Question about Life Like Collectible Train Set
Life Like train hesitates and stops altogether.
I've already cleaned the rails and contact points with rubbing alcohol with no desired result. Engine works fine on other tracks, so I know that isn't the issue.
The problem seems to be conductivity of the track...What will remedy this situation? Thanks for any replies; this (new) set belongs to my 8 year old son...
  • 653 Answers
It sounds like you have eliminated the motor as the problem. Try cleaning all of the electrical contacts including the connections between rail sections and the hot rail with fine steel wool (make sure you clean up all of the remaining steel wool bits since they are conductive). If that doesn't work, look at the transformer output.
Posted on Mar 05, 2009
Battery operated polar express engine does not work
these are all basically at the same time in sequence,
1. test batteries, need at least 75-80% power for train to operate at all. will be very weak but should operate. or use known good batteries.
2. next are the battery contacts. a lot of time the positive contact gets bent so far it either makes no or very weak contact, simply bend it back out very carefully to make better contact and clean it with a little rubbing alcohol of nail polish remover and a q-tip.
3. next would be the switch for continuity and then loose or broken wire.
after that you can email me for further help.
Apr 18, 2014 | Lionel G Battery Operated Polar Express...
Vehicle has VW Diesel engine. I need to clean the injectors from normal diesel use and the vehicle was not driven a lot in the last year. Cann't change the filter it's located in the fuel tank and it one...
You would be better off putting everclear alcohol in the system. Rubbing alcohol has no effect on the water content and may destroy the seals and gaskets in the fuel system. 100 percent ethanol. mixed in with the diesel.
Oct 21, 2013 | Cars & Trucks
Trying to print. gets to 7% and stops. Ink cartridges show question marks. For Lexmark X4650
remove the cartridge and clean all the contact points on it (not the ink spitting part) and reinsrt it. Use a q-tip and rubbing alcohol.
Mar 08, 2011 | Lexmark X4650 InkJet Printer
Nikon D200 has become nearly impossible to grab images
False low-battery warnings, focusing, and metering problems may be the result of poor contact between the body and certain lenses. Try removing your lens and thoroughly cleaning the contacts. I would recommend using a contact cleaner, but rubbing alcohol will also work. Remember that the whole ring needs to be cleaned. If that does not work, try scraping the battery contacts.
Feb 01, 2010 | Nikon D200 Body Only Digital Camera
Roomba goes a few minutes after a charge then stops
you can try cleaning the battery and charging contacts with some rubbing alcohol or contact cleaner, but its also possible the battery has reached the end of its service life.
Sep 13, 2009 | iRobot Roomba 560 Robotic Vacuum
Lexmark Ink Cartridge Issue
Ink cartridges do have a shelf life - usually about two years from manufacturing, but it's more likely that the nozzles have become dry or clogged as result of disuse. You may get things corrected by putting regular rubbing alcohol on a clean soft cloth and gently wiping the contact points between the printer and the cartridge. If that doesn't work, you'll probably have to replace the cartridges.
Feb 20, 2009 | Lexmark X1240 All-In-One InkJet Printer
sometimes DVD/CD drive become dirty of dust falling into leses.
Try This first !
Prepare 1 Cotton buds (clean one)
1 ply of tissue
1)Dip i side of it to Pure SWAN ALCOHOL or cleaning pure alcohol
2)touch 3 second of cotton bud to tissue (this to ensure excessive alcohol absorbed to tissue)
3) eject your cdrom drive
4) use cotton bud, scroll /rub/ twist the bud onto the shiny lens, be careful not over excessive force over the lenses.
5) rub again with dry bud.
TRY read your discs
Good luck
Please rate me if you happy with the results
Jan 05, 2009 | Computers & Internet
Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Dec 14, 2008 | Lionel Cw 80 Transformer
Tried all advices but no solution...
cleaning with rubbing alcohol may have aggravated your problems - rubbing alcohol contains glycerin, which may tend to worsen the connections. to clean the connectors, use only _denatured_alcohol or electrical contact cleaner. the only connectors I have had to clean are the two leading to the video head.
Mar 29, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Life Like Collectible Train Set Logo
135 people viewed this question
Top Life Like Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Life Like Toy Expert? Answer questions, earn points and help others
