Question about Dell Vostro 1400 Notebook
I've just installed Windows 7 Beta .However, the
I've just installed Windows 7 Beta .However, the sound in my computer disappeared.
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    You need the driver which probably isn't available yet; that's why it's a beta version.
  • 3,940 Answers
Try the WIndows Vista sound driver
Posted on Mar 05, 2009
Video card uninstalls ittself and reinstall back after restarting, what causes this and how do i fix it?
It is a beta and you probably have the win 7 driver there is no fixing it until windows 8 drivers begin to be coded
Mar 30, 2012 | HP SmartBuy 530 Notebook
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
My Acer Aspire 7520G gives, most of the time, no sound. Problem with the Acer Aspire 7520G 17.0" Laptop Acer Aspire 7520G gives, most of the time, no sound or audio device in windows 7. 2 days ago I...
Try installing the latest audio driver.
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Feb 18, 2011 | Acer Aspire 7520-5185 Laptop
Acer Aspire 7520 gives, most of the time, no sound or audio device in windows 7. 2 days ago I heard sounds coming from this notebook during a fresh install of windows 7, but at that time the moment I...
You can restore your windows 7 earlier restore point.
http://www.blogsdna.com/2039/exploring-windows-7-system-restore-restore-previous-versions.htm
Did install windows 7 ultimate.. then i donloaded the windows 7 driver for mz aureon 5.1 pci Card.. NO SOUND... any hints?
Please follow the steps below to get sound.
1) Uninstall the driver that you have downloaded.
2) Reboot the computer.
3) Now download the Beta Driver for the same from website mentioend below.
http://support.creative.com/Products/ProductDetails.aspx?catID=1&CatName=sound+blaster&subCatID=208&subCatName=X-Fi&prodID=14066&prodName=X-Fi+XtremeMusic
4) Install the Beta Driver and again reboot the computer.
5) It would work 100%. This has been suggested to many people and it worked just perfectly fine.
Best of luck.
Feb 27, 2010 | TerraTec Electronic Aureon 5.1 PCI Sound...
I had installed the windows 7 beta version. now videos not workin
windows 7 is still beta. It is till not a full operating system. Please let windows release the final version of windows 7.
Apr 04, 2009 | Intel Pentium 4, Pentium 4 , Celeron-D -...
Asus p5kc doesnt run 100% in Windows 7. I installed windows 7 but sound and network adapter doesnt work. I think windows 7 native driver didn't work. Can someone help me?
A lot of drivers will not work with Windows 7, at least for now. I would go to the Asus website and download the XP, Vista and 2000 or 2003 drivers for the sound and network cards you are trying to get to work. Try each one out. You may get one to work with Windows 7, but since Windows 7 is still BETA, I wouldn't hold my breathe.
Mar 29, 2009 | Computers & Internet
No sound in windows 7
u may counter-problem wid your sound card.
Mar 16, 2009 | AMD Turion 64 X2 TL-52, 1.6 GHz
Need an audio driver
Windows 7 is an beta version. you cant find drivers for that beta version yet
Good luck to you
Nic
Feb 13, 2009 | Compaq Audio card Sound Card
Dell Vostro 1400 Notebook Logo
125 people viewed this question
Alun Cox
