2008 Smart fortwo Logo
Posted on Mar 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know what kind of oil filter to use.
I have a smart care and i need it serviced. I know someone that can do it but i do not know what kind of oil filter to use. Can you help me
Paul W
Level 3:
  • Master 404 Answers
  • Posted on Mar 05, 2009
Paul W
Master
Level 3:
Answers
404
Questions
Helped
188025
Points
1575
Hello!
I did a service on a Smart 2006 two seater, I had to drop the sump to remove the 0W 30 oil (As NO Drain plug) the filter is a paper one located behind the big black plastic cap on the engine with a huge nut shape on the top.
I have since purchased a oil suction pump to pull the oil out through the dip stick hole, I enquired at Smart and they said Sumps were in the process of having drain plugs fitted but I havn't seen one yet. Maybe you are a lucky one?
Oh! as for grade, it really depends on climate and conditions, your Spares supplier/stockist will have the Bible on all recommended lubricants for all makes so He/She will advise you the correct grade.
Hope this Helps!
Press the Blue Button please to appraise my FREE! Effort.
Thank You & Good Luck!
Paul 'W' U.K.
Where is the fuel filter located on smart car? Where is the fuel filter on smart car?
Hi, there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I bought it, I also had an issue with the file so the girl replaced it in 30 mins
There is another one one bitmanual, also great content
Or try youtube?
1helpful
My 1b service light came on 15% oil life. How much is this going to cost me
This is just letting you know that your are getting close to needing an oil change. Depending on where you take it in, and what kind of filter and fluids, anywhere from about 30-65 bucks I would think
Td12xxc3 what kind of engine and year believe its a chevy v-6
That's a tough one! If you need routine maintenance parts like an air filter, oil filter or spark plugs just remove the part and write down the number on the part and get the same part number. If you need stuff like a starter, water pump, etc. you need to look for some kind of ID plate on the engine. Are you sure there is a Chevy engine in an Isuzu Rodeo???? Can't imagine how they did that!
My audi a4 is leaking oil unbelievably bad. i had someone look at it and he said it was some kind of gasket or seal and said if i get it he will fix it. i need to know what to buy. the leak is coming from...
Sounds like the oil cooler is leaking. That is what the oil filter actually threads into. If so, that is not too bad to replace. Other oil leaks/seals to look out for are tail shaft seal (back of trans), rear axle seals, and vavle cover gaskets on top of heads. I would recomend checking the rest of the car carefully for any other leaks. Parts are typically cheap, but labor can get expensive to get to leaking seals and replace them.
Can i use Stp oil filter on 97 pathfinder or do i have to use nissan brand. Someone said there was a vent of some kind on the nissan brand oil filter. They said it would not run right if i used a different...
Ur right about that! U could use a high quality replacement parts for ur vehicle! those replacement FiLTER was BACKed by STP w/c we all know was a BRANDED NAME in automotive industry! Hope that lighten u up! Taah!
Type of oil filter/amount & grade of oil
Manufacture suggest you use 5w20 oil and the oil filter most common one used is a Fram Filter
2helpful
Hi, I have Nissan sentra 2002 gxe. After how many miles should i give the car in service? Which kind of service should I ask for? Thanks
Every 10,000 miles partial service; change engine oil and filter, air and fuel filter's, spark plug's and check brakes fluid pipes and pad's. Every 50,000 full service. partial service plus change cambelt, check gear diff and power steering oils. Owners manual or any mechanic will let you know oil grades etc.
1helpful
Not a problem, but info. needed.
ANY OIL CHANGE IS PRETTY EASY REMOVE THE DRAIN PLUG RE-INSTALL THEN PUT OIL IN , AS FAR AS THE LUBE JUST LOOK FOR THE ZERK FITTINGS ON THE INSIDE HUB'S SHOULD'NT BE ANY SURPRISES
2helpful
I dnt know where the oil filter is on my 1995 Saturn sc1? how much quarts of oil does it need? and what kind of oil do i use for it ? thank you
The oil filter is near the bottom on the back passenger side of the engine.
Engine oil - 10w-30 High mileage formula
It should take 4 quarts.
180 000 Km service scope
hi when a car gets a lot of mileage bet bet to do a full service you will know about the basics [plugs air/oil filters fuel filter oil ] if you want it to last change the pcv [positive crankcase valve ] if its got a pollon filter change it sump washer tappets need setting unless hydrualic change rocker cover gasket when was the timming belt changed this is essensiall if this breaks not worth the risk which then brings use to brake fliud if this has not been changed change it gearbox oil is the same if it not been changed it will lead to expencive repairs if not changed yates210456
Top Smart Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Smart Expert? Answer questions, earn points and help others
