Question about Whirlpool Dryers
Adjust propane gas pressure on Whirpool Duet Dryer
I do not see the shutter on the burner tube to adjust the flame. There should be one right?
5 Suggested Answers
  • 1073 Answers
SOURCE: Propane gas flame too high
if it set up for propane or natural gas need to make sure if for propane you need to change the orifice in the cook top, it is shipped for natural gas call the store and they can order the kit
Posted on May 06, 2008
rockitman187
  • 2559 Answers
SOURCE: Flame does not seem hot enough - too much yellow flame.
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Posted on Jan 08, 2009
sclarke7
  • 218 Answers
SOURCE: gas dryer leaves black grease spots on clothes
the soot is coming from the flame at the gas heater box the drier needs to be converted to propane the flame is too large without the conversion kit installed and thus creates soot at the vent. contact a local repair place for this one it can be tricky.
Posted on Sep 12, 2009
TheMobilian
  • 8205 Answers
SOURCE: How to adjust orifice on gas dryer going from propand to natural
My gas Conversion notes: HERE
Posted on Jan 05, 2010
  • 36 Answers
SOURCE: Propane gas flame is not hot. Do I adjust the air
Here is something to try if it is LP Gas:
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Posted on Mar 25, 2010
How do I adjust the flame in my gas oven
You have to be careful when adjusting the flame because you can cause carbon monoxide issues. There are two adjustments. the orifice hood and the air shutter. the orifice hood when turned will adjust the flame amount and the air shutter will adjust the burning of the gas. the hood will be on the line feeding the burner usually on them safety valve and should be a 1/2 inch nut. The air shutter is the door like opening on the burner tube itself. Your flame should be a nice blue cone without any yellow and should not blow and walk off the burner.
Oct 05, 2014 | Kitchen Ranges
I see to have too much gas pressure after converting my Neptune dryer from natural gas to LP
you should not try to adjust the flame. LP burns more yellow that NG. The gas pressure automatically regulates the airflow based on the dynamic pressure that goes through the burner chamber. If your flame is roaring and pushing forward, everything is Okay, if it is a "Lazy" and falling flame, you have a blockage of the airflow - venting system
Mar 03, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Starts to light but goes right out
Vaporized propane sounds just like air coming through a hose. Turkey fryers use a different regulator than a standard barbecue which uses a low pressure -- 11" water column displacement. Pressure for a BBQ is measured in displacement because LP pressure is very low, less than half one pound PSI. Turkey fryers use a higher pressure so more gas is able to feed to the burner but the regulator diaphragm adjusts because of the adjustment wheel. However, before determining the regulator needs to be replaced, adjust the air shutter on the venturi and ensure the orifice is clear. LP must be mixed with air in the burner in order to burn but if the shutter is open too much we can hear air-flow and too much air can definitely cause that sound and cause flames to blow out. We have a video at you---e showing the adjustment with too much air blowing-out the flames. First check your connections and orifice to make sure there are no leaks or impediments. Second restart the burner with the air shutter almost closed and continue making adjustments -- while burning if possible. If neither of those work replace the pressure regulator. Most people will initially say replace the regulator but they do not go bad as often as many think; a regulator is only a open space that limits him much gas can travel through at any time.
Nov 29, 2013 | Bayou Classic Sp10
Purchased a used gas oven yesterday. The top burners are working fine, but the oven is sooting up. We live in the country and use propane, but did not receive any additional orfice or instructions. In the...
We need a model number to be specific.
Check the gas regulator and make sure the pressure cap has been set for propane.Most of them are turned over to put more pressure inside the valve.
If so. Check the air shutter on the bake gas tube and adjust for the best color flame.
Also tighten the bake burner orifice with a 1/2 inch wrench.
Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
ON THE CAST IRON BURNERS THERE IS A PLATE WERE THE BURNER INSERTS INTO THE GAS VALVE. THIS PLATE CAN BE ADJUSTED TO ALLOW MORE/LESS AIR TO THE BURNERS BY SWIVELING THE PLATE .CANTHESE BE REPLACED
This 'adjustable plate' is known as an 'air shutter' located at the tips of the venturri tubes which are the tubes that carry the propane from the valve to the burner. These air shutters allow you to control your flame by mixing oxygen with propane to create a yellow flame to a blue flame. The perfect flame is a uniform blue flame with a small yellow tip.
Unfortunately, these air shutters are considered part of the burner itself and cannot be individually replaced. However, if the burner and venturri tubes are separate from each other, you may be able to get a replacement venturri tube without having to replace the entire burner unit.
Hope this helps.
Ben
Tanks 2 You Propane
propanetanks2you.com
Mar 30, 2010 | Lynx Grilling
Jan 05, 2009 | Kenmore 63942 Dryer
Viking Gas Oven VGSO-166 flame too high
make sure the hood orifice is a #52. (orifice to bake burner)you can go to the local propane gas company and see if they have one they will sell you.
Nov 14, 2008 | Viking VGSC306-4B Gas Kitchen Range
Burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Jan 08, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Burners with yellow tipped flames
I have a G.E. natural gas cook top. All 4 burners have a lot of yellow flame all of a sudden. Is there an adjustment for this I could make? Please explain the best you can.
Jan 05, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Dryers Logo
154 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
