Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
What oil should i use when changing
Should oil be non detergent &
What is an alternative to sae-30 non-detergent oil.
A two stoke oil is a non detergent oil and is mixed with the gas for two stroke engines. If you are looking for an oil to add to the crankcase of a four stroke engine, you are better off with a detergent oil, the detergent and additives are make to keep your engine clean by attracting the particles in the engine crankcase.
Jan 26, 2015 | Garden
What kind of oil do I use in the Coleman powermate 6875?
You can use numerous engine oils. 10W - 40, 30W Detergent, 30W Non detergent (SAE)
The best all around above 40 deg F and below 100 F oil to use is a 30W detergent oil. Brand name does NOT matter. Oil level should be checked EACH time you add fuel. Change oil any time the oil appears Dark BLACK when checked regardless of the hour intervals. .
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Coleman Powermate Powermate 5000W...
What oil to use in a #38898 central pneumatic 2hp pancake air compressor ?
You need to use a 30 weight NON-detergent oil. The important part is make sure it is non-detergent! You can usually find it at O'Reilly's auto parts and possible other auto parts stores.
http://www.oreillyauto.com/site/c/detail/PGD0/ND30.oap?ck=Search_non+detergent+oil_-1_-1&keyword=non+detergent+oil
Jul 18, 2011 | Garden
I need a manual for the Craftsman Walk behind mower #917.388930. The main thing I need to know is when changing oil what is the capacity? SAE 30 non detergent I assume. Thank you.
No, you do not use non detergent oil. You must use only SAE high quality detergent oil with API service classification SG-SL . Use SAE 30 weight or 5W30 if you use the mower during cool conditions below freezing. I highly recommend you use Synthetic oil in this air cooled engine and change your oil once each year. The oil capacity is 20 ounces. You can see the owner's manual at this link. Just click Manual Location and put in the captcha and click submit. No need to sign in or register. http://www.hammerwall.com/Manuals/Craftsman/Description/917.388930/Craftsman%20Walk%20Behind%20Lawn%20Mower%206%20HP%2021%20Inch%20Rear%20Discharge/L0605486/
Jun 27, 2011 | Craftsman Garden
What oil goes in this unit?
Hi and welcome to FixYa, I am Kelly.
This response applies only to the engine:
Use 30 WT SAE engine oil.
You can use either detergent or non-detergent oil. I recommned 3 oil changes normal oil change intervals using 30 WT SAE non-detergent oil and on the 4th oil change use a detergent 30 WT Oil.
Kelly
Apr 17, 2011 | Honda 2500 PSI Gas Pressure Washer
What type oil does the dewault emglo require
Any motor oil is fine, like straight 30 weight, non-detergent, make sure it is non-detergent, or you will have soap suds in your little pump. They make compressor oil, but it is hard to find and all it is is non-detergent oil. Check it out.
Feb 05, 2011 | Garden
It is ok if we put sae 10W- 40 oil for honda oddysey 2004
u should always put in what the car calls for.
Jan 17, 2011 | 2004 Honda Odyssey
What weight oil does the honda 5.5 engine require?
Your Honda 5.5 hp engine specifically calls for SAE 5W30 engine oil. Use a good quality oil in the engine, and change it every 50 hours of run time. The pump will take 30weight non-detergent oil.
Using non-detergent oil in the engine will probably void your warranty, and will certainly shorten the life of the engine. Non-detergent oils have not been recommend by engine manufacturers in nearly 20 years.
Oil is cheap, go ahead and spend $4 - 5 on a quart of high quality oil. Your engine uses about 20 ounces per change.
Oct 01, 2010 | Honda 2500 PSI Gas Pressure Washer
What type of oil is used in a yard machine lawn mower model no. 11A-414E029
SAE 30WT i.e non detergent. Change oil every 25 hours and every 4th oil change us a detergent 30 WT oil.
The manuals will never tell you that but having worked on small engines since the mid 60's that 4th oil change with a detergent oil does a bang up job of keeping the oil ring from eventually cooking onto the piston. Also washes out the crank case and makes it look like new!
Kelly
Sep 07, 2010 | Mtd 22" Yard Machine Push Mower
Oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
May 27, 2009 | Mtd LAWN MOWER PART # 782-0082A-0638 DECK...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
88 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Roland W VanLue
Roland W VanLue
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
