from getting to the unit. Update this with what you find.
Dan
Jan 29, 2009 | Optoma EP739 Multimedia Projector
Optoma EP739
The lamp cover has a disconnect that wont allow the unit to power on while the cover is off.
Try taking the lamp cover off and bending the little piece of metal you find underneith.
It worked for me.
Nov 01, 2008 | Optoma EP739 Multimedia Projector
I have the optoma h31 projector and the color turned purple. We assumed it was the bulb and put a new one in. The color is now still not right and the picture sorta bounces
I had a similar issue with my EP739, the problem would start after about 3 or 4 minutes and then get gradually worse and worse..
The most strange thing I noticed was that white looked fine. And if you opened the configuration menu in the projector it appeared that blue was labeled green and green blue..
Some sites suggested cleaning the machine of dust, which I tried using a can of compressed air... This did not fix the problem at first.. but when I had it apart I studied the colour wheel for a little while and wondered if some how the machine was synching to it incorrectly somehow.. So I blew out the colour wheel location sensor (It's kind of obvious being the only component mechanically connected to the color wheel. Much to my delight, this fixed the problem...
So my solution to the flickering / colour fading / colour swapping issue with DLP projectors was to clean out the dust from the colour wheel location sensor..
In fact, if I did it again, I would ONLY clean the sensor, and leave the rest of the dust alone. Blowing dust around has the potential to cause other issues, especially if it winds up inside the optics system.
- Nate
Apr 27, 2008 | Optoma H30 Multimedia Projector
Optoma EP739 Projector Overheating
Set the projector to "high altitude mode." It will be noisier, but won't overheat. I wonder whether using one of those $10-$20 laptop coolers underneath it might be a quieter solution.
Mar 09, 2008 | Cameras
Optoma EP739
i have the same projector with same problem. i called optoma direct and ordered a new color wheel. it was relatively easy and came in about a week. the phone no. is 408-383-3710
Feb 11, 2008 | Optoma EzPro 739 Multimedia Projector
JVC DLA-SX21U Multimedia Projector Logo
910 people viewed this question
Top JVC Office Equipment & Supplies Experts
MusicMania
Level 1 Expert
Piyal Perera
Piyal Perera
jasbo
jasbo
Are you a JVC Office Equipment and Supply Expert? Answer questions, earn points and help others
