While making a shake I turned the glass top of the blender to lock it, but turned in the wrong direction. Liquid spilled down onto the buttons. I let it dry out before trying to use it again but the only sign of life is the illuminated "Varipulse" button; other than that, nothing works. Have I completely killed it or is there a fix for this problem?
Usually leakage into the base can compromise the motor's performace. Since it sounds like this also has digital displays, you don't want to risk messing it up even more by turning it on. The company should have service places you can take it into to get checked out, some might even do an estimate for free. I would call the company and see if that's possible and maybe just a quick cleaning can fix it.
Was this helpful?
Yes
No
Popular Solutions for Krups KB7207 4 Speed Blender
when I press any speed buttom it stops after a couple of seconds. The blending action stops every...
(More)
when I press any speed buttom it stops after a couple of seconds. The blending action stops every couple of seconds on any speed.
While making a protein shake last night i threw in water, then powder and started blending slowly....
(More)
While making a protein shake last night i threw in water, then powder and started blending slowly. then i put in a banana and it was thick so i put some more water. It was working but sounded like it was laboring. then i threw in a cup of ice, not large chunks but little smaller than ice tray ones. then it just quit. I thought maybe it was overheating so i left it for a while but to no avail. This morning it still does not work.Could you please let me know if there is any tests i can perform to determine what the problem is? thank you Rich Lampman
Hi. I already tried your suggestions (making sure base assembly is properly attached, that food...
(More)
Hi. I already tried your suggestions (making sure base assembly is properly attached, that food items aren't blocking blade, etc...), and have left unplugged for a while to "reset", but all that happens when a speed button is pressed is that the light beneath than button goes on momentarily, then cuts off, and the blades don't begin turning at all. Would appreciate you help, Daniel
