Question about HP Compaq Motherboard
Installation of mother board
I need help installing a HP laptop motherboard.
  • Roger Gantner May 11, 2010
    Agreed.
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    laptop motherboard installations aren't for novices. It could very likely take a good 3 hours and you literally have to remove dozens of screws and remember where they all go. And I can't help you anyway because you didn't tell us which laptop you are working on.
  • 530 Answers
Hi im josh in cebu phils. friend try to use this solutions it will help you.
Installing the New Motherboard First, make sure that the new motherboard is the same form factor as the case. Then, make absolutely certain that the power supply is set for the correct voltage to avoid zapping the new board. Look at the back of the case for a small switch that says 115V and 230V, or something similar, as shown in Figure 3.12. This should be set to the voltage available in the country in which it is used; in North America, this voltage is 115.
Figure 3.12: Power supply voltage switch. Next, make sure that no conductive surface comes in contact with any metal parts of the case. While some cases have elevated mounting holes that hold the board away from the case wall (see Figure 3.13), other cases call for standoffs. Standoffs are small spacers that go between the board's and the case's mounting holes (see Figure 3.14).
Figure 3.13: Elevated mounting holes.
Figure 3.14: Standoff assortment. After screwing in the screws, you need to install the power connectors and then follow the manufacturer's instructions for setup, which we discuss next. After you've done this, reinstall all of the compatible peripheral devices (if any) that were connected to the old motherboard. For more information on installing peripherals, see the rest of this chapter, Chapter 2, and the chapter appropriate for the type of device in question.
Motherboard Setup There are certain things you must do to the motherboard to get everything working together. Some boards have stickers indicating the proper positions of DIP switches and jumpers, but in most cases, the documentation (manual) is essential. If you don't have the manual, you can usually find information on the manufacturer's Web site.
Tip In some cases, the board was manufactured by one company but sold by another under a different trade name. In this case, you might be able to find the actual brand and model number by peeling off a brand/model-number sticker on the board to reveal the actual manufacturer's sticker. Make sure the board is not under warranty when you do this; peeling off the sticker might void an active warranty.
On the CD See the Industry Contacts document on the accompanying CD-ROM for manufacturer contact information.
DIP Switches and Jumpers All boards have DIP switches and/or jumpers (see Chapter 2 for general information on these). Depending on the board, these are used to select such settings as the speed and family of the processor, and there might also jumpers to reset the CMOS, redirect the sound from the rear to front connectors, select the type of memory to install, and others.
good luck.
Posted on Mar 05, 2009
I partitioned my Toshiba C675 laptop, but didn't do install mother board cd. is any problem with that?
Not really, unless you need the drivers for hardware that did not load with the Windows CD.
Dec 26, 2012 | Toshiba Portege 7020CT (P000272180)...
Installer for mother board hp compaq dx2200 MT
You can download the drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
Jan 09, 2011 | Intel Motherboard
MY LAPTOP OS WINDOWS 7 GEINUIE , MOTHER BOARD CHANGED AND OS NOT IASTALL AND INSTALLING ERROR
If you are using the installation disc that came
with your laptop, it will only install Windows on the same motherboard (or exact same model). The reason, Microsoft 'sells' the Operating System to the manufacturer for use only on that model machine.
The installation looks for a motherboard that
has a special 'tatoo' that Windows disc looks
for. If it doesn't find it, it won't install.
Nov 22, 2010 | HP Computers & Internet
I cant get sound on my laptop it says no audi output is installed
Please Install the Audio Driver For Your Pc Which Is In Mother board Cd Provided!!
Feb 24, 2010 | Compaq 449901-001 - HP Presario V6500...
Need to know where to put wires on hp motherboard
The last clarification that you provided with details on the motherboard and type of computer it came from were perfect!
I work on HP computers, laptops and printers everyday - as that is the only model we use at my company. I can surely help you with this one as I am well versed in breaking down and rebuilding computers. I don't know if there are specific wires that you're unsure of, or if you need help installing all of the wires to the board. Hopefully, this will help get you started.
I located a really detailed layout of your motherboard. You will see one black and white, drawn and labeled diagram of the board as well as a color photo of the board that isn't labeled. You will also find specs on the board as well as information about clearing the BIOS settings and/or BIOS password.
Click this link: Motherboard Specifications, MCP61PM-HM (Nettle)
HP's name for this board is also Nettle. It's pretty explanatory and if you try to connect a wire to the wrong connector on the board, more than likely, the pins won't match and it won't fit.
Hope this helps! Feel free to post any additional questions if you have problems installing the board.
Mar 24, 2009 | HP Compaq Motherboard
Need XP drivers for the MS-7525 Compaq mother board
Almost any drivers will work off the site. MS motherboards are weird like that.
Try this one:
Motherboard driverd are available here:
http://mxdtr.com/index.php/category/msi-ms-7525-ms7525-motherboard-boston-gl6-xp-audio-sound-video-chipset-driver-drivers-download/
Feb 06, 2009 | HP Compaq Motherboard
MOTHER BOARD DRIVER
Dear Sir,
I have installed windows xp sp2 and i have installed all the drivers of compaq desktop pc MODEL NO IS SG3430IL but i was unable to installed the display driver so, sir please guide me how i will install the driver its urgent.
Rgds
Bapi sarkar
Jul 22, 2008 | HP Compaq Motherboard
HP Compaq Motherboard Logo
222 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
