Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
Pump put together wrong
Need diagram
  • Gjermund Danielsen
    Gjermund Danielsen May 11, 2010
    Model NR ?
  • Jason
    Jason Apr 13, 2014
    not for sure. the pump is mechanical
  • 188 Answers
Here is a link to the owners manual included is a parts list... http://12.153.20.74/manuals/123919-01A.PDF. If you need a part you may want to try www.masterparts.net. They seem to be the only guys who have any.
Hope this help ...
Posted on Mar 05, 2009
Took of covers to oil speed omitor put some wires came off put back together and no elc. start or break light witch wire is not hooked up or in the wrong place
Sounds like , if the wires were in the wrong place it might have blown a fuse. Check the fuses to see if one is blown out.
If all the fuses are good then you probably need a diagram.
I like to use autozone.com for diagrams. You could try that.
Hope this helps.
Mar 24, 2015 | Cars & Trucks
How do I obtain a wiring diagram for 2003 Bourget Low Boy?
Should be in the back of your manual. If not, you have the wrong manual.
Nov 06, 2014 | Motorcycles
Need to rewire from 480 to 240 need coolant pump diagram for colchester # 348337 3 phase motor
Assuming that the motor has 9 leads and the wire numbers are still on the wires, for 240 volt 3 phase connections:
Connect T1, T6, and T7 together with L1 (A phase)
Connect T2, T4, and T8 together with L2 (B phase)
Connect T3, T5, and T9 together with L3 (C phase)
If you're not sure which of the incoming wires from the supply are L1, L2, and L3, just pick one. If the rotation is wrong just swap any 2 (TWO) phase wires.
Jun 22, 2010 | Measuring Tools & Sensors
I've repaired the bearings in my wf000 hotpoint washing machine, put it back together now it won't pump the water in, and the door lock light does'nt come on! any idea's wot is wrong?
I would say you have missed a wiring connection somewhere or connected the module up wrong. Hopefully you noted where all the terminals came from when you dismantled it or you may need a wiring diagram.
Mar 16, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I need to know how to put the pump assembly back
Go to the link provided below and under the heading "Browse Subcomponents" click on the "Pump and Motor Parts" link. I think that shows what you're looking for. Otherwise, check the other diagram links for your model on the same page.
Hope this helps!
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=6651514590&pop=flush
Jul 28, 2009 | Kenmore Dishwashers
Does anyone have a diagram of 1994 F150 manual wheel hub
Are both sides apart? Don't have any diagram to give you, go to Ford and ask for the exploded parts diagram, it shows the parts in order, they will usually print the page for you no charge, it is good business. I am sorry can't be more help, call if you like 925-459-0571
Aug 02, 2008 | 1993 Ford F150 SuperCab
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
112 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
