Question about Acer AL2017 20" LCD Monitor
Monitor stand I can't find a monitor stand anywhere for my acer al2017 monitor. I even tried acer but they just gave me a couple of links and a phone number. Neither did any good. My original stand got lost, that's a long story on how that happened. Does anyone know where I can purchase the original stand?
  • 3 more comments
  • nancyeie Mar 05, 2009
    Thank you but I don't want to do it that way. Just want a normal stand.
  • nancyeie Mar 29, 2009
    to
    bammbammfran, yes I'm still looking for a solution.
  • nancyeie Apr 04, 2009
    Thank you bammbammfran my issue is now resolved the stand fits.
    sorry I forgot it's now a four.
  • Fran Bednar
    Fran Bednar May 11, 2010
    Are you still looking ?
    bammbamm@ptd.net
    Novelist:
  • 159 Answers
I have one or two nice used Original ones available.
Where are you located ?
email bammbamm@ptd.net if you want pictures and costs
Posted on Mar 29, 2009
  • Fran Bednar
    Fran Bednar Apr 04, 2009
    I solved your problem. I get 3 stars. Other guy gets 4 ??? )-:
    Habit-Forming:
    New Friend:
  • 70 Answers
Wall Mount Monitor Arm
Customize your computer station with a variety of monitor mounts and monitor arms that let you work the way you want. Complement is a manufacturer of CPU holders, monitor arms and accessories for organising offices.
Know more here: Monitor Arms and Mounting Archives Complement Manufacturer Of CPU Holders...
Posted on Nov 17, 2015
    Scholar:
  • 93 Answers
You could try a VESA compatible monitor stand, which would bolt to the back of the monitor. It is designed for wall mounting the unit, however there is no reason why you couldn't get a bracket on an arm and mount it to your desk, or pop it on the wall ;)
Posted on Mar 05, 2009
Nema stand by monitor Acer AL1916
Pozdrav, ako vam se uopste ne pali monitor problem je u napajanju i to kod tog modela je cesta pojava.Najverovatnije je potrebno zameniti elektrolitske kondenzatore. Kompletno uputstvo imate na https://www.youtube.com/watch?v=VgMUpqTBLuA
PAZNJA:Ako niste posebno upoznati sa elektronikom vodite racuna jer moze doci do strujnog udara iako je uredjaj iskljucen.Nadam se da sam vam bar malo pomogao.
Acer AL1716 AL1916W AL2017 AL2416W LCD Computer Video Monitor Repair...
Dec 05, 2014 | Acer AL1916W 19" LCD Monitor
My monitor was working fine but now it won't turn on. Nothing was happening when it suddenly went off.The light is also not on and I have tried a few different power cables and plugs. It is an acer monitor...
Nost failures are due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 24, 2010 | Acer AL2017 20" LCD Monitor
NO LIGHT ON SRCEEN
This model AL2017 20" Acer monitor is known for having a bad power inverter board. The capacitors go bad, which causes the backlight to completely stop working or flicker intermittently. If you feel like you are electronically and mechanically inclined the board is easily replaced. Search ebay for AL2017 Power Board -- its about 15 bucks plus shipping.
Feb 13, 2010 | Acer AL2017 20" LCD Monitor
My screen stay black, the monitor has power al2017
I called tech support and it was suggested to send the acer AL2017 monitor back to them to make repairs to the circuit board.
Dec 10, 2009 | Acer AL2017 20" LCD Monitor
Graphics error
Hello, I dont think you need a driver for you lcd screen. If your resolution is low you need drivers for your graphic card. what card do you have ?or computer?
May 13, 2009 | Acer AL2017 20" LCD Monitor
Acer AL2017 Monitor
you will need 3 or 4 ( forget now) 220 uf 25 volt and two 1000 uf 25 volt .... just finished putting this one back together and it's great.
Dec 10, 2008 | Acer AL2017 20" LCD Monitor
Acer AL 2017 Monitor
I just repaired one.... will likely require that you replace 3 X 220 uf 25 volt capactiros and 2 X 1000 uf 25 volt capacitors. can't miss them the tops are swelled up. but the monitor appears to work now... not bad for 5 bucks worth of parts.
Sep 10, 2008 | Acer AL2017 20" LCD Monitor
Had a Acer al2017
If your picture was okay when it was running and the screen was not pinkish then the power board inside the monitor is in need of an overhaul.
Your unplugging it and plugging it back in just did a temporary reset by discharging the capaciotrs for a bit.
It more than likely needs new capacitors installed.
I have done a few of these and do a lot of inverter power board repairs through ebay id bammbammfran
Fran
bammbamm@ptd.net
Dec 12, 2007 | Acer AL2017 20" LCD Monitor
Acer AL2017 20" LCD Monitor Logo
425 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
