Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
FRIGIDAIRE MODEL#FRS23W3AWA COMPRESSOR IS RUNNING FOR COUPLE OF HOURS AND STOP SUDDENLY
  • 1,800 Answers
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip (labeled "A" below) of just one of the compressor mounts (labeled "B"). Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbly or hard, it should be replaced. Replace and tighten the compressor mount.
also check the compressor relay:
The compressor is accessed from the lower rear of the refrigerator. The compressor is labeled "A", the terminal box is located at the position labeled "B".
The compressor is accessed from the lower rear of the refrigerator. TFRIGIDAIRE MODEL#FRS23W3AWA COMPRESSOR IS RUNNING - f961c05.jpgor is labeled "A", the terminal box is located at the position labeled "B".
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced
Posted on Mar 05, 2009
  • 583 Answers
Compresser or internal connections might be faulty.but initialy try unplugging the machine and defrosting it completely and then plug and check if it works properly.
    Sergeant:
    Novelist:
  • 277 Answers
Compressor won't run or it is "clicking' on and off: This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps ( see model/serial tag or the sticker on the compressor )...if the compressor is drawing too much current, this may be why it is shutting off. Check the model tag for proper amp rating. Some relays will be easy to notice the broken with them, they may be burnt. Example one, example two, example three. Some of these relays can be removed and give them a little shake, and if they rattle around inside the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install areplacement start relay. You will need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding. Using the original style relay is always preferred, but using a general replacement can "get you by" if needed.
  • 410 Answers
Whne the compressor stops are you hearing any other noises such as fans running  or maybe a hum and click noise?
U-Line 75FF Bar refrigerator stopped cooling
it could be a problem start/run capacitor for the compressor or compressor failure
get a fridge technician in to test and get a quote
Most small fridges are cheaper to replace than repair
Jan 09, 2016 | U-Line Refrigerators
My refrigerator freezer wont stay running longer than 4-6 hours. Stops calling for compressor to kick on. any ideas?
i suspect a defrost timer issue but u may want to check the temperature control switch and ur thermistors as well
Apr 17, 2015 | Frigidaire Refrigerators
Model GSI-26 suddenly stopped cooling
It sounds like your compressor is having a hard time starting. Take your model number to an appliance parts store and ask for a compressor start relay. It plugs directly into your compressor and is easily replaced. Remember to unplug the refer first.
Dec 17, 2012 | Frigidaire Refrigerators
I have a frigidaire refrigerator model #FRS6R5ESBC that stopped cooling. I replaced start relay on compressor and discovered that defrost control was burnt out replaced it also. now in less than 3 days...
Had one a couple years ago did the same thing. Found the compressor was going bad and was pulling too many amps thru the control. Ended up buying a new frig.
Apr 08, 2009 | Frigidaire FRS3R5EMB Side by Side...
My side by side refrigerator all of a suddens started dropping in
you replaced the overload relay assy on the compressor,worked for a few hours now broke again ???, if that sthe case and your having same issue , it sound sas if your compressor may be no good.
Nov 16, 2008 | Frigidaire FRS26F4C Side by Side...
6 yr old refrigerator stopped working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Frigidaire can answer your warranty question try 1-800-374-4432
To answer your question it would require several questions to be answered but as a general rule $300.00 + Compressor would be a start point for me HERE.
To Check your compressor:
Either your compressor is broken inside or the start components are not working properly. Ohm the compressor terminals to ground and across to each other.
If any read anything to ground the compressor is bad.
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
Assuming the above checks out: Get a new Start relay (start capacitor if so equipped) relay and overload (and capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration.
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Jun 30, 2008 | Frigidaire FSC23F7D Side by Side...
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
when you removed the back panel inside refrig was there any sign of cooling, perhaps only top 1 pass of the coil was frosted, or completly warm no signd of frost at all?
Feb 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
418 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
