Question about Dell E156FP 15" LCD Monitor
I have a dell E156FPc LCD Monitor that won't power on. Not even an LED lights up. I've tried a known "good" power supply but still nothing. I opened it up and all of the caps appear to be good. I'm no pro but I've repaired a few of these. This one I'm stuck on, can anyone offer a suggestion?
  • 52 Answers
The board, with the power buttons is most likly toast. If it's not the power supply, than it's either the board or completly shorted out. Good luck.
Posted on Mar 05, 2009
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a Dell Precision M60 laptop and the charger adapter's led light is on when i plug it in, but the laptop won't turn on.I've replaced the battery and tried a different charger but that...
Unfortunately it sounds like you have an issue with your motherboard. If you remove the battery and just try to power on the laptop using the AC adapter and it still won't power on then it's probably the motherboard. The power supply circuit (where the AC adapter plugs into) for the motherboard is integrated into the motherboard.
Sorry. If it's still under warranty Dell will replace the motherboard.
Sep 10, 2011 | Dell Precision M60 Notebook
Tv little green light is blinking but tv won't power on
Ur tv power supply board it dead.The power supply board,that the board the a/c power coard go into it,that ur tv power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replament.
May 26, 2010 | Dell W3000 30 in. HD-Ready LCD Television
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
Dell 173FP - black screen - green flashing power LED
It can be bad fuse, shorted trnaistors inthe inverter circuits, bad caps, transformer. See the pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Post back what you find so we can guide you further.
Mar 10, 2010 | Computers & Internet
E173 Monitor has no picture, led powers up, turns off, cycles
sawyrick, This sounds like the switch mode power supply has failed, or it has detected a problem with the inverter board that lights-up the Cold Cathode Fluorescent tubes on rear side of lcd panel. You did not state any history in your complaint!! You didn't even tell how old it is. These things are important! If the fuse inside on the switch-mode-power-supply board were to go "open-circuit" then you wouldn't get any front panel light. In any case, since I don't know your level of electronic repair capability, (level zero because you don't own any test equiptment or soldering iron, solder, solder wick) you have few if any options open to you. Here are 2. 1. Call Dell, ask about monitor swapout program? If any!! You send them your's + $60-$90. They send you Refurbished same model in return. 2. Find out all you can about lcd monitors and their failing SMPS boards and or INVERTER circuit boards CCF tube lighting systems. YOUTUBE has some videos on the subject because of the high rate of failures due to Bad/failing electrolytic filter capacitors and or real crappy soldering of components to the SMPS board and or INVERTER boards. For a look-see only visit lcd-monitor-repair.com or www. badcaps.net or lcdrepair .us just for your own information. Hope thisinfo helps you out. I would certainly like to know what avenue of repair that you select to go with. In any case, I wish you good luck. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Apr 04, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell XPS 730 - Brand New - No display - Fan Loud
check if u r able to open the optical drive if its opening then power supply is gone bad or else get mobo an power supply replace
Dec 13, 2008 | Computers & Internet
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Computer monitor
try making sure that the power wire has a good clean connection and is securley plugged into your outlet. also try using a different cable like the power cable to your pc. if it still isnt turning on. you will need to take it to a repair shop or replace it.
May 24, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
No Power LED and Nothing on the screen
Check your power supply to your screen cause it should at least show a amber light at the screen to show that there is power but no proper signal from the computer.
So below are step to check the power supply to your monitor. Assuming if you use a different monitor on your pc it works
1. Check your fuse both internal and external
2. check if power is receipted by the LCD
Mar 24, 2008 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Dell E156FP 15" LCD Monitor Logo
583 people viewed this question
Alun Cox
