INSTRUCTIONS ON HOW TO BURN CD FOR MY LAPTOP
HOW TO BURN CD ON MY TOSHIBA SATELITE M305 -S4907 LAPTOP ... I JUST WANT TO KNOW WHAT I NEED TO DO IN ORDER TO BURN THE CD I CALLED TOSHIBA THEY SAY I HAVE THIS FEATURE BUT THEY CANT SEEM TO HELP WITH THIS ISSUE. I AM USING CD-R CD'S SOMEONE PLEASE HELP!
  • jen1always Mar 11, 2009
    THANKS ALOT GUYS.... IT WORKS NOW I REALLY APPRECIATE IT!!!!!
  • 1,800 Answers
Its very easy u can download the latest version of nero its an amazing software of burning cds and DVD
free trial of Nero
Posted on Mar 05, 2009
  • 52 Answers
Umm... You need a program like Nero to burn anything to CD. Start with that first and the rest will fall into place for you.
I recently purchased a Toshiba PA3761U-1DV2 external multi burner/reader. I have a Toshiba Satelite Vista SP2 32 bit. The included software won't install. However the drivers did install and
It usually better using the burn software that came with the multi burner because it will be compatible with your multi buner. Windows media player burning cannot be compatible to all the burners on the market.
Mar 07, 2013 | Toshiba PA3761U-1DV2 DVD-RAM Burner
Toshiba satellite M305 S4907 comes on but monitor is blacked out can barley see
http://www.screentekinc.com/Toshiba__Satellite__M305-series-laptops-lcd-screens.shtml
The Toshiba Satellite M305-S4907 Notebook PC, uses a single CCFL for a Backlight.
Primer before we go on;
An LCD screen cannot produce light. It needs an additional light source,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor image.
The additional light source is a Backlight.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 8 photos.
A screen Inverter is used on laptops that use CCFL for Backlighting.
A screen Inverter converts the power (Electricity), from the laptop, for the LCD screen, and Backlight.
Laptops that use a series of LED's for backlighting, do Not use a screen Inverter.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
http://www.sparepartswarehouse.com/Toshiba,Satellite,M305-S4907,PSMD8U-02R015B,Laptop,Inverters.aspx
The plastic thin frame in front of the LCD screen, is the Display Bezel. (Toshiba = LCD Bezel)
The screen Inverter is located behind the Display Bezel, and mounted at the bottom of the LCD screen.
(LCD Screen Frame, actually)
Easy to get to; easy to replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-M305/remove-screen-inverter-video-cable-1.htm
How to test a screen Inverter? Requires a Sensitive multimeter.
Read fairly expensive,
http://www.fonerbooks.com/test.htm
Because of this; and the low cost, plus ease of replacing; most home users just opt to replace it.
Know this;
Fluorescent lamps have MERCURY inside. HIGHLY poisonous.
Now couple that with the long thin makeup of the CCFL, and how easy it is to break it.
This is why if the screen Inverter is found to NOT be the problem; I would suggest replacing the LCD screen itself; instead of trying to replace the CCFL, and cause possible Mercury poisoning.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 12, 2012 | Toshiba Satellite Computers & Internet
What type of DVD should I use to record or burn a movie on it in my Toshiba Satelite A100 lap-top computer?
Go to www.ebay.com Type: Make and Model of your laptop and refine search DVD driver, you will be presented with a choice of DVD units at different prices, stay away from the used drivers, "they are a gamble" But you need a DVD/R-WRITER to burn discs and watch movies.
Apr 10, 2012 | Toshiba Satellite A100 DVD/CD-RW Combo...
Toshiba Satelite S355-S7915 Laptop. I made recovery discs and don't know how to use them to recover
You have to reboot your laptop with the CD in the CDrom,
Then boot from CD and follow instructions its pretty straightforward
Jul 18, 2011 | Computers & Internet
How do i reset the m305-s4910 to factory setting
Recovery
  • How to recover a Toshiba notebook with the HDD recovery procedure
  • http://aps2.toshiba-tro.de/kb0/HTD9A02QI0000R01.htm
From CD
  • http://cdgenp01.csd.toshiba.com/content/support/downloads/PMA500339010_web.pdf
You may have a hidden partition on the harddrive - if so you can recovery from there - BUT - you should also be able to create some bootable recovery DVD or CDs from the hidden partition using the toshiba recover cd creator Two ways to get to the hidden partition on Toshiba
  • Press an hold the zero key and power on - this will enable the recovery menu
OR on later models
  • Tap F8 as it boots and then use repair computer - from menu
  • How to recover a Toshiba notebook with the HDD recovery procedure http://aps2.toshiba-tro.de/kb0/HTD9A02QI0000R01.htm
if not you can order replacement recovery cds
  • https://backupmedia.toshiba.eu/landing.aspx
Apr 10, 2010 | Toshiba Satellite M305-S4826 Laptop
My notebook camera for my laptop (toshiba m305-s4907) doesn't work and everytime i try to launch it, it doesn't launch.
big red
have the same problem here it only worked the first couple of times then hasent worked since took it to geek ssquad told me that it just burned out wich suxs
Oct 25, 2009 | Toshiba Satellite M305-S4815 Notebook
Need take down instruction to fix a35 power addapter
Hello there:
if you do a google search
toshiba satelite a35 dissasembly instructions
there will be a big section on these laptops so make sure you get the right ones ok?
best regards mike
Aug 17, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Computers & Internet Logo
304 people viewed this question
David Payne
David Payne
