Question about GE Spacemaker JVM1640SJ Microwave Oven
Where can I purchase the round piece which goes in between the tray and the bottom of the microwave? Our tray no longer turns when the microwave is on. GE Spacemaker xl 1800.
    President:
  • 267 Answers
Www.searspartsdirect.com
Posted on Mar 05, 2009
Oster microwave turntable will not turn, food on one side is hard as a rock
hi suzanne.
If the glass tray in your microwave doesn't turn, it may be due to a broken drive motor. Most units have a round glass turntable which has a motor driven coupler and roller guide turning the tray. To access the motor, first unplug the microwave and remove the bottom panel.
How to Repair a Microwave Tray That Will Not Turn - PartSelect
microwave turntable will not turn Google Search
Nov 07, 2017 | Oster Microwave Ovens
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
May 12, 2014 | Panasonic NN-S963BF Microwave Oven
Magic chef microwave
Take the tray and the plastic piece the tray sits on out of the microwave. There is a small motor that turns the turntable. It is probably bad. You should be able to replace the motor from the bottom of the microwave. Part number is 3966820200.
Jan 18, 2014 | Microwave Ovens
My sharp R-340H no longer cooks. Still powers up
Please check the door safety interlock switches ...
If the switches are faulty, the oven thinks the door is open and will not turn on the heat ...
Find them indice hear the latch assembly.
Jul 09, 2010 | Sharp R-340 Microwave Oven
Microwave glass tray is broken. It is discontinued.
Yes you will not hurt anthing by not putting on the bottom. One substitution that works extremely well is to find you a plate like they use in regular ovens or anything that is microwavable of that sort. Sears has an excellent selection of microwavable cookware and there is nothing in the rule book that say you canno find you a piece to match the bottom of your microwave. It works either way. Good luck and God bless.
Jan 22, 2009 | Microwave Ovens
Kenmore elite microwave/vent hood model 721.80834500 turntable
I bought a Kenmore Elite Microwave Hood Combination Model 721.80823500 at Sears. The installer did not bring the parts to connect the vent to the pipe on the ceiling and never came back. I cannot find the vent/exhaust connetor part to have it installed. No one knows. I appreciate information or installer. Thanks.
isabelmvaldes@gmail.com
Nov 16, 2008 | Kenmore 63792 Microwave Oven
Turntable no longer turns
That would be the turntable coupler.
For more help from Emerson : http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Nov 25, 2007 | Microwave Ovens
Kenmore elite 721.80833 microwave
I purchased a later model glass tray which was redesigned and now it works fine.Just take your tray to the store and compare it to a newer one and you will see the difference.
Oct 20, 2007 | Kenmore 80803 Microwave Oven
Turnaround glass tray problem
Sometimes they get heated up and bend up in the middle so they don't make good contact with the coupler. The way I fix this is to heat the support over a stove flame, then place a heavy weight on it so it holds the legs up in place a bit until it cools. Here it is step by step: 1. Apply heat at points where each legs meet the hub (stove flame) 2. Place end of each leg on an object so that the bottom of the hub is held up about 1/8" off the work surface. 3. Place heavy object on hub so the bottom touches the work surface. 4. Let it cool. 5. Test it. 6. If it still does not work, increase the height of objects in step two. See: http://207.234.249.73/mwd/turntable_support_fix.gif
Mar 26, 2007 | Kenmore 80809 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
49 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
