Question about Frigidaire Washing Machines
Frigidiare washing machine squeaks in spin cycle
It squeaks when it is in the spin cycle. I have a Frigidaire gsws1749as2 top loading washer. There is a loud squeal/squeak that starts after the machine spins for a few minutes. The squeal changes pitch when I open the lid and the spin cycle slows down. if I let the machine come to almost a full top, the noise stops and I can close the lid & the spin cycle completes silently. I have run the machine with the front cover off and tried to isolate the noise, but I have had no luck. It sounds to me like it may be a dry bearing. I felt the bearings on the tub & transmission to see if maybe they were hot, but everything was cool to the touch.
Use fairy liquid it works best
Posted on Mar 05, 2009
  • kaleem ullah
    kaleem ullah Jul 08, 2014
    Throw it away! Ain't worth it! Rear bearing is giving up so you would need inner and outer drum triangular prolly about 400$ parts.
Why washing machine squeaks when in wash cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a squeaking noise during the wash rinse cycle on your Frigidaire washer. You could be hearing the noise from your motor during that operation, this is normal. Additionally, if you feel that this is noise an issue I would contact a professional to come out and diagnose your appliance properly. -Matt
Aug 23, 2014 | Frigidaire Washing Machines
Frigidaire front load washer will start and after about 2 seconds will stop. Lights will go from normal working to no spin
From what you have described I would have a professional diagnose the unit's timer and main control board for possible replacement of those parts.
Aug 31, 2012 | Frigidaire FTF2140FS Front Load Washer 10...
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Not spinning water from machine completely..... have to remove some of the clothes and restart spin ......also has a squeak sometime. Thanks for your help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Oct 05, 2010 | Frigidaire GLTF2070DS Front Load Washer
When the washer is in the spin cycle it make a loud squeaking sound
heatman101
Sep 13, 2010 | Maytag PAV2300 Top Load Washer
My washer, Frigidaire #CWS3600AS0, is smoking and squeaking when it's in spin cycle. Any idea what could cause this and is it fixable?
You need to replace the drive belt at the bottom of your machine. It has become stretched and worn from use. Fairly easy repair.
Nov 03, 2009 | Frigidaire CWS3600AS Top Load Washer
No spin cycle
Yes, it is the door latch assembly. replace this and you should be good to go. You can get it from an appliance parts supplier.
Dec 20, 2008 | Frigidaire GLTF2940E Front Load Washer
Washing Machines Logo
572 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
