Question about NetGear DG834G 802.11G Wireless ADSL Firewall Router [ DG834GNA Wireless ] (114587)
How do I disable my DG834GT router firewall?
I am having difficulty networking my 2 laptops and desktop. I am told that if I disable my firewall in my router that this may help? can you tell me how I do this. I have a netgear wireless DG834GT router.Thanks
  • greer200 Mar 05, 2009
    I can see most of the network but those computers that I can see I cannot access even though I have enabled sharing. When I tried to access another computer a see the drive but as I say they are shared but when I try to either open or explore the drive I am Presented with the following message. " Drive C can be seen but the computer that I am logged into does not have permission to open, explore the drive.
    Can you help?
    Scholar:
  • 82 Answers
The router firewall only blocks connections coming from the internet.
Basically it only lets an outside IP connect to your network if you establish the connectoin FIRST.
The most common cause of not being able to see another PC on the LAN is not having the same workgroup name.
Go to Start > My Computer , right click > Properties > Computer name. Make sure all PCs have the same workgroup name.
Posted on Mar 05, 2009
  • Steve Bumblis Mar 05, 2009
    1 of 2 ways to do it.
    On the destination PC go to the drive or folder that is shared , right click go to sharing and security , click on permissions. In the box you should see "everyone" , if not click add and type in everyone , then in the box underneath put a check in full control.
    or on your PC open explorer go to tools > map network drive . Set the drive letter to whatever you want it to be , (usually the higher up the alphabet the better so it doesnt conflict with usb sticks and such) where it says folder, type in the computer name where the share is , you can find that in the same place the workgroup name was. , and then the share name like this.
    I have a PC named fido and a share named music.
    \\fido\music
    Put a check where it says reconnect at logon.
    There will be a little link underneath that says connect using a different user name , click that. Type in the logon for the PC with the files you are trying to access. Hit ok and it should connect.
I want to use my d-link router with my new acer laptop but cant connect to the router. Windows says it is a router connection problem. It can locate the router just wont allow me to connect.
1.In Control Panel, click Network and Internet Connections, and then click Network Connections.
2.Right-click the Wireless Network Connection, and then click Properties.
3.On the Wireless Networks tab click Add.
4.In the Wireless network properties dialog box, enter the SSID "(Name of the connection) ex. dlink1234" you configured for your wireless gateway
5.Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway. (WPA-TSK, WPA2-TSK, WPA-AES and WPA2-AES)
6.Click OK and your home network will be added to the list of preferred networks.
if you have a firewall in your laptop try to disable it. example Eset Security antivirus Firewall. Disable the Firewall.
Aug 25, 2010 | D-Link (DI-784) Wireless Router
Got a home network with a cable modem, router in my living room, and a laptop and desktop in bedrooms. Router is connected along with the cable modem in the living room pc. Mcafee firewall said that i had...
the problem is is your pc has a built in modem???model of laptop and model of desktop???
contact me here if you want some help..stormblade002@yahoo.com
Feb 06, 2010 | Computers & Internet
Wifi getting connected with new linksys
on the desktop you need to find the wireless icon and right click on it and view available wireless network, try to connect to the wireless network you have establised, SSID and the encryption wireless as well.
try to connect and checked the connection, you should be getting Online..
Jun 26, 2009 | Linksys Wireless-G WRT54G Router
You need to call Linksys again for them to help you setup the other computer. For the none-working computer, you don't need to run the setup CD for the router. All you need to do is connect to wireless network like what you did on the working laptop.
Jun 26, 2009 | Linksys Wireless-G Broadband Router
Connection problems using ethernet cable
your modem or router has othere lan port or not if there then put it and in laptop you using dhcp or by manually given ip address what is that you have to give the same in the desktop and pls off the firewall of the desktop computer
Jun 02, 2009 | Computers & Internet
Laptop connecting but not my desktop
> Try changing and creating a new wireless network name.
> Try changing your security mode like WEP to WPA or vice versa..
> Try to update you drivers on your laptop then restart your computer before connecting to your network..
> Try assinging DNS ( Domain Name Server.) ask your router manufacture for the DNS that you could use.
> Make sure you typing the correct password for your wireless network..
> Make sure you disable WI-FI protected setup and on the router.
> Try to disable Anti-virus and Firewalls on you laptop.
Feb 17, 2009 | Linksys Wireless-G Broadband Router
Cannot get onto internet
disable the firewall on control panel.
check all the properties boxes on the network
connections and make sure firewall is disabled.
access the router setup and make sure that VCI is set to manual
and that you enter in the settings yourself (eg: 0,38 for aol broadband). Don't leave VCI, etc on auto, the router can't handle it.
Jan 09, 2009 | Buffalo Technology WHR-G54S Wireless...
Router not working
Hello Sean Lin,
The only option for the 5th pc would be to get it wirelessly connected. You need to install a wireless adapter to your pc. Set the IP & DNS to automatically obtained from router.
You also try to adjust or temporarily disable the your firewall and other securities;
Disabling Windows Firewall
Note: A firewall is designed to help protect your computer from attack by malicious users or software. Such software includes viruses that use unsolicited incoming network traffic that infects your computer. Before you disable your firewall, you must disconnect your computer from all networks, including the Internet. To disable your Windows firewall, please follow these steps:
Disable Internet Connection Firewall in Windows XP or Windows XP SP1
1. In the Control Panel, double click Network and Internet Connections. Then, click on Network Connections icon.
2. Right click on Local Area Network (LAN) Connection on which you want to disable the Internet Connection Firewall (ICF), and then click on Properties.
3. On the Advanced tab, you will see protect my computer or network check dialogue. Then, click on the Settings tab.
4. Click on OFF then OK.
Disable Windows Firewall in Windows XP SP2
1. Please click on Start, then click Run. Then, type in firewall.cpl and then click OK.
2. On the General tab, click OFF (not recommended) and then click OK.
I hope this troubleshooting steps will help..if not please notify me
Nov 20, 2008 | NetGear WGR614 54Mbps Wireless Router...
Problem linking my wireless laptop into newly installed network
you may have to turn on the wireless feature in the router.netgear will help you to fix it.go to their site or call them for help.
Jan 07, 2008 | NetGear DG834G Router
WIN XP
Windows XP includes a built in firewall. By default, the firewall is enabled (turned on). In order to use your router, you must turn off the Windows XP firewall. Your router already provides a firewall for you so turning off the Windows XP firewall will not make your system any less secure. Follow the steps below to disable your Windows XP firewall: 1. Right-click on "My Network Places" on the Desktop. 2. Select "Properties" from the menu that is displayed. 3. Right-click on the Local Area Connection icon that corresponds to your network adapter. 4. Select "Properties" from the menu that is displayed. 5. Click the "Advanced" tab. 6. "Internet Connection Firewall" will have a checkmark next to it. Remove this checkmark by clicking it once. 7. Click "OK" to apply the change. Windows will ask you if you want to turn off the firewall. Click "Yes" You have now successfully disabled the Windows XP firewall. You are still protected by your router's firewall. You should now be able to access your router.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
NetGear DG834G 802.11G Wireless ADSL Firewall Router [ DG834GNA Wireless ] (114587) Logo
287 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
