Question about Philips SA3025/37 Flash MP3 Player
My Mp3 player is working perfectly except for two problems number one, every time I try to change the song something comes up that tells me to add the certain song to a play list then gives me the option to add or cancel. Ever since I got my MP3 player it has randomly not turned on. No matter what I try, it does not respond in anyway to the computer or the rest button help!!
  • 8,596 Answers
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Mar 06, 2009
Problem when trying to add songs to albums
try removing all of the other info from the listing, except for the album, artist, and title. This is strange, but if you could tell me what brand it is, then it could be something much simpler.
Feb 05, 2008 | Samsung YP-K3 MP3 Player
It ll show only walkman and it ll turn off........ its not working...........
If your mp3 player shows the walkman, then it means the player is okay. But you need to check the battery if it is fully charged before you turn it on. Try to charge it over a while before turning it on, after doing so, turn it on. It will work.
And if it does not work, connect the mp3 to a computer and try to see the files on it. That way you will be able to tell if the files are not corrupted.
You can format the mp3 player using the computer, then try to re add your songs on the mp3 player and turn it on, this time it will work perfectly fine.
Hope this helped.
Jun 21, 2011 | Sony Walkman NWZ-B142 MP3 Player
Sony nwz s544 mp3 player won't sync/add songs, running too slow?
why dnt u try opening the file and jus dragging the songs on =] good luckk
Oct 16, 2009 | Audio Players & Recorders
Tags On My Mp3's On Device (RD2765) Aren't Working
I simply figured out that sometimes the two types of tag types for an mp3 file aren't the same and it creates a disconnect between the two and in that case neither of the two tags will be correct and the device will read them as tagless files, so to fix it I simply deleted both tags on it so there were no tags at all, then made both tags again, but the second time they were the same so they were both registered by the device, making the tag appear on the device... simple as that :)
Feb 08, 2009 | RCA Lyra RD2765 MP3 Player
Player cannot get connected to computer-Philips GoGear SA3115
Install and run the Philips Device Manager software from the product CD.
Select the Repair / Restore option and follow the on-screen prompts.
This will format the player and repair the firmware.
Mar 24, 2008 | Philips SA3125\02 MP3 Player
Can't delete songs
i had a problem like that once all you have to do is format your mp3 player go into media player under the sync tab and click format only problem is that you have to put all your songs back on it again
Jan 02, 2008 | Memorex MMP8565 MP3 Player
Storage
The iLO manual says you cant get songs from music stores like Napster. Lime Wire works very well on mp3 players. This same problem happend to me but then i realize it doesnt work if the songs come from Napster
Dec 21, 2007 | iLO MP3 Player
Why wont my Sansa get songs???
You may have to install Musicmatch and add songs through the portable device menu. It worked for me. Good luck.
Oct 28, 2007 | SanDisk Sansa m230 MP3 Player
Cant transfer anything to my player (e250)
i'm having a similar problem. every time i sync new music my computer tells me its on, but the tracks aren't on the player. it also refreshes every time i turn it on, which takes forever amd is getting really annoying. could this have something to do with my new microSD card?
Mar 05, 2007 | SanDisk Sansa e250 MP3 Player
Philips SA3025/37 Flash MP3 Player Logo
52 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
