Question about Sony KP-46WT510 46" Rear Projection HDTV
Convergence problem kp65wv600 replaced d board from sony but still have the problem. the picture is dipped in the middle and out of focus on the sides. is it a bad board or something else?
  • rodmarin Apr 27, 2009
    Replaced IC's, pico fuse in "D" board, and a pico in the "G" board the T.V. (KP-46twt510) was restored to its normal function, it looks great. Now I have a different problem? The set stays on for about 5min or so and then I lose sound and video, if I tun it off and turn it back on it returns to normal, but it does it once again, but it happens much quicker every time. Could it been something I did wrong or left unplugged.. otherwise it looks better than ever! The set never actually goes off it just seems off. Blank or darken screen.. no sound and it will return to normal after I tun it off and turn it back on. I've also notice that if I push guide on the remote it restores sound for a fraction of a second. Any help out there with this issue..
    thanks,
    Rod
  • Sony Master
  • 3,459 Answers
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 13, 2009
  • 4,234 Answers
It is possible it is the board, but that would be rare. If you have the service manual, follow the supply voltage lines. If the entire board was changed, the onboard fuses should be good. Check for 24V supplied to the board.
Keep us posted.
Dan
Posted on Mar 05, 2009
  • golfman246 May 04, 2011
    The problem is not the picture....It's green faded lines going across the screen in a slight ark....
    once in a while the whiol screen will light up bright green like a flash and dissapear.
Middle of the top of the picture in distorted and out of focus. color is displaying only purple at the top
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,require replacing to fix the tv convergence board,to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 04, 2010 | JVC AV-56WP74 56" Rear Projection...
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
I have a sony kp-61v85 color rear video projector and it has a red haze across the middle section of the screen like its out of focus. A tv repair man replaced 2 cv boxes and the picture got clearer and...
The tv have a problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resitors are dead.These parts on the tv convergence board,must be replaced to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Sony KP-61V85 61" Rear Projection...
Wavy color separation, auto focus doesn't fix problem. Doesn't have a manual focus.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Oct 11, 2010 | Sony KP-57WS500 57" Rear Projection...
Wavy lines green and orange hue.While watching a fooball game the status bar is wavy and in two separate lines-Green and Orange-Tried flash focus and convergence and powered unit off for several minutes...
Flash focus button push,didn't solved pictures convergence problems.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Picture is curved and wording is overlaping on my Sony 65'' hd pro
convergece ic's are bad also check low value resistors on convergence board. not an easy repair. you need expert soldering experience.
Feb 25, 2009 | Televison & Video
Convergnce sony kp65wv600
You can get replacement Ics at the following link which provides free instructions. I would recomend replacing the 4.7 ohm 1/2 watt resistors along with the two STK392-560 Ics as the resistors can get weak over time and that can lead to premature IC failure. Heres the link.
http://servicemanuals.vstore.ca/
Jan 18, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence Problem
sounds more like the convergence amp ICs STK392-040 you can get replacements here that comes with instalation instructions.
May 22, 2008 | Samsung PCN5425R 54" Rear Projection...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Convergence problem or??
Yes it has power supply and convergence problem let me know if you need help with part # s or how to fix it
Jun 23, 2007 | Samsung PCN5425R 54" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
295 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
