Question about Ruud Heating & Cooling
Air conditioner will not turn on, we taped the wires out the outside unit and now it will not turn on, which wires on the out side need to be connected??
  • 374 Answers
Check your power supply if it is available by using voltmeter or Multitester.If yuor using single Phase supply of 110/220 V source.If two wire was expose this is single phase test the volt by mounting test rod of tester on two wire using voltmeter.If there is 110/220 v registered on your tester this rhe wire to be connescted mean there is source of electricity.
Posted on Mar 05, 2009
Thermostat wiring diagrams
you need to have two wires one to y terminal and the other to common. on the outside you can hook them two the two wires going to the contactor coil on the 24 volt side you can hook them in any order,
Aug 24, 2014 | Heating & Cooling
CPLj24-1b
check outside breaker see if it tripped. thermostat, low voltage wire going to outside unit or contactor on outside unit bad.
Jul 06, 2013 | Goodman CPLE24-1 Air Conditioner
Wiring diagam for spit system mitishabishi airconditioner
S1 and S2 is the 220vac S3 is the commuicating connection to the outside airhandler. The solution is on the control board that handle the remote funtions
Jan 21, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a carrier 38ycc030340 that keeps blowing the airhandler 5 amp fuse
Hello, check the tstat wiring from the air handler to the outside unit and check for any wires that are loose or possibly touching metal, also, make sure the wires are connected securely at the air handler, tstat, and outdoor unit.
May 01, 2011 | Carrier 38CKC042 Air Conditioner
My Mitsubhishi Mr. Slim MSZ-A17NA 1 is drippping water on the inside. I have turned it off for now. What should I do? We're in Mississippi and it is a hot day! thanks
Hi!!
Make sure the unit is leveled, there is a drain hose coming from rigt side of the unit goes through the wall to the outside and down, this hose is probably clogged up.
Go outside the house and look for it. there should be some tubing wrapped in insulation going up to the roof top and a drain hose coming down. You can try to unplugged it from the inside using a wire clothes hanger or you can blow air from the outside end into the unit, you only need a small blow and you can use a flexible funnel or a piece of garden hose and some tape to do it. if you are going to do this make sure to drain all water from unit using a towel to avoit splashing. This works all the time.
Don"t forget to rate this post. Good Luck!
Jul 01, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Can I install the unit in the window sideways?
Not really unless you can divertthe hot air from the back side to the outside and and the cool air and intake to the inside, you could do it with some clear tape and some plastic sheeting , but better to build a frame to hold it outside facing in two L brackets then tape it up with some thick plastic.
Jul 23, 2009 | Heating & Cooling
My air conditional unit outside ,fans turns on but the unit compressor wont turn on,just stopped working this morning.i turned the thermostat to 72 but only the fan on the outside unit comes on and it is...
Somethings aperson cant fix without a service tech. First it could be wire burnt of capacitor going to compressor. Second it could be bad capacitor. There is a dual capacitor on the ouside unit one side says herm that runs the compressor. Turn power off to check to see if wire is burnt of the herm terminal or the C ternminal. Wire burnt off compressor common terminal.. Could be locked up compressor. Unless you know how to troubleshoot unit. You may have to call service tech. Cost if bad cap. is about 100 to 150. But unit wont run without it. Rus
Jun 21, 2009 | Emerson Quiet Kool 12HT13 Air Conditioner
Trying to install a fan motor for my outside ac unit replacement motor has 5 wires on it. my old on had only 3 driving me nuts
Your old moter had three wires. Common High and brown for capacitor. This one sounds like a two speed. Dont worry Now you have two brown wires for you capacitor instead of one. Tape off brown wire with white strip. Connect other brown to cap. You should have a white or yellow for common wire and black for high. Tape of the other extra wire and wire in like the three wire. Rusty
Jun 03, 2009 | Continental CE-PAC1163 Air Conditioner
My dog chewed up wiring on outside unit and i dont know where they hook up it is a 4 wire set up with red white blue and green large ac unit dog chewed thru little brown wire leading to house and now ac...
That wire is to your thermostat which of course turns the A/C on/off. One thing you can do is to splice the wire back together w/ small wire nuts (available at hardware store or wal-mart, and just hook it up color to color and then tape w/ electrical tape. Make sure you turn your breaker off and turn off the thermostat control.
Feb 11, 2009 | Heating & Cooling
Window Air Conditioner Sweats
You need to seal the portion of the air conditioner that is inside the window from the portion that is outside the window, Sweating is caused by moist outside air leaking in and contacting the cold portion of the air conditioner. Do not use duct tape, buy aluminum tape which is what professionals use to seal air leaks on ducts. Home Depot sells the tape. Buy the smallest quantity you can find that will do the job ( it can be expensive ) unless you plan to go into air conditioning duct installation.
For best results use some form of insulation over the accordian like side baffles ( cut to fit) . Styrafoam from packaging or silver backed insulboard (Home Depot). Now tape the sides of the insulation to all sides of the window frame, bottom of the window, the sill, and the air conditioner.
Unless you enjoy doing this every year - plan on this being a permanent installation. It is a tedious job because the aluminum tape is not very forgiving and has a peel off backing but it sticks forever.
May 08, 2008 | Heating & Cooling
Heating & Cooling Logo
47 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
