Question about Storagetek L40 DLT Tape Drive
Stk l40 the arm failed initialization
When I turn on the stkl40,The operator panel displays the message:
The Arm(Theta and /or Z) failed initialization.(error 3106)
Init Failed
Does anyone know the reason?
Please tell me .
Thanks a lot!
2 Suggested Answers
SOURCE: StorageTek L40 Tape Library
how to change backup tape in storagetek L40?
would appriciate very much if you could reply me!
Thank you!
Posted on Apr 08, 2008
Kitchenaide rinse dispenser in dishwasher doesn't work. White soapy streaks on plates
Confirm that lower washarm is rotating. Initially check by rotating by hand. Second mark arm position turn on unit stop and heck arm position.
Listen very carefully and confirm arm is turning. It is often found debris clogs the lower arm jet preventing the arm from turning.
Also check the water level in washer sump. Low will also keep the arm from rotating.
Hope this helps.
Jun 29, 2017 | Dishwashers
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
Engine schematics 2002 pontiac montana
Hi there:
Isnt a diagram but If you have removed the motor, here is the motor installation procedure....
INSTALLATION PROCEDURE
Align the wiper motor to the wiper drive system module. NOTE: Refer to Fastener Notice in Service Precautions.
Install the wiper drive system module to wiper motor screws. Tighten Tighten the wiper drive system module to wiper motor screws to 7 N.m (62 lb in) .
Connect the electrical connector to the wiper motor.
Install the crank arm on the wiper motor.
Rotate the washer solvent container into the installation position.
Install the washer solvent container screws. Tighten Tighten the washer solvent container screws to 6 N.m (53 lb in) .
Inspect the wipers for proper operation.
Also, here is the crank arm procedure...
REMOVAL PROCEDURE
Remove the wiper system module cover.
Remove the drive link from the wiper motor crank arm.
2.1. Loosen the drive link screws.
2.2. Remove the drive link from the wiper motor crank arm.
Remove the wiper motor crank arm cover and seal.
Remove the wiper motor crank arm from the wiper motor.
4.1. Loosen the wiper motor crank arm screw.
4.2. Tap on the wiper motor crank arm screw with a soft-faced mallet while holding up on the wiper motor crank arm until the wiper motor crank arm loosens from the wiper motor.
4.3. Remove the wiper motor crank arm screw and the wiper motor crank arm from the wiper motor.
Install the wiper motor crank arm onto the wiper motor.
1.1. Turn the ignition switch to the ACCY position.
1.2. Set the wiper switch to PULSE position. The wiper motor should be operating.
1.3. Turn the ignition switch to OFF when the wiper motor is in the innerwipe position.
IMPORTANT: Do not rotate the wiper motor shaft during the installation of the wiper motor crank arm.
1.4. Install the wiper motor crank arm on the wiper motor while maintaining a 4-8 mm (0.157-0.315 in) gap between the V-grove in the wiper motor crank arm and the tab.
Install the wiper motor crank arm screw. Tighten Tighten the wiper motor crank arm screw to 16 N.m (12 lb ft) .
Install the wiper motor crank arm cover and seal.
Check the gap between the wiper motor crank arm and tab. If the gap is not 4-8 mm (0.157-0.315 in) , remove the wiper motor crank arm and repeat installation steps.
Install the drive link onto the wiper motor crank arm.
Install the drive link screws. Tighten Tighten the drive link screws to 5 N.m (44 lb in) .
Install the wiper system module cover.
Additional procedures: Wiper Motor Module Replacement.
TOOLS REQUIRED
J 39822 Wiper Arm Puller
REMOVAL PROCEDURE
Set wiper switch to the PULSE position.
Turn the ignition off when the wiper arms are in the innerwipe position and not moving.
Disconnect the washer hose from the washer nozzle.
Remove the cover from the wiper arm nut.
Remove the wiper arm nut from the wiper transmission drive shaft.
Using J 39822 remove the wiper arm from the wiper transmission.
Remove the wiper blade from the wiper arm.
Clean the knurls of the wiper transmission drive shaft with a wire brush.
Install the wiper blade onto the wiper arm.
Install the wiper arm onto the wiper transmission drive shaft. IMPORTANT: Hold the measuring device at 90 degrees (perpendicular) to the wiper blade tip.
Measure the distance from the wiper blade tip to the solid edge of the windshield blackout. Position the wiper arms at the following distances:
LH - 147 mm (5.79 in) above the glass blackout.
RH - 123 mm (4.84 in) below the glass blackout.
Install the wiper arm nut onto the wiper transmission drive shaft. Tighten Tighten the wiper arm nut to 48 N.m (35 lb ft) .
Install the cover on the wiper arm nut. IMPORTANT: Lubricate the washer hose with the windshield washer solvent to ease installation on the washer nozzle.
Install the washer hose on the washer nozzle.
Remove the wiper arms from the vehicle.
Remove the air inlet grille panel.
Remove the wiper motor.
Remove the air inlet panel to wiper motor module screws.
Remove the wiper motor module from the vehicle.
Remove the insulators from the wiper motor module.
Install the insulators onto the wiper motor module.
Align the wiper motor module to the air inlet panel. NOTE: Refer to Fastener Notice in Service Precautions.
Install the air inlet panel to wiper motor module screws. Tighten Tighten the air inlet panel to wiper motor module screws to 10 N.m (89 lb in) .
Install the wiper motor.
Install the air inlet grille panel.
Install the wiper arms onto the vehicle.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 23, 2012 | 2002 Pontiac Montana
Upper spray arm on my Kitchen Aid dishwasher (8573025) doesn't work.
Arm operates(turns) by water pressure. If it does not turn no water is going to the top spray arm. make sure the setting washer is on does not preclude the top spray arm from operating(read manual). If not check arm by spinning by hand to make sure it is free. If arm is free and it still does not turn when DW is running than there is a restriction in the tubing to the upper spray arm or the check ball or solenoid are not operating correctly.
Mar 01, 2012 | Dishwashers
GE Dish Washer GSD 2800 DO3 runs a partial cycle...(even empty) and then beep and gives a message on control panel "washer arm blocked". Even ran without dish rack in washer still got the...
the rotating arm has a magnet in it to let the controls know if it is turning. Yours is not turning so
  • check the jets for blockages... you might have to remove the arm to clean them properly
  • make sure there in nothing stopping the arm from turning...spin the arm manually to see if it rotates freely.
  • knives etc sticking upward can stop the arms from rotating on the top rack
  • if you run without the rack the arm will obviously be not telling the electronic it is not blocked because it is not there. the rack must be in the machine with the magnet and the magnet passing correct messages.
  • If there is really no blockage then there is a elect fault that need to be sorted professionally.
  • PS have you taken the arm off anf squirted a hose up the inlet to see if water comes out all of the jets????
Mar 01, 2011 | Dishwashers
My deceased parents have a GE dishwasher (don't know the model number - can't find it on the machine and can't find the paper work) that stops working shortly you start it and displays a message on the...
Could be false sensor input, could be that the arm is not turning, I am not sure how old your machine is, but age could play a part if the arm is "in fact", not turning. If you are not mechanically inclined, I would suggest that a qualified repairman check it out. Assuming that it worked ok..Prior to the several months of inactivity, it is hopefully a simple fix. Although I have repaired many a dishwasher, to give an accurate diagnosis on a machine that has not operated in some time, and without knowledge of what it was doing prior, and examining this particular problem...it is hit and miss. I would advise that you examine the wash arm, make sure that it turns freely, If you cannot find an obvious obstruction, or a glitch in its rotation...then you should have it checked out. Could be many things causing this condition...up to and including the water pressure and supply lines...Good Luck! Ihope you find this to be helpful!
Dec 31, 2009 | Dishwashers
Display error
The blood pressure monitor will display an "err" error message for many reasons. It could be the cuff is too small for the arm or wrist. Most wrist monitors measure up to 8.5 inches & arm monitors measure up to 13 inches. If a larger size is needed, then check with a pharmacy for larger sizes. Sometimes placement of the arm is wrong or the tube is not lined up correctly on the arm or the tube is not sealed tightly into the monitor. Sometimes body movement during a reading can cause an error. It is best to check if any of these occurrences happened before the error message occurred.
Sep 06, 2009 | Health & Beauty
I have a confidence 7470 and I can not get my machine to sew because the error sigm says I need to lift my bottonhole arm back up. I have done this repeatedly and have turned the machine on and off to...
It is the switch that is connected to the arm that may not be working properly which in turn send the wrong signal to the display.Check the arm and look for any kind of switch connected to it..Try to move it and see what happens or if the error disappears..
Sep 02, 2009 | Singer 7436 - INGENUITY
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
StorageTek L40- Service required Led Blinking always.
Remove the server connection from the library.
power on the library, follow the display in the front panel. The library will do some checks. Note where it fails. Press the select button, it will display the some code message. With the error code refer the manual.
Sep 18, 2007 | Storagetek L40 DLT Tape Drive
Storagetek L40 DLT Tape Drive Logo
263 people viewed this question
Top Storagetek Computers & Internet Experts
David Payne
David Payne
Are you a Storagetek Computer and Internet Expert? Answer questions, earn points and help others
