Panasonic DVD-LS80
Problem for Panasonic DVD-LS80
Broken screen casing
By nosuprize on Mar 05, 2009
The plastic casing around the screen broke open, but the player still works. Is there any danger as far as radiation/laser exposer to leave it the way it is? Is there any danger in unscrewing the casing around the screen to put it back together?
Solution #1
posted on Mar 05, 2009
Not Rated)
Geekman
Rank: Guru
Rating: 85%, 1751 votes
LCD displays do not emit any radiation. This is the same as LCDs that are used on laptops and on LCD High Definition TVs but these are much larger screens.
LCD are liquid crystal display just like the display on your digital watch, but it uses three lots of color crystals (red, blue & green)where as the digital watch uses one black crystal. The DVD player also a backlight panel to provide light behind the liquid crystals so you can see the movie images.
There is no danger in unscrewing the case etc, just don't have it turned on when you do this, because you may cause an electrical short to some components, even if you do it won't harm you (the elecrical voltage is too low) but it is enough to possibly damage the unit.
Was this helpful?
Yes
No
Popular Solutions for Panasonic DVD-LS80
Questions and Unsolved Problems for Panasonic DVD-LS80
Do you recommend Panasonic DVD-LS80?
Answer
Answer
after our Panasonic DVD-LS91 (portable) fell off a footstool while in operation, the audio works,... (More)
Answer
how do I find the four digit set up code???
Answer
HO3 error panasonic DVD-LS80 disc will not play
Answer
trying to find out password ratings
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic DVD-LS80:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
