Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Snowblower Treads not turning
I have a 5hp 23" Craftsman Snowblower which just had its traction belt break. When I opened up the bottom of the snowblower there was a loose spring in the bottom. I cannot figure out where it is supposed to go, but the treads still do not spin. It looks like one end would attach to the pulley which should cause tension on the belt, but I can't figure out where the other end would attach. Does anyone know?
    Scholar:
  • 76 Answers
Hello, if you go to searspartsdirect.com type in your model number you will be able to find a diagram that will show you where and how the spring attaches
Posted on Mar 05, 2009
I have a 30"/ 16.5 craftsman snowblower and the traction belt keeps jumping off almost as soon as I engage the drive. I have replaced the belts and it happened again.
1) Look for obvious pulleys out of alignment. Most pulleys on a drive system are 'keyed' and have a set screw or bolt holding them into position.
2) Most traction belts turn with the engine, so it turns all the time. Look for an idler pulley with spring attached that may be out of alignment.
3) Inspect the 'V' groove of the driven pulley for any foreign debris.
4) Inspect the driven pulley for damaged caused by another pulley or object striking the edge of the 'V'.
Feb 15, 2017 | Garden
What are the belt sizes for a craftsman snowblower model# C950-52379-5
Based on the following info from SearsPartsDirect.
Will this fit my Craftsman Canadian model c9
The auger drive belt is part number 585416MA, and the drive belt is part number 1733324SM.
Feb 09, 2015 | Craftsman Garden
Auger clutch cable breaks at hook
find out why it is binding at that point they should not break that easy , do not force it , that is what is happeing find out what the problem is
Feb 14, 2014 | Craftsman Snow Blower / Snowblower Bottom...
I have a craftsman snowblower mdl # 842.242561 - need specs-
I have the same blower, and use a 19.5hp garden tractor with 23" rear tires
Nov 17, 2009 | Craftsman Garden
Check the steel axles that go through the plastic wheels.What happens is the axles rust and swell not allowing the track wheels to turn freely.its a problem overlooked by all the so called small engine repair shops.I have removed the wheels and sanded the axles to remove the rust.I greased the shafts and the wheels move freely.There is a provision on the wheel for a grease fitting.I carefully drilled the holes and with some strong waterproof glue thredhed a fitting in each wheel.
Mar 05, 2009 | Garden
Ariens 926LE snowblower won't engage forward or backwards. Running fine
First thing I would check is to make sure the traction drive belt didn't fall off or break. To do this remove the plastic shroud between the engine and the snow chute. The traction belt is the one closest to the engine.If it isn't broke Make sure it is on the upper and lower pulleys.
Dec 21, 2008 | Garden
Ariens Snowblower won't engage into drive
I had the same problem with my 5HP Dual stage (C950-520240) Canadian model and found that the arm connected to the traction cable (part #85449 "Shaft Traction Clutch") which forces the friction disk up to the rubber friction wheel had a cracked weld and had bent, preventing positive contact with the rubber friction wheel. The drive wheels would turn if you lifted the back of the machine off the ground, but would not work if under load. First I replaced the belt and rubber friction wheel, but no go. I had to basically disassemble the whole drive assembly to find the problem, very frustrating because you could not see the crack in the arm from head on. I had the cracked and bent arm straightened and welded, all is OK now. enb54.jpg
Dec 05, 2008 | Ariens 34 In. Zoom Series Riding Mower
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
276 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
