Question about Maytag Atlantis MAV9501E Top Load Washer
MAV9501EWW Burned smell and white flakes
Started a load as usual and 10 min later cam back to a bad smelling washroom. Electrical smell and no response on controls. No circuit breaker popped. Drained and pulled covers to find motor had a heavy smell to it but turned freely. The bottom of tub where springs attach at base has white plastic like shavings all over. There was ice in the drain hose(wash room is outside) Where can I get a manual for this and can I take apart the parts with out special tools. One part said there is a 200lbs spring load on it.
  • 15 Answers
SOURCE: Maytag Model # LAT9635AAE
Check to see if it is a pump problem or a transmission problem. First remove both belts see if all the pullys turn freely. if the pump has a tight feel check inside pump for a item jammed in it.look for transmission oil on floor or belts if oil is present transmmision if probably going.ALSO check at the top of the tubs for anything stuk in between tubs.
Posted on Oct 10, 2007
SOURCE: MAYTAG WASHING MACHINE
The rubber smell is the belt from the motor to the tub. The grinding sound is/was the tension pulley that keeps the belt tight. The bearing on the pulley probably went out and now the belt is burning because of the friction of sliding around the pulley. The belt and the pulley need to be replaced. If you have the room, turn off and disconnect the hoses. Unplug the electrical cord from the wall outlet. Remove the drain hose and any water in the tub. Carefully tip the washer over backwards, DO DROP IT!!! Now you should be able to see the motor, tub, tension pulley, and belt. With a basic 3/8' drive socket set, probably metric, and a couple of screw drivers you should be able to remove the belt and the pulley. Take the belt, pulley, and model numbers to an applicance parts store and buy replacements.
I only suggest this because I hate paying labor. If you are not machanically inclined then you are going to have to pay the labor.
Good Luck
Posted on Dec 19, 2007
reg501
  • 413 Answers
SOURCE: off balance spin cylce
The base of the tub assembly rests on a white plastic ring called a 'snubber'. If any type of lubricant gets in this area, the tub will wobble excessively. The major cause for this issue is a failed transmission where oil has leaked out and into the snubber. The transmission may be warranted for 10 years. Check your owners manual. A good method to check for oil is to tilt the machine back and remove the plastic cover in the center of the pulley, if it contains oil, the transmission is leaking also look at the inside cabinet wall for signs of oil splatter.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 19, 2008
  • 11 Answers
SOURCE: Burning smell + Screeching sound but Belt is not the cause, then WHAT is?
A lot of people may be searching for help with horrible sounds and burned belts for Maytag and Admiral washers only a few years old from Home Depot etc. They used a cheap pump that has a corrugated sheetmetal ring that holds the bearings. Well as it runs the vibration and friction cause it to slip down and grind on the pulley as well as not turn easily. If you put the washer on it's back and turn the small pulley and it turns with a gritty feel or you can actually see a loose metal collar type ring thing that looks like a cookie cutte; then you have a bad pump.
There is a small access panel on the back of the washer. Three screws and two spring clips on the hoses and you're done (use big pliers on the hoses). Put the belt back on (just push motor to one side, it's not tight), then check for leaks and reinstall the cover. VOILA! You can find the pump on ebay for $25 or your local GE parts dealers for $50.
Posted on Sep 22, 2008
Healeyman
  • 1198 Answers
SOURCE: washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
Posted on May 04, 2009
It has white smoke when u run it for 10 min it stops
Sounds like a bad head gasket. Check your oil after car sat all night. See if there is white , or any signs of water in your oil. Smell dipstick at the same time to see if there is the smell of gas in the oil. While car is cold check the coolant for traces of oil in the cooling system. , or the smell of gas present. When the head gasket goes,it no longer separates the different ports for oil, coolant, and gas mixtures. What happens is that coolant gets into your engine cylinders where gas, oil, and air mix, and ignite. This causes steam to come out of the tail pipe. If you are going to change it yourself, keep me informed and I can walk you through it. What size motor is in the car?
Jan 11, 2013 | 1994 Ford Thunderbird
My mazda 626 has a strong potent smell coming from the exhaust
You don't mention what that smell is reminiscent of?
You don't mention the colour of the "smoke" and you didn't say whether the engine is petrol or diesel?
You don't mention whether the road behaviour/performance is normal?
White smoke is almost always steam or in the case of a diesel it could be an unburned fuel mist, grey/black is excess fuel and blue or grey/blue is burning oil.
Some steam is fairly normal until the engine and exhaust system is hot but excessive amounts could be one symptom of head gasket trouble. If the engine is drinking coolant and sending it through the exhaust as steam it will sometimes smell spicy.
Burning oil smells a bit like burned eggs in the frying pan.
If the car hasn't ultra-low sulphur oil and fuel the catalytic converter will convert sulphur traces into hydrogen sulphide - the bad egg gas...
Sep 27, 2017 | 1998 Mazda 626
My Kennmore 79363 Gas Range/ Electric Oven electrical doesn't work. Started smelling electrical burning smell, tracked to oven. shut off breaker, smell stoped. Few hours later checked again after...
The person who installed the oven didn't do the connections up tight enough.
I would replace the breaker/power switch with a new one and trim back the wires if the burning is in the breaker. If on the rear of the oven, same applies with badly tightened connections.
If in doubt, call a qualified electrician. That will be better than having a fire!
Aug 06, 2017 | Kenmore 79363 Gas Kitchen Range
White smoke coming from the machine, it was in the middle of the extended cycle. stopped machine and unplugged. Smells as though something burned.
Usually the first repair a Maytag washer needs is to replace the belts. They can wear out and smell.
The belts are located on the very bottom of the machine. They are not covered. If you pull out the washer about 2 feet and lean it back against the wall you will see the belts on the bottom.
If they have shiny parts, or one of them was sticking. You will be able to see if it is burned.
I've made a diagram to help.
The "main drive pully" is the belt that is most likely to be burned. It is also possible for a clothing item such as a baby's sock, to get caught in the pump. That being the case, the pump belt can burn.
If you replace the belts, which you should do if the machine is 10 years old. You must replace them with Maytag belts. This is important, because they are designed to allow some slippage. If you replaced them with belts of the correct size but not the right type, the machine will not work properly.
Of course, the machine can have electrical problems, but it is rare. Let me know what you find and I can advise you further. Happy New Year, Mark
Jan 02, 2011 | Maytag MAV3855A Top Load Washer
Starter and wiring
maybe burning smell is comes from the starter,i think the magnetic field of the starter is burned,check it
Feb 19, 2010 | 2003 Mitsubishi Eclipse Spyder
Dryer smells like gas
If you smell gas then there is a leak. The gas company came out and checked for a leak? Get them back in the morning before you open the room to check again. Eric
Aug 27, 2009 | Whirlpool 7.4 Cu. Ft. 10-Cycle Super...
I have a maytag washer MAV9501EWW that has a bad odor. Looking at the website and it refers to being HE and using normal detergant instead of HE. Is it HE? No where in the manual does it talk about being...
do a full load of whites, lots of bleach, extra wash/heavy duty cycle, hot wash and hot rinse, not too much soap. this usually works, like a washer flush.
Aug 19, 2009 | Washing Machines
Car died rotton egg smell
Not sure if engine coolant smells like rotten egs when it burns inside the cylinders , but it sounds like you may have blown a head gasket. Coolant and/or oil could be getting inside combustion chamber. Another possibility is that the catyletic converter might have broken up and colapsed onto the screen where it goes into the exhaust. Might give the rotten egg smell and block the exhaust enough to cause backpressure sufficient to cause the engine to run poorly too.
Try putting your palm over the exhaust pipe , if the exhaust is coming out in pulses (pop ,pop,pop) thats normal , if it is just slowly flowing out with no noticable pulses , I would check into the cat converter problem.
May 07, 2009 | 1997 Buick Riviera
Bad smell from ac unit in my house
does it smell like literally , dirty socks?if so it is dirty sock syndrome, a plague of heat pumps for years. if it smells like an electrical melting or burning of wires then time to call a pro.it could be a weak capacitor or a weak fan motor. if it is dirty sock syndrome then its the microbes that thrive when temps are middle temps and reproduce when temps are hot and cold in intermittent days. hot one day and cold the next equals call for cool then call for heat and hot steam from heated coils cause s bacteria to grow and microbes to spread across coil. when you switch back it causes the smell.if the coil is clean you can spend a chunk of money on sanitizers but best bet is to run it cool for hot weather and hot for cool weather. the transitional periods are what create the smell. avoid semi cool and semi hot periods. this condition is common to acs from all brands . lots of stuff on the internet about dirty sock syndrome
Oct 31, 2008 | Sharp CV-P09FX Air Conditioner
Vibrating Noise and Electrical Smell
The noise and smell usually come from a bad transformer. If the magnetron has burned out usually the transformer will need to be replaced as well. The transformer is right behind the grille on the right hand side.
Mar 09, 2007 | LG 30" Over the Range Microwave Hood with...
Maytag Atlantis MAV9501E Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
